Member postings for Chris Evans 6
Here is a list of all the postings Chris Evans 6 has made in our forums. Click on a thread name to jump to the thread.
Thread: Adcock Shipley Bridgeport motor
16/01/2022 19:03:08
From what I can see in your unloading picture it is a "Varidrive" machine. I have one of these running from a VFD at 230/240 Volts.
Thread: Bearingboys Ltd Excellent Service
15/01/2022 11:39:37
I have used them in the past, always good service.
Thread: Milling collet choices
09/01/2022 09:33:15
I use R8 and Clarkson on my Bridgeport. R8 for light and accurate work and Clarkson ( 2 chucks 5/8" and 1" capacity) for heavier work where there is a risk of the cutter pulling down. It helps having a good number of screwed shank cutters and a cutter grinder to keep the mill fed. If you go the ER route consider a bench mounted fixture for tightening the collet nut, Bridgeport brake's are sometimes poor to stop spindle rotation even in back gear/low speed range.
Thread: J&S 540 grinder
08/01/2022 10:59:56
A Leicestershire company "Andmar" may be able to help.
Thread: Internet Speed ?
05/01/2022 09:18:49
Posted by Nigel McBurney 1 on 04/01/2022 18:54:20:
in my rural area,i have been without BT emails since last friday,got something back this morning,my broadband never reaches more than 1 usually its about zero to .7 OpenReach have just put in some new poles down our rd as there are some new hoses being built,mainly farmers converting any old tin shed and the rules now state that new residentual development has to have fibre line broadband installed,then a cable was fitted but the linesmen said that it could be many months before its up and working,
Living in a rural area I can appreciate you woes. At best my broadband speed is 1.8 and mobile signal very hit and miss. Recent activity by Open Reach means we may get fibre within 5 years. So many websites now use two factor authentication we are really missing out on the city dwellers "Normal" life.
05/01/2022 09:18:49
Thread: UK source for 17/32" ring spanner ?
04/01/2022 19:33:50
Pre-war BSA motorcycles use mainly whitworth sizes with some odd ball A/F including the above mentioned 25/32"
Thread: hello from stafford
04/01/2022 09:40:58
Welcome along Rick, I am more into pre-war bikes and no model making but the forum is great for any engineering questions. Do you have any machinery yet ?
Thread: Warco WM14 - what are these screws for?
03/01/2022 15:30:06
I would try removing one at a time. They may be for workholding during manufacture and could be discarded or modified to sit below the surface. They may be there to keep the holes clean ?
Thread: What tool do I need? I need to measure the radius of a tiny fillet on a 90° edge.
30/12/2021 14:59:28
When |I was working (toolmaker) this was a daily task. Made easy with a shadograph with resolutions from 10 to 1 up to 100 to 1. Where are you located ? There may be a local company willing to let you use their kit or measure for you for a tea fund donation.
Thread: Speed Camera Flashes?
27/12/2021 20:32:59
I got a speed awareness course going 6 MPH over a 30 limit. Fair cop I was speeding, on the course the people running it asked. "How far do you need to travel at 80 MPH instead of 70 MPH to save 10 minutes ?" The answer shocked me, it is 100 miles. I don't say that I now never go over the limit but am more aware and respectful of the limits which means the courses work.
Thread: DRO's and mental agility
22/12/2021 21:20:29
Newall on the lathe an Heidenhein on the mill. Would not want to work without them. Biggest advantage for me is speed and confidence more so on the lathe for ease of setting say the length of a bolt or spindle. Face off zero the axis and set the saddle stop to distance required, no faffing and measuring required.
Thread: Hi all
22/12/2021 08:58:05
Welcome along Neil, the Cowells is a fine machine. I get to Northern Ireland a couple of times a year for the Motorcycle racing and visiting the wife's family.
Thread: Mamod Locomotive Rebuild
20/12/2021 09:11:19
Welcome William, your post prompts the question are Mamod still trading ? They used to be made in Burntwood West Midlands not far from me. I have a Mamod stationery engine that has not steamed for many years. Chris.
Thread: Casting
20/12/2021 09:04:36
Plus 1 for Purbright for the iron castings, only 25 miles from me. Not sure re bronze, never had any done. Last aluminium bronze I had done was by a foundry in Kingswinford West Midlands. Foundry name escapes me I will post it if I remember.
Thread: What do you use for heat treatment?
12/12/2021 09:13:03
I cheat and take my heat treatment to my last employer to run in with their work. They always refuse payment so I put a few £ in the tea kitty.
Thread: Hello form Alton hampshire
11/12/2021 09:40:18
Welcome along Ralph,  I have heard of a bed re-grinder in the Midlands but not had to use one.
Edited By Chris Evans 6 on 11/12/2021 09:41:35
Thread: Hello from Barnsley
11/12/2021 09:36:46
All the best for the square four restoration, I would not like to tackle an old bike rebuild without my lathe and mill. Keep asking questions as you come across problems, the friendly bunch on here will get you sorted.
10/12/2021 08:42:01
Welcome along to the forum Paul from another motorcycle tinkerer. 1929 & 1932 BSA Sloper's keep me entertained, I am a long way from Barnsley to help but good luck with your new machinery. Any questions just ask, someone will know the answer.
Chris.
Thread: New Micrometers
01/12/2021 10:02:39
Posted by Peter Simpson 3 on 01/12/2021 07:46:35:
I realise we all do different model engineering but the talk of measuring to 1/100000" and buying micrometers with heat shield to stop finger temperature affecting the reading is mind blowing. I doubt many engineering companies work to these tolerances.
I've worked in some very high end toolmaking places where we chased the tenths to achieve maybe half a thou overall at best. Only one place was temperature controlled. we all had "Tessa" and "Shardlow" micrometers but day to day standard Mitutoyo stuff was good enough. To this day I prefer to read an imperial depth micrometer rather than a metric one.
