lathe
john evans 13 | 08/01/2017 14:23:22 |
30 forum posts | I have used a chester conquest machine for 17yrs with no real issues other than replacing a circuitboard. I now find it hard to take reasonable cuts in steel so am considering a replacement. Naturally I have looked at others in the range as the warehouse is close to me. I see nothing I like. My search inevitably takes me to older myfords. I have an opportunity to buy a basic ml10 with few extras. I assume being heavier in construction the machine will be more robust..is that likely to be tbe case? i gain little in capacity but lose variable and higher speed so is it worth buying or should I look elsewhere? I have a separate mill and do not turn large items. Mainly parts for old motorcycles. |
Chris Evans 6 | 08/01/2017 19:27:29 |
![]() 2156 forum posts | I have never used a Myford but the spindle bore always looks restrictive for motorcycle work. You need a 40mm upwards bore for most fork stanchions. |
Neil Wyatt | 08/01/2017 19:36:08 |
![]() 19226 forum posts 749 photos 86 articles | Hello John, Welcome to the forum. I'm not convinced an ML10 will be significantly more capable than your Conquest. If you haven't done so already you might consider the taper roller bearing modification. Another thing to consider is adding a 3-phase motor and variable frequency drive. This link shows how I did this on my Clarke CL300M, which is a very similar machine. I happily run it with a 4" chuck and TCT tooling these days. Neil |
john evans 13 | 08/01/2017 19:38:37 |
30 forum posts | Old bike fork stanchions seldom reach 40mm,35 being an average maximum. Modern are 40 plus. It does not matter though as I would never machine fork legs etc plus my bikes have girder forks. Thanks for the response however. My query surrounds comparison of the conquest lathe with an ml 10. I.e. will I be better off with the myford?
john evans 13 | 08/01/2017 19:49:49 |
30 forum posts | Thanks Neil. Your response re the ml10 mirrors my own opinion. As for the taper mod i suppose you refer to my conquest? If so,my problem is not with the headstock but with the top slide which chatters under load |
Kevin F | 08/01/2017 19:49:54 |
96 forum posts 24 photos | I own a Myford ML10 and I believe it would be a good upgrade compared to the Chester conquest lathe , you'll always get your money back on a Myford if you find it is not to your liking , I know many don't like the Myford lathes but in my opinion they are one of the best lathes for Model engineering . |
john evans 13 | 08/01/2017 20:16:24 |
30 forum posts | Thank you Kevin. I hoped a myford owner would chip in. I agree with you re resale value as the conquezt will not be worth much. My concern is that the myford is only slightly bigger. Has few speeds to select and is heavy. The ml10 does not however sell like the 7. Advantages would be a potentially stiffer slide set up. Better spares but not necessarily cheaper. I would love a southbend but have seen very few within reasonable distance.An atlas is my second choice but the ml 10 mentioned is a good price and in very good order. |
Carl Wilson 4 | 08/01/2017 20:53:00 |
![]() 670 forum posts 53 photos | My brother does a lot of motorcycle work. He has an emcomat that is too small. You want something like a Harrison M250 or similar. It'll hold its value and be easier to use and output any Myford any day. |
Nick Wheeler | 08/01/2017 21:03:32 |
1227 forum posts 101 photos | An ML10 seems a backwards step to me: you'll be spending money to lose the variable speed, large(for the size) spindle bore, bolt on chucks and the ability to move it about on your own. About the only 'improvement' is a longer bed, which may or may not be of any use to you. When I replaced my mini-lathe with a bigger machine, I sold it easily for about 2/3 of what it had cost me over the ten years that I owned it which seems a pretty good deal. |
Carl Wilson 4 | 08/01/2017 21:10:23 |
![]() 670 forum posts 53 photos | A longer bed that is basically the same as a Drummond B type from around the time of the first world war. Just buy a proper one. |
Carl Wilson 4 | 08/01/2017 21:11:26 |
![]() 670 forum posts 53 photos | Ps nothing against Drummond B's, I have two. |
john evans 13 | 08/01/2017 21:31:08 |
30 forum posts | Harrison is too heavy for my shed. I looked at a boxford.Nice machine but again heavy. I need a bench lathe or one with a pedestal . |
Neil Wyatt | 08/01/2017 21:31:57 |
![]() 19226 forum posts 749 photos 86 articles | If your top/compound rest is really worn out rather than out of adjustment, both the base and top part are available as standard spares, as are the feedscrews. The whole schamozzle shouldn't set you back more than £50. Neil |
Carl Wilson 4 | 08/01/2017 21:56:25 |
![]() 670 forum posts 53 photos | Have you considered an Optimum lathe? German purportedly. Were sold in UK by Excel in Coventry. |
Kevin F | 08/01/2017 23:10:21 |
Posted by john evans 13 on 08/01/2017 20:16:24: Thank you Kevin. I hoped a myford owner would chip in. I agree with you re resale value as the conquezt will not be worth much. My concern is that the myford is only slightly bigger. Has few speeds to select and is heavy. The ml10 does not however sell like the 7. Advantages would be a potentially stiffer slide set up. Better spares but not necessarily cheaper. I would love a southbend but have seen very few within reasonable distance.An atlas is my second choice but the ml 10 mentioned is a good price and in very good order.
The ML10 centre height is 3.250" and the distance between centres is 13" ( unless it's the long bed 18" ) so it is slightly smaller than the conquest which has a centre height of 90mm and 350mm between centres , I agree you will miss the flexibility of the variable speed motor at first, I owned a warco lathe ( similar spec to the Chester ) which had variable speed which was a great asset to have but As time has gone by I don't miss it at all , the ML10 I have now is not my first Myford lathe ,I had an ML4 before and the ML10 feels so much more ' capable ' a very sturdy machine for its size . As for the actual physical weight ,I don't have a figure to hand but two adult men can easily handle the lathe ,spares and parts availability is fantastic ,in my opinion I'd go for the ML10 I'm sure you won't be disappointed ,if there's any specific questions just ask . Edited By Kevin F on 08/01/2017 23:10:53 Edited By Kevin F on 08/01/2017 23:12:26 |
Nick Hulme | 09/01/2017 00:06:48 |
750 forum posts 37 photos | As you're not fettling the lathe you have I'm guessing you don't want to modify whatever you get, if that is the case you really can't beat buying something new that comes with a warranty. Don't get me wrong, I have a Myford Super 7 Long Bed that's had more time and money spent on it than would be sensible for most but if I was starting out to buy a lathe today I'd be spending the money on a nice tool-room lathe, preferably an '80s EMCO but some of the better Chinese stuff might do with some fettling,
- Nick Edited By Nick Hulme on 09/01/2017 00:10:02 |
Nick Hulme | 09/01/2017 00:09:04 |
750 forum posts 37 photos | Double Post, Sorry
Edited By Nick Hulme on 09/01/2017 00:09:30 |
Hopper | 09/01/2017 05:44:50 |
![]() 7881 forum posts 397 photos | Posted by john evans 13 on 08/01/2017 14:23:22:
I have used a chester conquest machine for 17yrs with no real issues other than replacing a circuitboard. I now find it hard to take reasonable cuts in steel so am considering a replacement. It seems like if you were happy with the lathe for that long it might be easier to do a bit of maintenance on the existing machine than to buy another, but older, secondhand lathe that may well need much the same sort of fettling. If it no longer takes good cuts, where it once did, there is a reason. Providing the reason is not that the bed is worn out (unlikely in home use) the rest of the reasons are easy enough to fix at home. First suspect would be headstock bearings. As Neil has suggested the taper roller bearing conversion will transform it into a different machine altogether. Do try to get good quality bearings and not cheapie no-name jobs. SKF bearings work well for precision stuff. Second suspect would be gibs on the carriage, cross-slide and top slide need stripping, cleaning out and setting up properly. Also any shims on the anti-lift plates on the carriage probably need tightening up. I would do these simple jobs before I went looking for a used lathe. I just picked up an old Myford ML7 on the cheap. Complete and running. Looked a bit tatty but not too bad. And the bed was good. But get it home and I find it has a missing tooth on the backgear that requires a complete strip down to replace. Plus about ten thou slack in the headstock bearings once the congealed gunge was removed, requiring bearing overhaul and scraping in. Plus a good handfull of small broken knobs, bent cross slide leadscrew, halfnuts jammed full of the swarf of ages and on their last legs, countershaft bearings so worn they have chewed up the countershaft, cracked drive pulley etc etc etc. It will be a good lathe once I have gone over and serviced every nut and bolt. Lathe restoration then becomes a hobby in itself. They are as bad as old motorbikes for eating up your time fiddling about fixing the ravages of time and previous owners. Better the devil you know, I reckon. |
Hopper | 09/01/2017 05:48:09 |
![]() 7881 forum posts 397 photos | Posted by Carl Wilson 4 on 08/01/2017 21:56:25:
Have you considered an Optimum lathe? German purportedly. Were sold in UK by Excel in Coventry. Made in China for a German company . The only one I have personally had anything to do with (6 x 12 micro) was very poorly made. I would not touch one. I've seen Chinese lathes purchased direct from Aliexpress in China that have better qualitiy. |
Carl Wilson 4 | 09/01/2017 06:47:35 |
![]() 670 forum posts 53 photos | That's a shame. Ah well. Caveat Emptor. |
