As title
Adam | 07/09/2018 21:01:19 |
70 forum posts 81 photos | This is my first proper lathe. I inherited a Drummond m series from my grandfather as well as a kerry super 8 pillar drill. I restored the Drummond but I could not get on with it. So I sold it and got a Colchester chipmaster from a friend. It was completely covered in crap as it was stored in a barn but it was dry and seemed good underneath...... |
Adam | 07/09/2018 21:37:59 |
70 forum posts 81 photos | How do I add a photo from my photo gallery? |
Oldiron | 07/09/2018 23:05:01 |
1193 forum posts 59 photos | Hi Adam. Just click the camera icon & select a photo from your album. regards |
David Taylor | 07/09/2018 23:30:06 |
![]() 144 forum posts 39 photos | I just looked through your album - wow! What a beauty. |
Adam | 08/09/2018 21:17:13 |
70 forum posts 81 photos | Thanks everyone, I used a different web browser as the camera did not show |
Adam | 08/09/2018 21:19:39 |
This is the lathe in the barn. It was covered in all kinds of grime but felt good on the slides. 3 phase but could not test it but it was a very good friend selling it at a good price so I took it.
Adam | 08/09/2018 21:21:16 |
70 forum posts 81 photos | Also, all the serial numbers all matched and it came with a LOT of tooling (16 Dickson quick change holders) but only one 3 jaw chuck. |
Adam | 08/09/2018 21:23:28 |
70 forum posts 81 photos | It also came with a capstan attatchment which is in full working order. Just a little...…. dirty |
Adam | 08/09/2018 21:25:36 |
70 forum posts 81 photos | I get by with a little help from my friends...…. The buddy I got it from included delivery too. And a couple more mates and we got it into my garage with a but machinery jimmy and some elbow grease. Now to disassemble. |
Adam | 08/09/2018 21:27:32 |
70 forum posts 81 photos | I still could not test it so I figured id just disassemble it and see whats what. Its bloody heavy, reassuringly so. Oh yeah it also came with a fixed, and travelling steady. |
Adam | 08/09/2018 21:29:46 |
70 forum posts 81 photos | I Started by removing the larger components and started with the tailstock. |
Adam | 08/09/2018 21:32:48 |
70 forum posts 81 photos | I removed all the old paint with a wire wheel on angle grinder then used some filler to fill the larger imperfections. Then (after careful masking) painted white enamel. The handwheel and other components were cleaned on a brass wire wheel in the bench grinder.
Adam | 08/09/2018 21:34:03 |
70 forum posts 81 photos | |
Adam | 08/09/2018 21:37:46 |
70 forum posts 81 photos | Next came the carriage gearbox (cant remember the proper name). It was stripped to every last component and cleaned in a large ultrasonic bath. |
Adam | 08/09/2018 21:41:44 |
70 forum posts 81 photos | The part where you engage the power feed was a BA***RD to remove. Thanks to someone on here I got some advice. There is a hidden plug that needs to be removed.
Adam | 08/09/2018 21:43:07 |
70 forum posts 81 photos | Once out I found (much like all the components) it was covered in grease, oil and swarf. This was also thoroughly cleaned in the ultrasonic bath.
Adam | 08/09/2018 21:48:03 |
70 forum posts 81 photos | All painted and reassembled and greased up. Nothing was repaired or replaced. It all felt tight and no real wear.
Adam | 08/09/2018 21:49:45 |
70 forum posts 81 photos | Next I removed the gearbox and made a start on stripping and cleaning it. |
Adam | 08/09/2018 21:51:44 |
70 forum posts 81 photos | The gearbox had clean oil inside and everything engaged well so I did not strip it completely but just clean it up and paint. |
Adam | 08/09/2018 21:54:48 |
Next was the headstock. Again this felt good and the clutch seemed to work so I did not want to disturb. A lot of maskig and a lick of paint was all that was needed. oh and its seriously heavy!!! |
