Chris Veitch | 10/08/2014 20:22:06 |
14 forum posts | I'm hoping to change one of the standard Aluminum Oxide wheels on my bog-standard B&Q bench grinder for a Silicon Carbide wheel for grinding carbide tools. However the originals are 150 x 16mm on a 1/2" spindle whereas the only Silicon Carbide I can find are 150 x 20mm, although there's plenty of room within the housing for a thicker wheel. Are there any risks associated in substituting a larger wheel of this size? (Or any other advice on the subject for that matter) Regards, Chris |
Ian P | 10/08/2014 20:29:38 |
![]() 2747 forum posts 123 photos | Sticking my neck out here..... but not a lot more expensive is to go for a diamond grit wheel. The difference between diamond and green grit is the same as chalk and cheese! Diamond even on a metal hub is probably going to be lighter than solid grit. Ian P |
donkey | 10/08/2014 20:33:16 |
![]() 85 forum posts 5 photos | All good as long as you get the full nut on the shaft. Brian
jason udall | 10/08/2014 20:52:15 |
2032 forum posts 41 photos | Apart from the usual safety advice re. hanging a new wheel. Green grit wheels "shed"more than uusual. .its part of how they work... So are particularly dusty.. Bonded diamond wheels (for carbide) cut better and cleaner. Don't need truing (can't be trued, so get the bushing right).. I would still ring a diamond wheel but then though I have seen the result of a wheel bursting I have never heard of a diamond wheel bursting... . |
stan pearson 1 | 10/08/2014 22:35:39 |
![]() 135 forum posts 2 photos | Chris The only things to look out for are Speed rating on wheel is same or lower then grinder, this is more a problem with larger diameter. Make sure you put paper packing's ether side of washers don't over tighten and make sure of a full nut. Make sure the rest is no more than 1/16" from stone. You might have to trim the new stone as to balance them. Stan |
Eric Cox | 11/08/2014 08:59:05 |
![]() 557 forum posts 38 photos | "Speed rating on wheel is same or lower then grinder". Don't you mean the speed rating of the wheel has to be the same or higher than the grinder?. |
stan pearson 1 | 11/08/2014 22:11:19 |
![]() 135 forum posts 2 photos | Sorry Eric Just trying to catch you out ! . Yes speed on wheel same or higher than machine. Stan |
