thick wall steel pipe for rollers
capnahab25/03/2014 21:38:22
194 forum posts
17 photos
I need to move my lathe in the workshop. I have been using short lengths of 1 inch mild steel bar. I would like something longer ( 3-4 foot) and have seen people use thick walled tubing, - could be the rigid compressed air stuff ?. Does anyone have any recommendations ?.
Mark C25/03/2014 21:41:43
707 forum posts
Scaffold tube, cheap easily found
Mark
capnahab25/03/2014 21:44:51
194 forum posts
17 photos
Scaffold tube is good but a bit big on the diameter , for various reasons needs to be about an inch.
Rick Kirkland 125/03/2014 21:50:28
175 forum posts
25mm dia electrical conduit. Cheaper than steam pipe and up to the job.
Rick
JasonB26/03/2014 07:28:37
3/4 Gas Barrel wil have a thicker wall than coduit and being the 3/4" is the bore then the OD is about 1 1 /16"
Brian Wood26/03/2014 08:48:34
2742 forum posts
39 photos
What about plain galvanised water pipe, nominal 1/2 inch bore? Also cheap and available
Paul Lousick26/03/2014 08:49:43
2276 forum posts
801 photos
Why not water pipe ? Cheap from local hardware shop or cheaper from a scrap metal agent
Gordon W26/03/2014 11:18:35
2011 forum posts
If you can get them- 2 sheets of steel with grease between, easier and safer. Good ply etc. also works.
Bazyle26/03/2014 12:45:19
6956 forum posts
229 photos
Usefull pointer to the use of 3/4 pipe as I have been ruluctant to cut down my 5 ft scaff pipes to 2 ft to get though gaps.
It may be worth looking at the underside of your machine to see what the shape is. While the feet may present a flat wide load area if the roller moves along under a thin steel cabinet wall for example the pressure distribution may be bad for both the cabinet and roller. If that is ok then short 6 in lengths may be easier to move about and cheaper too. Since thin rollers are affected more by grit and concrete roughness shorter ones may reduce that problem.
Ed Duffner26/03/2014 13:00:28
863 forum posts
104 photos
A few tool and plant hire shops offer skates to place under machinery / appliances for moving around.
