Raphael Golez | 02/08/2019 20:29:54 |
167 forum posts 153 photos | Hi everyone, Just wondering what is your own preferred way of using the travelling steady to turn smaller diameter shafts. I'm turning a 12.5 mm aluminium rod to 12 mm x 80 mm. I support the end with a revolving center and the travelling steady. I placed my cutting tool just after the travelling steady so that when turning I would avoid the brass fingers damaging the work. Its a hit and miss as the tool sometimes digs in and damaging the work. I see others on youtube putting the cutting tool ahead of the travelling steady thereby supporting the desired diameter size but they are turning steel which is not affected by the softer brass fingers. If I do this with aluminium would the fingers damaged the turned area? I did not attempt this method so far, I would like your opinion first. Thanks! Sorry for this questions, I know I should do research first but I guess the knowledge here is worth it. |
Mick B1 | 02/08/2019 21:07:40 |
2444 forum posts 139 photos | I'm a bit surprised you bother with a travelling steady - I've used one maybe half-a-dozen times in 40+ years, and only for turning lengths of about 10 diameters or more. Your total depth of cut only needs to be 0,25mm or about 10 thou, and you've only a length of 6 or 7 diameters to turn. 3-jaw chuck plus tailstock running centre should do fine. I'd probably do 2 passes of about 0,2 and 0,05mm, but that's only if the 12mm diameter has a tight tolerance. |
Nick Hulme | 03/08/2019 09:01:56 |
750 forum posts 37 photos | You can make soft tips for softer materials, try Nylon or Delrin tips. |
roy entwistle | 03/08/2019 10:37:57 |
1716 forum posts | Don't forget to lubricate the tips Roy |
Neil Wyatt | 03/08/2019 11:36:35 |
![]() 19226 forum posts 749 photos 86 articles | Posted by RAPHAEL VAL GOLEZ 1 on 02/08/2019 20:29:54:
The tool may be blunt or building up aluminium on the tip, make sure it is sharp and use cutting fluid. Neil |
Ian S C | 03/08/2019 13:08:14 |
![]() 7468 forum posts 230 photos | Cutting fluid/ kerosene/ parafin, or WD 40. Ian S C |
