Warco WM14 - what are these screws for?
David Ambrose03/01/2022 15:14:57
55 forum posts
4 photos
Hi,
I am installing a Machine-DRO 3-axis DRO on my Warco WM14 mill. I need to fix the Y-axis reader to the carriage, but there are these two cap screws on the face where I need to fit the bracket, and their heads are proud of the surface. The Machine-DRO user guide shows the holes, but no screws, so there would be no problem fitting the bracket. As far as I can work out, the screws do not do anything, so can be safely removed, but I thought that I would check to see if anyone has any experience of removing them. If I hear nothing, I will phone Warco tomorrow. The equivalent Grizzly manual does not show the screws.
Edited By David Ambrose on 03/01/2022 15:16:00
Chris Evans 603/01/2022 15:30:06
2156 forum posts
I would try removing one at a time. They may be for workholding during manufacture and could be discarded or modified to sit below the surface. They may be there to keep the holes clean ?
David Ambrose03/01/2022 15:34:55
55 forum posts
4 photos
I have just discovered they clamp the X-axis lead screw nut! So I will need to machine the bracket plate, or use spacers. Funny how the Machine-DRO instructions ignore them.
Dalboy03/01/2022 15:36:00
1009 forum posts
305 photos
Looking at the photo is this end the end of the X axis if so could they be there to hold a bracket for the end of the x axis screw. Just thinking as a mechanic.
I see you found out while I was typing
Edited By Derek Lane on 03/01/2022 15:39:26
David Ambrose03/01/2022 15:48:54
55 forum posts
4 photos
Or I could just apply my brain, and shorten the bolts. Sorted!
