I would like to make a 2mt-1.5"x8tpi adaptor.
John Bromley | 16/08/2014 17:23:59 |
84 forum posts | I took delivery of my new nose mount ER32 collet chuck and collets this morning. I can see these will be a great addition to my tool box. I know 2MT ER chucks can be purchased but I thought it may be nice to make my own. A 2MT to 1.5"x8tpi adaptor will allow me to use the chuck in the tailstock. Is this possible on a Metric Boxford lathe? I have a full set of Metric change wheels. I guess, If it is at all possible, I will need some conversion gears? John |
JohnF | 16/08/2014 17:36:52 |
![]() 1243 forum posts 202 photos | John, I don't have all the info you need but the answer is I am sure yes, however you will need a 127 or possible a 63 tooth gear to make the reverse conversion to an imperial thread. What model is your lathe? I recently purchased a metric boxford but do not have it running yet, I do have the full instructions so will have a look at what's recommended and either post the info or pm you. John PS mine is an 11-30 lathe Edited By JohnF on 16/08/2014 17:38:24 |
John Bromley | 16/08/2014 17:50:06 |
84 forum posts | Hi JohnF, It's a 5" Boxford CUD MKIII. It would be nice to have the option to cut imperial threads. For smaller stuff I will carry on as normal with taps and dies. John
Edited By John Bromley on 16/08/2014 17:50:28 |
Bob Brown 1 | 16/08/2014 18:15:02 |
![]() 1022 forum posts 127 photos | try this Changewheels and English/metric and metric/English conversions Metric Threading Lathes with a 3 mm pitch leadscrew and changewheels for screwcutting (i.e. without a screwcutting gearbox): were supplied with the following gears as standard. *16, 24, 28, 30, 36, 40, 44, 48, 52, 56, 60, *80, *72/18 compound, *54/18 compound, *80 idler (with boss) "English" threading Lathes with a screwcutting gearbox had a standard ex-factory drive train consisting of: 20t, 40t, 56t and an 80t idler. To convert this gearbox to cut Metric threads the following gears are needed: 24, 26, 28, 32, 36, 44, 48, 127/100 compound
Bazyle | 16/08/2014 22:02:11 |
![]() 6956 forum posts 229 photos | Even without the 127 ger you may be able to find a combination of gears that gives a close enough approximation. There are several programs around the web that work out the options. |
Les Jones 1 | 17/08/2014 08:40:21 |
2292 forum posts 159 photos | Hi John, Les. |
Brian Wood | 18/08/2014 09:33:51 |
2742 forum posts 39 photos | Hello John, Your question seems to have run into the sand. Just out of interest I tried the links listed by Les Jones above; one was no longer accessible and the other was (to me at least) incomprehensible. I don't know what change wheels you have available but I can offer two practical gearing arrangements that will do what you want. I don't claim authorship, these figures come straight out of Martin Cleeve's excellent book 'Screw cutting in the lathe' Workshop Practice Series #3 They are:- Stud gear 50----Idler----40=55------65 as screw gear (the = sign shows the gears linked on the same intermediate stud) That will be accurate to -1 part in 1650 The alternative arrangement is Stud gear 38---idler-----40=50-------45 as screw gear. This is accurate to -1 part in 380 In both examples, screw gear is the input to the gearbox. Both will be more than sufficient to cut an 8tpi thread for your job to decent accuracy. They require the gearbox to be set to 3 mm pitch to match your lead screw pitch, in effect simulating a non-gearbox machine, and the usual caveat applies to keep the clasp nuts closed throughoit the whole process, beginning to end. I hope that helps you Regards Brian
Edited By Brian Wood on 18/08/2014 09:45:12 |
Michael Gilligan | 18/08/2014 09:55:25 |
![]() 23121 forum posts 1360 photos | Posted by Brian Wood on 18/08/2014 09:33:51:
Just out of interest I tried the links listed by Les Jones above; one was no longer accessible and the other was (to me at least) incomprehensible. . Brian, Maybe a temporary glitch ? ... Links appear to work O.K. MichaelG. |
Brian Wood | 18/08/2014 10:34:31 |
2742 forum posts 39 photos | Hello Michael, I have found in the past that some of the magic links for information in this sort of category is often difficult or clanky to follow even when they work. I like to understand the logic which was why I went to the book for these answers. I think the OP just wanted a simple answer to get his job done this time, he can pursue the links later for the future. Regards Brian |
John Bromley | 18/08/2014 21:27:45 |
84 forum posts | Thanks for the input chaps, I tried the nthreadsp.exe program and found it very easy to get on with. Sadly the change wheels on my CUD will only go in certain places, the only gears I can compound are the ones Boxford deem necessary to cut Metric threads, the 54/18 and 72/18 pairs. The rest are designed to be mounted individually on keyed mandrels, either in the stud gear or lead screw positions. Therefore I intend to make a complete 2MT Collet chuck. The closing nut thread on an ER chuck being 40x1.5mm will be easy with a 3mm lead screw, as I can engage the half nuts at any position. Many thanks again. John
Nick_G | 18/08/2014 21:48:41 |
![]() 1808 forum posts 744 photos | . May also be handy info :- **LINK**
Nick |
_Paul_ | 18/08/2014 22:05:06 |
![]() 543 forum posts 31 photos | For £14 you could buy one 2MT Chuck adaptor I have a couple of them and they are accurate and quite nicely finished. Paul |
