polishing spindle taper threads
clogs01/09/2014 15:44:53
630 forum posts
12 photos
Hi out there......
Decided to treat myself to a 30mm dia polishing spindle.....
I have the shaft and bearings and a good friend just donated a 3hp, 3phase motor....
so need to make the tapered threads, any idea's or just taper the shaft and
cut the threads by hand...drudgery.....??
many thanks Frank in France...
JasonB01/09/2014 18:23:53
Was discussed a while ago in this thread
jacques maurel01/09/2014 21:54:50
84 forum posts
20 photos
Look at this video:http://www.youtube.com/watch?v=I57FCsvUajg
John Haine01/09/2014 23:09:10
5563 forum posts
322 photos
Convert your lathe to cnc, then it's a doddle....
(ducks the brickbats...)
_Paul_01/09/2014 23:29:09
543 forum posts
31 photos
This youtube video shows "Doubleboost" making a taper spindle
_Paul_02/09/2014 01:56:35
543 forum posts
31 photos
And part two.
clogs02/09/2014 08:33:54
630 forum posts
12 photos
HI again,
I did try the search function on the forum, sorry I wasted ur time......
Very pleased with the results tho.......quite liked the thread cutting arrangement on the u tube video....
yes I know I'm sad...hahaha...
thanks again..Frank in France........just started the learning curve......
Douglas Johnston02/09/2014 09:15:16
814 forum posts
36 photos
What a wonderful video, I loved the accent and the use of descriptive language when things went wrong at the end.
Doug
Nick_G02/09/2014 11:39:23
1808 forum posts
744 photos
Posted by Douglas Johnston on 02/09/2014 09:15:16:
Doug
That was quite tame for him.! smiley
Nick
Jon Gibbs02/09/2014 12:23:46
750 forum posts
The thread Jason linked to was started by me.
I've since managed to turn a pretty reasonable pigtail mandrel using a neat little gizmo from a Hemingway Kit ...
It's made it an expensive and time consuming solution but it's very satisfying when you eventually get there.
I turned the taper and cut the thread with the same effective tailstock offset (approx 8mm) but to get a steep enough taper it was only possible to cut it on a short section of stock which was then screwed onto a mandrel with a threaded nose.
I'll try to post some pics.
Jon
