Small pillar / bench drill for model making
Recommendations?
Stevo27/07/2014 11:40:47
68 forum posts
24 photos
Hi all,
I'm looking for a small bench dril ( I have a much bigger Axminster Pillar drill) for model making, say up to 5mm diameter. I've a small X-Y table (proxxon) that will go on to it.
Anyone have any recommendations? I see Axminster do one, but for that price and a wee bit extra I could buy a mill/drill all complete!!
Thanks in advance.
Steve
Michael Gilligan27/07/2014 12:09:40
23121 forum posts
1360 photos
Steve,
Look out for one of these [but prefereably in original condition]
Mine has a rectangular table [plain, not tee-slotted], and a balanced 3-phase motor.
Short of spending an unrealistic amount of money, I don't think you would find anything better built.
Roderick Jenkins27/07/2014 12:10:38
2376 forum posts
800 photos
Steve,
I've used one of these Proxxon drills. It is accurate and nice to use but there isn't a vast amount of headroom, especially if you put an XY table on it. George Thomas' Univesal Pillar Tool makes an excellent precison drill, here's mine:
HTH
Rod
Edited By Roderick Jenkins on 27/07/2014 12:11:30
Pete Gilbert 127/07/2014 13:08:56
33 forum posts
10 photos
Screwfix currently have a budget one at £70 inc vat
Clicky
Whats more, there's one on Ebay for £64!!
Clicky
Gordon W27/07/2014 13:36:47
2011 forum posts
I bought one similar to the above, about half that price, from a big DIY shop. It was ex-display and I had to sign a disclaimer because the instructions were missing. I bought it for the motor and switch. When I had a good look at home it was a bit sloppy at table and head, the column was undersize, also notable flex at the table. A piece of tube for the column was found by luck, and the table braced underneath, this gave a vast improvement at little cost. I use it every day in my "little w/shop"
Michael Gilligan27/07/2014 15:42:48
23121 forum posts
1360 photos
Whilst searching for [and failing to find] anything of a quality comparable to J&S that I mentioned in my first post; I happened across this delightful little "sensitive drilling table" ... What a brilliant idea !!
Roderick Jenkins27/07/2014 16:11:29
2376 forum posts
800 photos
I would be cautious about that budget drill. The Naerok in my picture was bought originally for woodworking duties. Fine for that but there was always too much slop in the quill for model engineering. It has now gone (to a woodworker) and been replaced. You may be lucky but, as is mentioned elsewhere at the moment, the quality control is likely to be rudimentary. You need a good quill/spindle and chuck on a small high speed drill.
Rod
Pete Gilbert 127/07/2014 16:17:41
33 forum posts
10 photos
Posted by Michael Gilligan on 27/07/2014 15:42:48:
Expensive as a hobby tool, but yes, very neat.
We have a small 'tapping drill' type stand at work that has the same action as that for the table, and a double cone drive for the chuck. It releases the drive as the table rises and the tap meets a set depth then drives the opposite way to screw the tap back out of the new thread as the table is lowered.
Edited By Pete Gilbert 1 on 27/07/2014 16:21:05
Edited By Pete Gilbert 1 on 27/07/2014 16:21:48
Oompa Lumpa27/07/2014 20:41:08
888 forum posts
36 photos
Rod, please, leave it out with the drill head for the UPT. I can see me losing another couple of days out of my life while I build the attachment - like I need it!
John Moore has a really nice High Speed drill that I covet, maybe he will butt in and show a few pics. Lovely thing, magnetic table too......
graham.
Roderick Jenkins27/07/2014 21:25:37
2376 forum posts
800 photos
Sorry devil
Rod
Roderick Jenkins27/07/2014 21:34:01
2376 forum posts
800 photos
Many years ago we bought one of these at work - we used it to drill holes with diamond drills in ceramic substrates. Very,very nice machines, I've no idea what they cost.
Rod
Michael Gilligan27/07/2014 22:04:35
23121 forum posts
1360 photos
Posted by Roderick Jenkins on 27/07/2014 21:34:01:
Rod
Rod,
There's a good write up about the Cameron, here.
Michael Gilligan28/07/2014 11:29:56
23121 forum posts
1360 photos
Thanks for posting the picture of the Meddings, John
... I knew there was another one comparable with the J&S, but couldn't remember the name.
J&S is also cast iron [except for the Aluminium belt guard], but is quite thin-walled, so probably lighter in weight. [H&S would scowl, but I can move it quite comfortably on my own.]
Bazyle28/07/2014 12:41:22
6956 forum posts
229 photos
Pollard Corona is another make. Not sure which part of the name is the mfr and which the type.
Edited By Bazyle on 28/07/2014 12:44:59
Michael Gilligan28/07/2014 13:13:57
23121 forum posts
1360 photos
Looks interesting, Bazyle
For info. Frederick Pollard
