Motor for tailstock.
Chris Denton08/07/2014 20:07:19
275 forum posts
Are there any companies that sell motors for fitting to a tailstock for drilling etc?
Something like a motor with speed control via a phase inverter, with travel stops etc.
Fairly easy to make, but it'd be worth seeing if there's a ready made option.
Ady108/07/2014 20:25:03
6137 forum posts
893 photos
Seen plenty of mills/drills on the cross slide, never seen one on a tailstock though. It's primary function is for workholding and it can double up as a stationary drill
Chris Denton08/07/2014 20:28:34
275 forum posts
I meant to just move the tailstock barrel in and out rather than rotate!
my carpel tunnel syndrome makes turning the handle a pain!
Ady108/07/2014 20:30:25
6137 forum posts
893 photos
A power tailstock!
(Never seen one, sorry)
JasonB08/07/2014 20:31:58
Have a look at the various lever feed conversions which will make it easy to move the barrel in and out especially useful when peck drilling deep holes
There are also a few designs that link the carrage to the tailstock and drag it along the bed
Oompa Lumpa08/07/2014 21:12:12
888 forum posts
36 photos
Posted by Ady1 on 08/07/2014 20:30:25:
A power tailstock!
What a cracking idea!
graham.
FMES08/07/2014 21:16:43
608 forum posts
I would have thought that some of the Dividing Head stepper drives that some of the guys on here have developed would be most suitable for a power tailstock.
Les Jones 108/07/2014 21:30:05
2292 forum posts
159 photos
Hi Chris,
I would think that a DC motor (EG windscreen wiper) would be better than a stepper as it would be an advantage to provide torque limiting as well as speed control to reduce the risk of breaking smaller drills. I cannot think of an easy way to do this with a stepper motor.
Les.
Ady108/07/2014 21:30:09
6137 forum posts
893 photos
Heres one from 1942
elanman08/07/2014 21:37:05
47 forum posts
4 photos
Chris,
MEW no 110 has an article on the very subject.
Cheers
Chris Denton08/07/2014 21:38:29
275 forum posts
An electric drill provides (almost) everything you would need - speed control, reverse, etc.
You'd just need to wire up some limit switches.
Ady108/07/2014 21:42:48
6137 forum posts
893 photos
The disadvantage of a lever is it would make a tuff job harder to do
There have been some bigger-drill-bit jobs when the standard screw drive has been a godsend for me because it gives you a good level of control and a high drill pressure at the same time
Horses for courses I suppose
Edited By Ady1 on 08/07/2014 21:46:16
Ady108/07/2014 22:04:34
6137 forum posts
893 photos
Some of the battery powered drills have all these things plus an integral clutch so you could limit the drill bit pressure
Maybe a drill powered tailstock drive would be the most unobtrusive mod
A gearcog on the back of the tailstock, powered by a wormdrive and the electric drill can fit on one end
The inner part of the gearcog has a thread which fits the tailstock spindle thread to drive it in and out
You could make your own wormcog (instead of a gearcog) from a 12mm tap and an aluminum disc
Use a bit of 12mm threaded bar from B+Q as a wormdrive spindle
Edited By Ady1 on 08/07/2014 22:15:48
Chris Denton08/07/2014 22:19:32
275 forum posts
Good idea.
The easiest way would be to just put a socket in the drill which fits onto the nut that holds the hand wheel on.
I'm thinking more for something automatic though, something that I can turn on and leave to drill and reverse!
Edited By Chris Denton on 08/07/2014 22:19:51
Chris Trice08/07/2014 23:04:37
1376 forum posts
10 photos
I wonder if the loss of "feel" is going to result in a few broken drill bits. I've got a lever feed on my tailstock and love it. Makes gentle pecking on deep holes a delight.
Neil Lickfold09/07/2014 11:30:34
1025 forum posts
204 photos
Power feed tailstocks etc, in my experience, is only good for processes that do not require pecking, like a roller box or a gundrill, those sorts of things.
JasonB09/07/2014 12:58:13
You would also need a motor that stops quickly to avoid ejecting the chucksmile o
Neil Wyatt09/07/2014 13:15:32
19226 forum posts
749 photos
86 articles
Alternatively look at the postings here by John Stevenson - his design combines a lever feed with ertaining eth screw feed:
An advantage of a powered spindle in the rear tailstock is twofold - the speeds of head and tailstock add together, and as they contra-rotate it's more reliable for drilling long, straight holes as there is no 'preferred direction'*.
*Often seen in nature, when a plant grows or a simple creature swims in a helix - the overall direction of movement tends towards a straight line, whilst if they tried to go in a direct line they would probably veer off course. Presumably the same applies to arrows (but not bullets, where rotation is much faster and the effect is gyroscopic)
