Adam Harris | 06/09/2014 19:54:34 |
533 forum posts 26 photos | In order to service or replace the motor on a Super 7 (or indeed the belt guard back plate) it is necessary to remove the motor pulley before removing the motor and often the pulley is seized on so badly that judicious use of a standard 3 legged puller (judicious because the edge of the pulley would be damaged easily by the puller's 3 feet) is no good. What I think is needed is to fabricate a type of adjustable plate or square section triangle to fit behind the body of the pulley and to locate the puller feet onto that. Before I go any further, I wonder if anyone else has come up with an elegant solution to deal with this not infrequent problem on old Myford Super 7's...anyone? Edited By Adam Harris on 06/09/2014 20:00:07 Edited By Adam Harris on 06/09/2014 20:00:33 |
Michael Gilligan | 06/09/2014 20:27:12 |
![]() 23121 forum posts 1360 photos | Adam, It doesn't answer your question, but you might find this interesting ... When I removed the motor from the ML7-R, there was no key between the shaft and the pulley: The pulley was only retained by the grub screw; which had obviously been rattling in the [motor shaft] key slot and had bruised it quite badly. That said; it did slide off O.K. Generally ... Your idea sounds good. MichaelG.
Adam Harris | 06/09/2014 20:28:32 |
533 forum posts 26 photos | Or maybe cut some thick plate into a horse shoe shape with an outer diameter a bit greater than the outer pulley and in inner diameter a bit greater than the inner small pulley... |
Adam Harris | 06/09/2014 20:40:37 |
533 forum posts 26 photos | Interesting Michael - certainly testament to the ease with which the pulley can and does often jam onto the shaft. Annoying. I think I am going to cut some 5/16 plate I have lying around with a grinder into such a horse shoe shape tomorrow morning, although I do hate grinder noise from others on a Sunday morning! Edited By Adam Harris on 06/09/2014 20:40:59 |
john fletcher 1 | 06/09/2014 20:49:09 |
893 forum posts | Over the past twenty years I have had reason to remove pulleys from several Myford super seven lathes motors and all have fixed by grub screws, not a key in sight. Once the grub screw is removed, all that is needed is a bit of careful persuasion using two pieces of flat steel or similar.Ted |
Michael Gilligan | 06/09/2014 21:15:12 |
![]() 23121 forum posts 1360 photos | Posted by john fletcher 1 on 06/09/2014 20:49:09:
Over the past twenty years I have had reason to remove pulleys from several Myford super seven lathes motors and all have fixed by grub screws, not a key in sight. Once the grub screw is removed, all that is needed is a bit of careful persuasion using two pieces of flat steel or similar.Ted . Thanks for that info. Ted I had assumed mine was a "Friday afternoon job". ... Sounds like it's actually the infamous "Product Improvement". MichaelG. |
speelwerk | 06/09/2014 21:26:06 |
464 forum posts 2 photos | On the two I have both have a key in the motorshaft that is held in place with a grub screw. Niko. |
Adam Harris | 06/09/2014 21:41:03 |
533 forum posts 26 photos | I also have 2 and both have keys with a grub screw pressing onto it. |
Adam Harris | 06/09/2014 21:42:23 |
533 forum posts 26 photos | Actually I'm not sure that the grub screw presses onto the key , I will have to check that. |
Chris Trice | 07/09/2014 01:47:12 |
![]() 1376 forum posts 10 photos | Ditto. Grub screw onto the key in the shaft. The pulley is a good fit but usually comes off easily with a puller i.e. pulled off the shaft evenly. |
Michael Gilligan | 07/09/2014 07:13:56 |
![]() 23121 forum posts 1360 photos | Posted by Adam Harris on 06/09/2014 21:41:03:
I also have 2 and both have keys with a grub screw pressing onto it. . Yes, that's obviously how it was designed to work. hence my sarcastic reference to "Product Improvement" MichaelG. |
Nicholas Farr | 07/09/2014 07:28:33 |
![]() 3988 forum posts 1799 photos | Hi, I'm not familier with Myford biuld practice, but in industry pulleys held with a grub screw often have one on top of the other whitch helps stop them from working loose. It is like double nutting a bolt/stud, may be worth checking. Regards Nick. |
Chris Trice | 07/09/2014 10:35:39 |
![]() 1376 forum posts 10 photos | It's poor practice to grub screw directly to a shaft. It raises a burr which can make disassembly difficult. The norm is to grubscrew where there's a clearance or provide a flat/groove for the grub screw to contact. The alternative is to provide a pad made of softer material, usual brass or copper, to go under the grub screw. Edited By Chris Trice on 07/09/2014 10:37:53 |
Ian S C | 07/09/2014 12:14:46 |
![]() 7468 forum posts 230 photos | Take the grub screw right out, and check that there is not another grub screw down the hole. Ian S C |
Michael Gilligan | 07/09/2014 13:05:13 |
![]() 23121 forum posts 1360 photos | For info ... [see my earlier post] Here are some pics of the pulley and motor shaft from my recently purchased [secondhand] ML7-R The damage on the motor shaft [and the consequential damage to the bore of the pulley] is obviously down to the absence of a key ... but the scuffs and digs on the pulley suggest that it has been removed before; so I still don't know how it was originally assembled. MichaelG. |
speelwerk | 07/09/2014 14:00:45 |
464 forum posts 2 photos | Michael, as you can see in your pictures the grub screw sits almost on the edge of the key, which is missing in your pictures. When you tighten the screw you have to make sure the key is in the correct place under the grub screw and the pulley is lined-up accurate otherwise the pulley will work loose during use. Tightening the grub screw is much hampered by the belt gard back plate. Niko. Edited By speelwerk on 07/09/2014 14:02:06 |
Ian S C | 07/09/2014 15:32:41 |
OT. On machinery that I'v been assisting in manufacturing (agricultural), we use two grub screws, one over the key, and the other at 90*. Ian S C Edited By Ian S C on 07/09/2014 15:34:40 |
Michael Gilligan | 07/09/2014 15:59:02 |
![]() 23121 forum posts 1360 photos | Posted by speelwerk on 07/09/2014 14:00:45:
Michael, as you can see in your pictures the grub screw sits almost on the edge of the key, which is missing in your pictures. < etc. > . Thanks, Niko Yes, that's what I was pointing out ... What worried me was when Ted [john fletcher 1] indicated that he has seen several like that. ... suggesting that it may have become "standard". MichaelG. Edited By Michael Gilligan on 07/09/2014 16:00:38 |
speelwerk | 07/09/2014 18:11:45 |
464 forum posts 2 photos | As far as I know they all should have a key held in place by the grub screw, but as Ian S C has pointed out placing it on the edge is not how it should be done and I can understand they get missing over time. You can improve it a little by rounding the underside of the key so you can push it further in the key way of the shaft. Niko. |
Chris Trice | 07/09/2014 18:23:51 |
![]() 1376 forum posts 10 photos | In my opinion, that's been butchered by a previous owner who lost the key. I'd clean the shaft up with a file to lose the burrs and and then look at getting a replacement key. It would NOT have left Myford like that. |
