Which cutter(s) to use?
Ed Duffner | 20/05/2014 18:33:57 |
863 forum posts 104 photos | Hi guys, Title should have read Circular I'm now making two off MS plates to house the bearings for my lathe headstock. The only method I have to achieve this is to clamp a plate to my rotary table and use and end mill to progress down to 16mm and almost out to full diameter. I then creep outward on the final interference diameter for the bearing outer. This creates a circular slot because the centre section is the only way I can bolt the plate to the RT. The plates are 20mm thick and I'm cutting down to a shoulder 16mm deep for the bearing to pull in against. I've done one plate already and my 8mm, 4 flute end mill is getting rather blunt. At the moment I don't have a cutter-grinder. Being a relative beginner in machining I was wondering would this be better done using a 2 flute slot drill or roughing mill and finish with a 4 flute end mill? Cheers,
Edited By Ed Duffner on 20/05/2014 18:35:05 |
Thor 🇳🇴 | 20/05/2014 18:41:25 |
![]() 1766 forum posts 46 photos | Hi Ed, if your initial cut is a circular slot I would use a slot drill (2 flute). If making the slot wider an end mill might be better. Your cutters going blunt when milling steel is something I have experienced too, there can be several causes. Either grind/sharpern the milling cutters or get new ones. Thor |
Ed Duffner | 20/05/2014 18:48:54 |
863 forum posts 104 photos | Thanks Thor, yeah I'm thinking about getting another cutter hence the question about which might be best for slot work. If it was a straight slot I'd probably go for a 2 flute slot drill, but I was unsure if a circular slot required a different approach. |
JasonB | 20/05/2014 19:43:39 |
![]() 25215 forum posts 3105 photos 1 articles | How big is the plate? can you do it in the lathe its basically a similar method to Trepanning where we have had a couple of recent threads. Ignor this if the lathe is out of action until the plates are made. Edited By JasonB on 20/05/2014 19:45:05 |
Nobby | 20/05/2014 22:45:17 |
![]() 587 forum posts 113 photos | Hi Ed and guys
Ed Duffner | 21/05/2014 07:22:18 |
863 forum posts 104 photos | Thank you Jason and Nobby, the lathe is out of action, this is part of it I'm rebuilding. I have two 125 x 100 x 20mm plates to make the faces, it'll be a bit like the Sieg headstock casting with pressed in taper-roller bearings but only the ends where the bearings are. The plates will be bolted to a base plate on the lathe. Nobby, you have described what I'm trying to achieve very well. I was a bit coy on the first plate and left about 1.5mm in from the edge as I didn't want to get too close. I keep forgetting that 1.5mm is actually a very large distance in engineering terms I will get a 2 flute slot drill to finish this job off. I am using the Warco WM-16 milling machine. Here's the idea. The left plate is as clamped in the mill and the finished item on the right. Thanks again,
Ed Duffner | 21/05/2014 08:00:15 |
863 forum posts 104 photos | I managed to find an imperial slot drill in my Dad's stash of tooling so can continue today. Thank you to whoever changed the title spelling, JasonB ? |
John Stevenson | 21/05/2014 10:08:14 |
![]() 5068 forum posts 3 photos | Perhaps a silly question but why can't you rough out and use a boring head to get the bearing diameters ? |
Ed Duffner | 21/05/2014 13:24:21 |
863 forum posts 104 photos | Hi John, no boring bar, not much money at the moment. I want to eventually make a boring bar as per Harold Hall's design in the Milling Book. ...but I need a lathe to do it. |
