Here is a list of all the postings Nick Hulme has made in our forums. Click on a thread name to jump to the thread.
Thread: Holding screw-end end-mills/slot-drills |
24/11/2019 13:42:24 |
Posted by Hillclimber on 18/11/2019 18:34:39:
Until now, I have held end-mill/ slot-drill cutters in ER25 collets. And am aware of the hazard of these being drawn out. This is a hazard only observed by those not using correct assembly techniques and tightening torques for ER collets. |
Thread: aluminium troubles |
24/11/2019 13:27:50 |
Provide cutting and cutter data to save people guessing what you may or may not be doing. |
Thread: Precision Tool Vice Type 2 |
24/11/2019 13:25:58 |
Posted by not done it yet on 20/11/2019 08:46:46:
IMO, the vise should be ‘idiot-proof’. If that means making it 1mm taller, to avoid this potential problem, then so be it. It's an Industry Standard design, the solution is only to allow it's use by Industry Standard Non-Idiots. |
Thread: It's Myford Jim, but not as we know it! |
24/11/2019 13:20:25 |
Posted by Georgineer on 23/11/2019 11:36:14:
Have you told Myford about the problem?
I considered it but what are they going to do, start checking products which they have not bothered to check so far and scrap the rejects or sell them anyway and expect a certain level of returns and for the other users to put up with shoddy products with a "Genuine Myford" sticker on them? |
23/11/2019 01:26:34 |
I bought a 30/12 Fine Feed Tumbler Gear bought from the new Myford Ltd and fitted it to a genuine Nottingham Myford Super 7 with genuine Nottingham Myford change gears and genuine Nottingham Myford idler gears. |
Thread: machine dovetails. |
10/11/2019 17:49:06 |
If there isn't space for a dovetail cutter then it may have been done on a horizontal mill, I'll let you imagine the setup but it's not rocket surgery |
Thread: Tools for Super 7 |
07/11/2019 08:47:50 |
Posted by Howard Lewis on 05/11/2019 16:18:04:
A Super 7 is barely going to be fast or rigid enough to use carbide tips to their maximum. Wait for the howls! I may have a jaundiced view of this opinion owing to my Super 7 being a Long Bed model and having a VFD and 1hp 3 phase motor, but using insert tooling I regularly take 10mm reduction cuts on 30mm stainless bar with blue chips flying. |
Thread: DRO to vertical mill z axis |
17/10/2019 22:25:43 |
DRO or Digital Scale? |
Thread: Curve Cut Problem |
17/10/2019 22:23:17 |
If you add what CAD/CAM/Controller you are using people with relevant experience will be able to comment. |
Thread: At last - no more chattering when parting off! |
09/10/2019 20:21:17 |
Posted by Mark Rand on 07/10/2019 20:34:02:
Just being picky here, but it seemed to me that there was still quite a lot of chatter in the 'tool'. It might have needed a more sturdy 'tool holder'. There was a lot of chatter in the tool, but it's his video........
Thread: Metrication of models |
04/10/2019 17:31:44 |
It's predominantly a case of substituting alternate threads which will work (i.e. not having an over-size major OD which interferes with another aspect of the part) and using a calculator. |
Thread: cutter slippage using ER series collets |
27/09/2019 23:47:06 |
Unlikely to slip if used correctly on a good quality tool shank, read up on what bits should be clean and oil-free when fitting the tool and use the correct torque. |
Thread: M8x1 left hand tap. |
19/09/2019 09:29:31 |
Posted by Pete Savage on 18/09/2019 11:18:10:
he idea was to make phosphor bronze sacrificial anti backlash nuts to try and get the backlash and friction down to help with the fitting of CNC, so an investment in a tool likely to last a few sets sounds good. If going the CNC route go straight to Ball Screws, suitably sized ones for your machine will not break the bank. |
Thread: Myford Bull Wheel Indexing |
17/09/2019 18:06:34 |
That's cute, neat and well executed. |
Thread: Anyone know where I can get hold of 'Gauge Rods' |
09/09/2019 21:47:55 |
I'd just make a mount for a digital gauge on the top slide, measure from a shoulder to a face or face a known length from the shoulder |
Thread: Loctite minefield |
31/08/2019 18:03:13 |
Ask your supplier.
Thread: Travelling Steady |
03/08/2019 09:01:56 |
You can make soft tips for softer materials, try Nylon or Delrin tips. |
Thread: Floor Paint |
02/08/2019 12:29:24 |
Water based hasn't yet matched the durability of solvent or polymer based, when it does you'll know, you'll no longer have to clean bird poop off your new car ASAP lest it strip the paint! :D
Thread: Toyo MD-1 mini drill - drive belts needed |
29/07/2019 16:58:55 |
Posted by Manfred Baer on 22/07/2019 21:06:18:
Brian, Rik, Thanks for your support. Since having some experience with PU belting on spinning wheels (wife) my first choice would be a seamless o-ring. I found that it is quite a task to achieve a (more or less) true running PU joint even for a low rev application like a spinning wheel. Manfred Use V blocks and a straight edge, works perfectly every time for round PU belting and also for bonding O rings from cord. |
Thread: Gibraltar Toolpost |
22/07/2019 19:21:40 |
I have a Long Bed Super 7 and can take deep, accurate cuts on 30mm OD 304 stainless steel without need for a special tool post. |
