Grinding wheel supplier recommendation
Alan Waddington 213/03/2017 22:11:45
537 forum posts
88 photos
Just refurbed an 8" Wolf bench grinder and need some wheels for it. Nothing fancy just for general purpose grinding, tickling up of twist drills and HSS tooling etc
Anyone recommend a good online supplier ?
Martin Connelly13/03/2017 23:38:34
2549 forum posts
235 photos
There was a thread recently about CBN wheels from The Toolpost in Didcot. I have one from 5 or 6 years ago that shows no sign of wear. I would advise getting at least one of these for your grinder.
Martin
RobCox14/03/2017 07:29:54
82 forum posts
44 photos
I'll second that recommendation. About 18 months ago I bought a blue wheel and a CBN wheel for my 6" grinder for these guys. Very satisfied with both. The CBN wheel does a nice job on carbide too.
Rob
Michael Cox 114/03/2017 07:54:09
555 forum posts
27 photos
I use a company called Abtec, www.abtec4abrasives.com, for abrasive wheels. They have a great selection of products, good prices and will provide knowledgeable advice if asked.
Brian Oldford14/03/2017 08:32:03
686 forum posts
18 photos
Try PBR Abrasives at Willenhall, No connection.
Robbo14/03/2017 09:16:16
1504 forum posts
142 photos
Can confirm Martin and Rob's recommendation. Knew Mick O'Donnell from woodturning years ago, and the grinding and sharpening items were great.
Now moved on a bit to a more commercial operation. If you can't afford CBN then can recommend the Ruby wheels - have them fitted to 2 grinders, a high speed and a low speed..
Have also used Abtec for wheels for the surface grinder, and satisfied with them.
Chris Evans 614/03/2017 09:25:26
2156 forum posts
Brian, PBR that is a blast from the past. I used to buy wheels for work from them over 20 years ago. Didn't think they where still going.
Andrew Johnston14/03/2017 09:25:47
7061 forum posts
719 photos
+1 for Abtec.
mark smith 2014/03/2017 10:30:00
682 forum posts
337 photos
I have a Mick o` Donnell ruby wheel on my 8 " Kef grinder ,i also have a blue microcrystalline wheel on the other side with quite a fine grit (120). Both work well with minimal edge over heating onHSS. But they are quite pricey and as the original poster says nothing fancy then i would also recommend Abtec which i had on a previous 6" grinder.
Edited By mark smith 20 on 14/03/2017 10:32:58
