Member postings for Oldiron
Here is a list of all the postings Oldiron has made in our forums. Click on a thread name to jump to the thread.
Thread: An alternative to parting-off
04/11/2018 12:54:43
Here is an interesting webpage for those interested.
Thread: The right sort of paint!
04/11/2018 12:38:55
Hi Kevin, E-tech heat resistant engine enamel is good. Or in a smaller colour range at car shops is VHT exhaust paints.
regards
looks like Hopper beat me to it
Edited By Oldiron on 04/11/2018 12:39:27
Thread: Double diamond tool
04/11/2018 12:31:38
Hi Cam. Welcome to the forum. I follow your channel. Very interesting. See you on Emma's live show chat sometimes.
regards
Thread: Mini Mill Belt drive conversion
04/11/2018 12:15:36
Hi Alan. I got my belt conversion kit from SPG Tools **LINK**
It was a reasonable price. All kits are made to order so you need to send them all the relevant measurements.
extract from email dated 22/10/15 :-
"Thank you for your order, Will you please send me some sizes. Screw centres from front to middle screws, also centres of front screws, motor shaft diameter, quill diameter below the thread. Depending on the age of the machine we find these dimensions do vary.Regards Brian (office) SPG Tools"
I hope this helps.
regards
Thread: End Mill Sharpening
03/11/2018 12:50:02
Hi Howard. An update to the link for end mill sharpening.
Homeworkshop  Advert ID: 33969
Tools
Details:
Details:
End mill and slot drill re-grinding service offered for a donation to EACH.(East Anglia Children’s Hospice. Action has been approved by them)
Work is on an Alexander T&C grinder.
Shank dia. from 5mm to 16mm or imperial equivalent.
End lips only not O/D
HSS. 5 cutters for £8
Carbide 5 cutters for £15
Slitting saws please phone
You pay the postage.
Terms:
Price: £1.00
Post Only
Contact:
Geoff Josey
Wymondham
NR18
UK
01953548530
email
I hope this helps.
regards
Edited By Oldiron on 03/11/2018 12:50:44
Thread: Old Printer Parts
02/11/2018 11:13:10
Posted by Rod Ashton on 01/11/2018 18:20:10:
Excuse the aside but - Any of you printer guru`s know of a driver source, for an old pen plotter please? Parallel port type
Hi Rod I have used Driverguide for many years and have great results from them. **LINK**
No adds no emails except for one when you join. Joining is free.
Good Luck
regards
01/11/2018 18:16:17
Posted by Steve Crow on 01/11/2018 17:06:34:
Does the chromed mild steel cut ok?
Cheers
Yes it does.
regards
01/11/2018 16:58:58
I also have stripped out many large and small printers for the screws and round bars. I have found that some of the real cheap rods are chromed mild steel. The majority though are stainless. Some magnetic some not. I keep them all as they will come in useful one day. They are all made to a very tight tolerance so handy for many applications.
Ideal for making studding and small parts.
regards
Thread: Dial Gauge Advice
01/11/2018 16:50:23
Posted by Howard Lewis on 01/11/2018 15:14:54:
Lever adaptors to allow a Plunger clock to be used in a bore were made commercially. May still be, if we could find the right place to look.
Try here:- **LINK** There are probably others available.
regards
Thread: Starrett : Manual Video Measuring Systems
01/11/2018 10:46:23
Mmm Not sure if I could justify laying out what could probably be this years income for one of those. But a very nice item.
regards
01/11/2018 10:41:19
Posted by Mick B1 on 31/10/2018 14:35:03:
True, but Baty at least make, or used to, a bellcrank-type finger-lever that clamps onto the plunger sleeve and allows the gauge to work in that situation. Still a bit of a faff compared to a finger-type gauge, though.
I have one dial indicator that is permanently fitted with cranked finger. I find it very useful & easy to read without putting on the optivisor.
I got a box full of these in an auction lot and sold many on Ebay. Still have a few pieces left in that box somewhere I think.
To the original OP, you will not go wrong with both types as they have their own separate uses
regards
Edited By Oldiron on 01/11/2018 10:43:34
Thread: Name plates
29/10/2018 09:35:53
Hi Try the advertiser in the right column. **LINK** Never used them myself but others on this site have. If they cannot do it I imagine they know someone who can.
regards
Thread: Does anyone recognize this grinder ?
27/10/2018 11:46:51
Posted by Andrew Johnston on 26/10/2018 19:04:57:
Posted by Lewis Cobb on 26/10/2018 18:38:35:
Here's a little video my pal sent me and I tossed onto my dropbox - hope it works -
Nope, can't view it and a download failed. sad
Andrew, if you are registered with Drobox you only have to sign in to download the clip. Worked perfectly for me.
I have no idea of the make of the grinder either.
regards
Thread: cutting the bar of a digital calliper
23/10/2018 22:12:49
thumbs up for the fine bladed hacksaw. I have shortened several scales with one.
regards
23/10/2018 22:10:20
Keep an eye on **LINK** There is a chap that advertises there quite often. He does a sharpening service and proceeds go to charity. I think he does only the tips and not the flutes. I have his details somewhere but seem to have misplaced them for now. If I can find them I will post them.
regards
Thread: Cleaning with Parafin?
13/10/2018 19:02:41
Posted by the artfull-codger on 13/10/2018 18:38:20:
Just wondering about petrol being illegal?? I use it for really greasy parts & I use cellulose thinners for de-greasing & cleaning paintbrushes & sprayguns,safe if used properly,I don't let celly thinners near paint of course.
Graham.
Never heard that petrol is illegal to use for cleaning parts in the home shop. ( how could it be stopped) Must be 1000's using it in this country alone.
Probably frowned upon in an industrial setting.
regards
Thread: Warwickshire Event Centre, Leamington Spa
12/10/2018 15:21:56
Going on Saturday as usual
Thread: Parting off - again, sorry
11/10/2018 11:31:52
Could be that you are using much to slow a spindle speed and too fast advancement. I find these tip tools cut much better at higher speeds.
regards
Thread: Forged & Filed
11/10/2018 11:25:36
Posted by Neil Wyatt on 11/10/2018 09:11:08:I was more thinking that he doesn't appear to lift the file for the return stroke, although it could be the sound effects.
To lift or not to lift will always be a debatable subject. When I did my time the instructor always told us " lifting the file and banging it back down was a waste of effort, Just remove all down pressure and draw the file backwards which helps to eject any chips attached to the file" " always finish on a forward stroke." ( no comments pls Whether this was right or wrong I had no idea at the time and still don't so I have followed that routine ever since. The use of a file card at regular intervals is the key to file life as far as I can see. With the advancement of modern methods I have no wish to find out whether a file can be worn out or not by my physical exertions.
regards
Thread: Today's Mystery Object
21/09/2018 16:04:39
If this is a tool post of any description I cannot see how to tighten it in the Tee or compound slot. The body and the T nut part appear to be machined as one piece. Why would anyone place that broken tap where it is ?
regards
Edited By Oldiron on 21/09/2018 16:05:17
