Member postings for mark smith 20
Here is a list of all the postings mark smith 20 has made in our forums. Click on a thread name to jump to the thread.
Thread: Alexander Mill
17/03/2017 09:55:35
I think it was Alan who posts as Bentley1930 who was designing one for the FP1, i think he posts on here occasionally.
Edited By mark smith 20 on 17/03/2017 09:55:53
17/03/2017 09:05:58
Hi, theres a thread on the Practical machinist form about someone making one for a Deckel FP1, probably other but having an Alexander myself there are some subtle differences depending on what year the Alexander is from.
Thread: Grinding wheel supplier recommendation
14/03/2017 10:30:00
I have a Mick o` Donnell ruby wheel on my 8 " Kef grinder ,i also have a blue microcrystalline wheel on the other side with quite a fine grit (120). Both work well with minimal edge over heating onHSS. But they are quite pricey and as the original poster says nothing fancy then i would also recommend Abtec which i had on a previous 6" grinder.
Edited By mark smith 20 on 14/03/2017 10:32:58
Thread: EBay Rant!
08/03/2017 11:14:15
Martin, your probably knocking your head against a wall.
My wife went through a similar thing but actually WON as a seller which is quite rare in my experience.
The buyer actually opened a not as described case through ebay for one of those FITBIT wrist things, before he had actually received the item.
He escalated the case within 5 minutes of opening it before my wife even had time to read the case details never mind respond.
She contacted ebay with all the details and the buyer when he realised it wasnt going his way opened a paypal case.
It was a simple case of fraudulent claiming but explaining this to ebay and paypal by providing tracking that he hadnt even received the item yet was extremely frustrating. A blatant  abuse of the ebay money back quarantee scheme.
She won eventually but what should have been a simple process of proof was like talking to a brick.
In your case they are supposed to return the item in the condition you sent it (before refunding the buyer) and if you have proof of the damage you would think the buyers claim would fail . Was the item even covered for insurance when sent back???
Edited By mark smith 20 on 08/03/2017 11:15:47
Edited By mark smith 20 on 08/03/2017 11:17:19
Thread: Southbend
20/02/2017 15:55:49
It could easily be a 13" going by that one photo.
Edited By mark smith 20 on 20/02/2017 15:58:17
Edited By mark smith 20 on 20/02/2017 15:59:08
Thread: Preventing Rust
17/02/2017 11:09:20
camellia oil is extracted from seeds of the tea plant .
Correction: no its not its from Camellia oleifera, also Japonica as Neil suggested previously and also a few others including the tea plant. I would guess that a lot of the commercial grade oils are a mixture of several sourcesindecision
Edited By mark smith 20 on 17/02/2017 11:33:25
Edited By mark smith 20 on 17/02/2017 11:35:52
Thread: Polycarbonate sheet
14/02/2017 14:17:58
Sticky removers wont penetrate the plastic film. I sympathize with you, around 10 years ago i bought a conservatory for self build. After building the dwarf walls , I got waylaid erecting it for 2-3 years and when it came to fitting the polycarbonate roof sheets , the plastic film had deteriorated and would only come off in small pieces. Nothing i tried helped ,took ages to remove it all.sad
Edited By mark smith 20 on 14/02/2017 14:18:49
Edited By mark smith 20 on 14/02/2017 14:19:31
Thread: Quality digital vernier calipers
12/02/2017 15:15:17
Last ones i bought were Tesa Twin Cal Ip67. They seem pretty good. Bought them used but they are in good condition.
Edited By mark smith 20 on 12/02/2017 15:16:27
Thread: Crosslide acme thread
09/02/2017 16:04:19
Yes its dirt cheap in the US if you can get cheap shipping.
Or you can buy in Uk like here  10" length at 86 quid plus vat and shipping for right hand ,couldnt see an option for left hand so thats likely even more. Absolute rip off!
https://www.accu.co.uk/en/533-acme-lead-screws
Edited By mark smith 20 on 09/02/2017 16:08:09
Edited By mark smith 20 on 09/02/2017 16:08:39
09/02/2017 15:50:05
Posted by richardandtracy on 09/02/2017 15:37:17:
Possibly looking as expensive as £20 for 400mm with a flange nut from China. If you search, can probably get a ballscrew & nut for no more than £30. I'm a tight-wad, but it seems not worth machining yourself at these prices.
Richard.
Can you point to 5/8" imperial left hand  acme screws in China. Ive looked and all i see are trapezoidal metric screw being called wrongly acme????
Edited By mark smith 20 on 09/02/2017 15:56:37
Thread: Centec 2 horizontal mill
09/02/2017 14:48:36
Worth taking if its for nothing, would take a lot of cleaning up before you would be able to see the state of all the important parts. Certainly a total strip down job.The broken base is a problem but could be got round by making a false base plate and fixing it on somehow.
Edited By mark smith 20 on 09/02/2017 14:49:12
08/02/2017 14:10:09
16 x 4 is metric trapezoidal thread isnt it??
08/02/2017 11:42:00
It isnt cheap though which is probably the reason Sean wants to make it. For a short length you could probably get away without a steady rest if you go easy and take small cuts. . I did it easily for my Southbend by just making the new threaded section and fixing it to the old part after cutting the old thread off.
Thread: Greetings all!
06/02/2017 12:17:13
Hi James, interesting occupation, i make string instruments and bows for a living. Ive done a few with gold mounts but the cost is bloody high for gold so i mainly stick to silver most of the time.smiley
Thread: Bench Grinder
05/02/2017 00:16:21
I bought an older Kef Slibette 8" off ebay for 20 quid a few years back and its a fantastic grinder, i modified the rests though. It runs for like 15 minutes after you switch it off. Like the one in this photo.
Bloody hell just checked the price of them and they are around 900 euros with VAT.
Edited By mark smith 20 on 05/02/2017 00:22:00
Edited By mark smith 20 on 05/02/2017 00:23:45
Edited By mark smith 20 on 05/02/2017 00:27:59
Thread: Slideway protection
04/02/2017 11:22:49
When the rubber cover on my small warco mini mill fell to bits , i made these up of rubberised kevlar sheet bought off a supplier on ebay ,stitiched on a sewing machine using kevlar thread. Tuff as hell and does the job .
Thread: Alexander 2CG Tool Grinder Questions
02/02/2017 16:44:13
Mr Alexander didnt work for Deckelsmiley he was born in 1866 and worked for Pratt Whitney and Goodyear before setting up on his own in 1896. His relationship with Deckel was as i understand it making/ importing Deckel stuff under license until WWII when that was impossible. After the war he carried on making them (grinders ,toolmaker mill) without license obviously with slight differences to Deckel specs..
Edited By mark smith 20 on 02/02/2017 16:57:11
Thread: advice required
30/01/2017 18:46:40
I painted mine in boxford blue/grey which looks ok in person but very blue in photos for some reason. The original colour on mine was a sort of grey with a greenish bluish tint , and somewhat similar to Rustoleum Mouse grey. If i was doing one again which is very unlikely i would prefer the grey to the blue/grey boxford colour from Paragon paints.
Edited By mark smith 20 on 30/01/2017 18:49:03
Original colour
Edited By mark smith 20 on 30/01/2017 18:53:12
30/01/2017 14:41:12
it is probably Sept 1941 (is that 40 part of the model number?), is that model 413 or 415? My earlier one is 122171 which appears to be end of 1942.
They seem to have been in various shades of grey ,but you could get any colour you wanted if you paid a small surcharge.
Edited By mark smith 20 on 30/01/2017 14:42:25
Thread: Online suppliers of M42 square HSS blanks please?
30/01/2017 12:06:07
I can only find mention of swiftic hss on a new zealand website where its described as Tungsten Moly ,so M2 but not sure about the 260 designation. Strange no company shows up though a few sellers selling swiftic brand cutters etc..
