HSS cutting speed calculation
From Practical Engineer part 1
GoCreate10/08/2014 07:12:28
387 forum posts
119 photos
I was reading through Practical Engineer part 1 article on this forum  regarding cutting speeds but I am a bit confused.
The article states:
1" x 375 = 375 RPM for steel
1/2" x 375 = 188 RPM for steel
1/8" x 375 = 47 RPM for steel
What am I missing?
Nigel
Edited By tractionengine42 on 10/08/2014 07:16:13
JasonB10/08/2014 07:45:30
Seems it should say divide 375 by cutter dia
375 / 1 = 375rpm
375 / 0.5 = 750rpm
375 / 0.125 = 3000rpm
Link to article if anyone else can come up with an explanation
J
GoCreate10/08/2014 08:01:41
387 forum posts
119 photos
Thanks Jason
That makes sense now and useful to know.
The article needs a revision.
Nigel
Michael Gilligan10/08/2014 08:31:29
23121 forum posts
1360 photos
Jason,
You are obviously correct, regarding the error in the formula
Mistakes like this are easily made when an author is describing a "convenient rule of thumb" that has been stored away in his subconcious: The underlying theory gets skipped-over, and the error is not noticed.
I know that MTM runs as a "lean" operation, but this is a perfect example of material that needed "peer review" before publication,
There is an insight to the origins of David's rule, in the opening line: "Referring to a chart of cutting speeds, a 1in. HSS cutter in mild steel requires a speed of 382 RPM. For practical purposes, this can be taken as 375 RPM."
Why would we use 375 as a "practical" approximation for 382 ?
... Because 375 is the decimal for 3/8 ... which will relate to some other convenient rule.
[Well, that's my explanation ... others may differ]
Edited By Michael Gilligan on 10/08/2014 08:32:44
JasonB10/08/2014 10:20:10
Yes I think you are right with the reason to use 375 Michael, maybe for the metrically minded beginner a figure of 400 would be easier to work with when using finger and thumb as most of the older MEs will know in their heads what the various figures in that decimal sequence are off the top of their heads.
Also agree that proof reading is not enough, you need someone who understands whats being written.
J
jason udall10/08/2014 11:05:59
2032 forum posts
41 photos
I had cause to right a spreadsheet to calculate cycle times for estimating ( quoting) jobs for a machine shop...
Firstly my "estimate"..were within 2% of final optimised and leaned on cycle times some timemore sometimes high..
This took in ,material machinability, cermet ceramic, carbide, bcnt hss or what ever tooling.
Ok
So for a laff, I compared my childhood 10, 000 rpm / drill diameter (mm). Which I worked out for myself also worked for outside dia.
Again for hss and machinability 100% this matched to about 1/2 a percent.
Now to the real world...does YOUR lathe have constant surface speed?..variable to a tenth of a rpm?...
No , you will have a selection of speeds and at best steps of 100-200 rpm...
In short rules of thumb can be very helpful
I for one labelled my drill stand in rpm as well as diameter. .colour codeing sufficed. .
JasonB10/08/2014 13:04:15
I can get variable to within 2rpm if I'm bothered smiley
Neil Wyatt14/08/2014 11:43:42
19226 forum posts
749 photos
86 articles
I think Jason was correct so I've changed 'multiply' to 'divide'.
I'm surprised it took five years for that to be spotted, the article has well over 8,000 views!
JasonB14/08/2014 12:22:10
Thats 7999 people having a job getting a good finishsmile p
Bazyle14/08/2014 13:21:58
6956 forum posts
229 photos
Hopefully most people latched on to the one figure for 1" and work it out. They do say you should keep your brain active so chuck away the tables and graphs and work it out each time from that one figure.
Didn't we have another thread on this a few weeks ago (starting with milling cutter speed) pointing out that old and hobbyist values were way out compared with both theory and industrial production rate practice.
Michael Gilligan14/08/2014 13:39:51
23121 forum posts
1360 photos
Posted by Neil Wyatt on 14/08/2014 11:43:42:
Nice to see that stated for the record, Neil
[ = version control ]
... I was beginning to think I was dreaming.
JasonB14/08/2014 13:44:55
Neil, just had a look and it will require a bit more than changing multipy to divide, try this out for a 0.5" cutter which may be a bit slow
"First, divide the cutter diameter in inches by 375."
Needs to read
"First divide 375 by the cutter diameter in inches"
J
