D1-3 compatibility
CamLock, or is there an alternative ? ...
Michael Gilligan06/08/2014 10:57:34
23121 forum posts
1360 photos
Can anyone please tell me the most compact lathe which would accept a D1-3 chuck? ... either a proper CamLock fitting, or is there an alternative that keeps the big tapered nose, but replaces the lock-pins with bolts ??
Thanks
Bob Brown 106/08/2014 11:07:43
1022 forum posts
127 photos
I doubt there are any "compact" lathes that have a D1-3 headstock. What are you trying to achieve?
Nick_G06/08/2014 11:15:22
1808 forum posts
744 photos
I know the Harrison M250 has a D1-3 headstock and this range of Boxfords does **LINK**
I suppose it depends upon your definition of 'compact'.? I have one of those Boxfords which for model engineering could not be considered compact. But a friend of mine who runs a machine shop considers it to be a baby lathe.
Nick
John Stevenson06/08/2014 11:43:24
5068 forum posts
chipmaster ?
JasonB06/08/2014 11:52:37
The 7 & 8 series Emco lathes have a tapered nose but use studs and nuts rather than cams if its the short taper fitting you are after.
Prazimat also has the short taper but a keyhole type flange which just needs the nuts nipping up
Edited By JasonB on 06/08/2014 11:56:29
Michael Gilligan06/08/2014 11:55:33
23121 forum posts
1360 photos
Posted by Bob Brown 1 on 06/08/2014 11:07:43:
Bob,
What I am trying to achieve, is the use of a Burnerd MultiSze Collet Chuch [which I already own] in the small space which I have available.
If I had the space, I would probably just buy a Chipmaster, or a Kerry [both of which I have used and liked], but I do not have the space, and I only need a small "working envelope" ... i.e. I don't want, or need a big machine, but I do want to use this chuck.
P.S. ... I may consider buying just a headstock, and building a "Bitza"
Michael Gilligan06/08/2014 11:57:12
23121 forum posts
1360 photos
Posted by John Stevenson on 06/08/2014 11:43:24:
chipmaster ?
John,
That would probably be my first choice, but I don't have the space.
Thanks
Michael Gilligan06/08/2014 11:58:36
23121 forum posts
1360 photos
Posted by JasonB on 06/08/2014 11:52:37:
Thanks, Jason
I will investigate.
JasonB06/08/2014 11:59:43
Just saw your other post, its a different taper so no use to you
Michael Gilligan06/08/2014 12:04:10
23121 forum posts
1360 photos
Posted by Nick_G on 06/08/2014 11:15:22:
Nick
Thanks, Nick
I think I've covered "compact" in my reply to Bob. ... If it would just clear the Chuck body, and take [say] 12" between the face of the collet and a tailstock centre; that would be plenty big enough.
MichaelG. ... [just looking for inspiration]
Michael Gilligan06/08/2014 12:05:05
23121 forum posts
1360 photos
Posted by JasonB on 06/08/2014 11:59:43:
Thanks anyway.
Bob Brown 106/08/2014 12:20:00
1022 forum posts
127 photos
I think you best bet may be to make up an adapter plate that once you remove the locking pins allows the chuck to be mounted/bolted on one of the compact lathe back plates, blanks are cheap enough.
Details of the D3-1 mount is here **LINK**
Bob
Edited By Bob Brown 1 on 06/08/2014 12:40:01
Michael Gilligan06/08/2014 13:06:39
23121 forum posts
1360 photos
Sorry, Bob, but that is not what I want.
I want a proper headstock spindle in big bearings, that is made to the appropriate level of precision.
Bob Brown 106/08/2014 13:11:02
1022 forum posts
127 photos
How much space are we talking about?
John Stevenson06/08/2014 13:11:40
5068 forum posts
Posted by Michael Gilligan on 06/08/2014 11:55:33:
Bob,
Surely a bit like finding a crutch in the gutter and breaking your leg so as to make full use of it ?
Old School06/08/2014 13:12:45
426 forum posts
40 photos
Myford 254 but not really a compact
JasonB06/08/2014 13:15:19
A Bantam probably has a slightly smaller footprint than a chipmaster as the stand goes straight down rather than flaring out
Michael Gilligan06/08/2014 13:20:19
23121 forum posts
1360 photos
Posted by Michael Gilligan on 06/08/2014 10:57:34:
Bob,
Space is at an absolute premium... which is why I specifically asked regarding "the most compact lathe which would accept a D1-3 chuck"
This chuck has lain unused for over twenty years and [prompted by my discussions with Nick, on another thread], I have finally decided to find a way of using it.
Nick_G06/08/2014 13:36:05
1808 forum posts
744 photos
Posted by Michael Gilligan on 06/08/2014 13:20:19:
I get the blame for everything.!!!! devil
Why should here be any different.? cheeky
Nick winkwinkwink
Michael Gilligan06/08/2014 13:41:49
23121 forum posts
1360 photos
Posted by John Stevenson on 06/08/2014 13:11:40
Quite possibly, John
... or maybe like making a Buell because you had a Harley Davidson engine available?
[feel free to subsitute other engine/frame combinations according to taste]
