Here is a list of all the postings Dave S has made in our forums. Click on a thread name to jump to the thread.
Thread: Being nice to a vise |
08/10/2021 15:38:25 |
Never worried about it with my metalworking vices. A none issue in a workmate - there are 2 screws just balance the loading. Dave |
Thread: cutting spur gears on a mill |
07/10/2021 19:23:43 |
Over on homeshopmachinist there is a thread where a chaps leadscrew appears to be the wrong pitch. In the middle of that is :Plastic gear making Spur gears free moulded install a lathe…
Edited By Dave S on 07/10/2021 19:25:29 |
Thread: Brazing/high temp silver soldering with 999 Ag wire? |
07/10/2021 13:56:21 |
Copper to copper is certainly possible with fine silver - that's how I attach things I'm going to enamel together. I use plain borax for the flux. I suspect brass will be 'tricky' as IIRC the melting point of silver is above the melting point of brass. Can't say about the price comparison for sure, but a reel of fine sliver wire I bought was about £30 and I expect it to last me for a good few years yet.
Dave |
Thread: gr 8.8 ht bolt steel which carbide tip |
06/10/2021 18:52:08 |
For what it’s worth I don’t think these are made of chinesium or cheese, but the modified quite easily with a quality HSS endmill Dave |
06/10/2021 17:38:52 |
Don’t forget that tool holders are just metal, and can be modified. My 2 mainly used ones are both larger than ideal for my tool holders, so I chucked them in the mill and removed a chunk from the underside. Dave |
Thread: Shim stock |
03/10/2021 16:25:14 |
I have used razor blades for small shim stock - the double edge type, not the ones moulded into plastic. Dave |
Thread: I need to cut chamfers into x64 pieces of mild steel - any advice? |
29/09/2021 15:59:18 |
“Coolant” with carbide is mostly to flush the chips away. Intermittent coolant on carbide tends to thermally shock the tool, and is more likely to lead to poor tool life. I mostly use coolant when I want to be able to measure a part soon after cutting - it helps to keep the part at near to ambient temp - so my measurements are more likely to be accurate… I would trust MSC and Ketan for info more that Axminister. Dave |
28/09/2021 18:44:10 |
Coated carbide on mild steel and a machine that isn’t setup for full flood I would try no coolant at all. Also go look at MSC direct for *much* better choice and prices. Dave |
Thread: PM Research#1 Cylinder Can it be saved ? |
26/09/2021 13:05:45 |
I would bore slightly oversized and sleeve the cylinder. If you haven’t made the valve yet you can make it oversized to cover your ports. Dave |
24/09/2021 17:30:05 |
Pretty sure you can calculate PCD from Mod and tooth count, and can do Mod from tooth count and outer diameter. From that you can layout the centre distances of a pair of gears. PCD for a single gear is not a very useful number anyway
Dave |
Thread: Buying advice sought re Milling Machines: e.g. Proxxon: FF230 vs. BFW40/E vs. MF70 |
24/09/2021 12:38:15 |
John - What is so bad about your MF-70? Dave |
Thread: Cylinder Head Combustion Chamber Template |
24/09/2021 12:35:09 |
If you have some gash vales you could use them? Clean the faces, place in the valve guides, add glue to the faces. Position your template and then turn the head over so the valves sit on the template whilst the glue sets
Dave |
22/09/2021 12:18:27 |
I’ve gone involute for the clock because I wanted to explore the use of the “rotary Sunderland rack method” as a way to make gears. Dave |
22/09/2021 11:00:41 |
Yes it’s a clock, and no I’m not sure. These are the first gears I’ve ever cut, and I suspect that I should have profile shifted the wheels the opposite way to thin the teeth. Still it’s all learning, and if they are depthed ok then they mesh ok - even if it’s not quite correct… Will do better next time Dave |
22/09/2021 08:08:50 |
Not really. Design pressure angle stays the same - hence the gear can be cut wit the same cutter, and mesh with gears cut with that same cutter. I believe the actual pressure angle where the teeth meet changes, as a result of being at a different point in the curve. Read here: Gear Profile Shift | KHK Gears for an explanation of profile shifting. It is fairly common in industry to match the tooth form to the required result. Edit to add: Introduction to Gears | KHK Gears is a fairly good primer on all things gear related. Dave Edited By Dave S on 22/09/2021 08:10:33 |
22/09/2021 07:20:18 |
The undercut is an unfortunate artefact of the process of making an involute gear. It limits the strength of the root of the tooth, which can be a bit of an issue. Profile shifting just uses a different part of the involute curve, and so can avoid the undercut. It’s trivial to do in practice - using the same rack form cutter you just move it out a bit (simplification but essentially the process) I have made some 12 tooth pinions without undercutting by doing just that and they roll against the 144,96 and 90 tooth gears made with the exact same cutter perfectly. Dave |
Thread: A straight line engine |
21/09/2021 17:50:07 |
The complexity isn’t actually the most off putting thing. Rose engines benefit somewhat from a mechanical reduction in the pattern to the work - especially at watch sizes. That isn’t true for a straight line engine. Still one might turn up, or I might revise my build plans and make one. Dave |
21/09/2021 17:28:38 |
I posted a want to buy for a straight line machine recently. I have thought about building one, but having had discussions with Chris Manning about what it takes to have a successful machine I am reconsidering, hence looking for one. Dave |
20/09/2021 15:30:51 |
What you are describing is using the cutter “vertically” I think. With a standard end mill. what I was envisaging was the cutter “horizontally” more like a slitting saw. so as the blank rolls the gearotic code rolls A and moves Y. I was thinking roll A and move Z This would mean the “stick out” issue of a long thin cutter is now a diameter issue of a thin slitting saw like cutter. I have experience with Gearotic, and knew John quite well. Clumsy Bstard lived 5 mins up the road. Dave
20/09/2021 14:39:54 |
You can always profile shift if you want to avoid undercutting on low number tooth pinions. Dave |
