PTFE die block
Using PTFE as die block material
David Haynes10/05/2014 21:40:47
168 forum posts
26 photos
I felt a bit disappointed that the PTFE die blocks that I used will have to be replaced before doing any useful service. The pin that goes through the block into the radius rod yoke has created an oval hole and this will affect the timing. I think the problem is the small dimensions of pin and block; a 3/32" pin through a 3/16" wide x 1/4" long x 1/8" thick block. Nice idea if it worked. Back to the steel.
Any thoughts?
John Baguley11/05/2014 02:15:48
517 forum posts
57 photos
Hi Dave,
I use bearing grade PEEK which is a harder material. I think virgin PTFE is probably too soft for such a highly loaded application and it will just deform, hence the oval hole.
Andrew Moyes 111/05/2014 08:09:46
158 forum posts
22 photos
Has anyone tried Tufnol (synthetic resin bonded fabric) as used to be used for example for contact breaker cams in motor cars?
Andrew M
David Haynes11/05/2014 08:34:05
168 forum posts
26 photos
Thanks folks. John, do you have a prefered supplier for PEEK?
mick H11/05/2014 09:06:29
795 forum posts
34 photos
Speaking of die blocks and difficulties therewith, I remember reading on this forum a more or less throwaway line from someone who said that he made circular die blocks. There was no further comment on this but it seemed like a good idea to me and I subsequently made up some circular bronze blocks, 1/8" diameter, for the Walschaerts gear of a Gauge 1 loco. They seem to roll perfectly and the timing is consistent but it has yet to run in steam. Has anyone else used this idea?
Mick
John Baguley11/05/2014 09:07:08
517 forum posts
57 photos
Hi Dave ,
In the past I've bought it from RS. They have Tecapeek PVX in 10mm diameter. They don't seem to have the range of diameters that they used to have though.
I've also bought it from Davis Industrial Plastics when I wanted longer lengths. They have PEEK HPV:
Both are similar materials. It's very expensive in larger diameters but not too bad for small stuff. I'm sure there will be other suppliers if you look around.
I use it for all sorts of bushes on locos e.g. coupling and connecting rod bushes.
Mick - I haven't tried round die blocks as such but over the pond they seem to use them quite a bit, even on 7-1/4/7-1/2" gauge stuff.  I have used a round die block in the slots on the end of a radius rod with good results
Edited By John Baguley on 11/05/2014 09:18:18
OuBallie11/05/2014 11:04:41
1181 forum posts
669 photos
David,
PTFE will creep unless constrained.
René Etter (RSME) did extensive experiments using the stuff in making D valves, and found this problem.
Cannot remember if he found a solution or not, but I think details where published in ME in the '70s or early '80s.
Geoff - Time to get wet plugging exhaust leak. Oh the rain has eased.
Chris Gunn11/05/2014 12:00:44
459 forum posts
28 photos
I used a material called Orkot for my die blocks on my 4" Garret, after having used it at work on something subjected to severe loads on a feed chain, where it stood up very well. These die blocks have been in since 1997, and there is no noticeable wear to date. The material has graphite in it I believe which helps with lubrication. I have used the same material for my 6" Garret 4CD die blocks. It is available, and a google search will give some suppliers. There are similar materials out there.
Chris Gunn
Michael Gilligan11/05/2014 12:04:14
23121 forum posts
1360 photos
Dave,
I have had excellent service from this ebay seller.
Chris Gunn11/05/2014 14:24:25
459 forum posts
28 photos
David, Having had a look at MichaelG's link, the Orkot is similar to the Ketron Peek HPV.
Chris Gunn
Ian S C12/05/2014 12:58:18
7468 forum posts
230 photos
Getting a bit complex, you might over come the tendency to oval holes by using a metal bush in the hole, or salvage one that has acquired an oval hole. Ian S C
John McNamara12/05/2014 15:58:49
1377 forum posts
133 photos
Hello David
PTFE will always creep, It also smears under load, I have found that out the hard way making slider blocks on a machine.
Can you post a photo of your die? I have an idea but cannot visualise your design.
