charadam | 27/02/2015 19:30:17 |
185 forum posts 6 photos | I posted this on the Yahoo user group, but no response as yet.
Can anyone define the crossfeed screw for me in terms of diameter, thread form, pitch, hand and length?
The lathe is Imperial.
I want to replace the screw soon but cannot strip the lathe at the moment.
Thanks in advance,
Charles |
Raymond Hodges | 27/02/2015 20:37:55 |
71 forum posts 1 photos | Hello Charles Try this site maybe they can help www.lathes.co.uk/chipmaster/index.html Good luck Ray Edited By Raymond Hodges on 27/02/2015 20:38:24 |
Neil Wyatt | 27/02/2015 21:13:32 |
![]() 19226 forum posts 749 photos 86 articles | I found a post that says the cross slide screw is a ACME 3/4-5TPI on a Student. Neil |
Tony Ray | 28/02/2015 19:18:52 |
238 forum posts 47 photos | Charles, I can tel you that it's left hand twin start. If you are going to replace the screw you would be advised to change the nut as well. You can get these parts from 600 group but may find Robert Pringle based in Harlow are cheaper but still prepared for a shock.
norman royds 2 | 11/01/2019 18:56:50 |
48 forum posts | I ALL having trouble with my Colchester chipmaster clutch is slipping but I don't think it is the clutch there is a lot end play in the shaft it self and the clutch housing .and there is no information in the manual that I bought from tony Griffiths or in manual that came with it .so is there anybody out with the information that can help me there must be some worn parts or bearing I thought it was the variator but I have changed the oil in variator . thanks in advanced for any information regard nome |
Emgee | 11/01/2019 20:33:28 |
2610 forum posts 312 photos | Charles, have looked at the manual and can only advise part numbers, but there is a choice of Eng or Met and std or anti-backlash nuts. Emgee |
norman royds 2 | 11/01/2019 21:13:46 |
48 forum posts | thankyou I will have a look on yahoo regard norm |
norman royds 2 | 12/01/2019 13:50:09 |
48 forum posts | No look on Yahoo page seems to be out off use .I have tow manual but no technical information I look on ebay and the manual look the same has so back you hope you can help me regards norm |
Pete Rimmer | 12/01/2019 16:18:17 |
1486 forum posts 105 photos | I think the chipmaster is the same as the Bantam, 9/16" diameter 10tpi pitch .200" lead left hand 2 start. I could possibly be able to knock out an EN8DM threaded blank to splice into your screw but I'm really busy right now. They are expensive because of the integral gear which I could also probably hob but if it is the sliding spline type, I have no cutter for the spline. |
