Soldering Hot rolled mild steel
fizzy30/04/2014 11:13:10
1860 forum posts
121 photos
I need to SS 4 pieces of hot rolled 6mm sheet together. Since the steel has an oxidisation coating on it I guess its not a good idea to solder straight to it. Removing it seems near impossible - any ideas?
Ian S C30/04/2014 11:25:27
7468 forum posts
230 photos
fizzy,unless you want to take it off with emery cloth, or file it, you can use either the electrolytic rust removal system, or soak it for a day or so in citric acid, or similar. Although I find that brazing with Oxy A, or propane, with a neutral flame you don't need much of a clean up at all. Ian S C
colin hawes30/04/2014 11:59:50
570 forum posts
18 photos
I usually clean up the surface with an angle grinder. Colin
Gordon W30/04/2014 12:21:42
2011 forum posts
Angle grinder with wire brush- must wear goggles. Acid flux, Bakers , solder will stick to all the cleaned bits no problem.
Ian S C01/05/2014 13:34:35
7468 forum posts
230 photos
Not Bakers, acid, fizzy want to silver solder, so an appropriate flux, or as I usually do borax. Ian S C
Gordon W01/05/2014 14:05:23
2011 forum posts
Sorry, I read SS as soft solder. For some reason I assumed he was soldering the sheets together prior to machining.
Ian S C01/05/2014 15:54:10
7468 forum posts
230 photos
Gordon, you could be right, fizzy can take the one that suits. Brazing little bits of steel, I use scrap sheet brass cut into strips about 5 mm wide, and borax for flux, works ok for me. Ian S C
HomeUse01/05/2014 18:14:32
168 forum posts
12 photos
Try dilute Hydrochldoric acid (Brick cleaner) to clean steel sheet - wash off with clean water and coat joint area with Borax paste - clamp in position and heat to just under cherry red and apply Silver Solder to edges of joints - solder will flow towards flame/heat position (Capillary action) - let cool normally - DO NOT COOL IN WATER - causes brittal joint
