Gordon W | 27/02/2014 11:20:50 |
2011 forum posts | I've been messing about with a couple of small DC motors and trying to work out how to use one throttle ( speed controller ) to control both motors. I realised that I know next to nothing about about modern electronics. Can anyone recommend a suitable book ? I do know elect. theory and can read a wiring diagram, so don't need basic stuff. Only ones I could find are very basic, very technical or very expensive. As an example ,what's a 555 and what can I do with it? I would like to be able to build something myself, eg speed controller, pulse counter. |
Ady1 | 27/02/2014 11:36:23 |
![]() 6137 forum posts 893 photos | I found this on my travels and was impressed... although I know nothing about these things Another one I found but it was quite expensive, was called Edison5 gl Edited By Ady1 on 27/02/2014 11:37:14 |
Andrew Johnston | 27/02/2014 11:44:06 |
![]() 7061 forum posts 719 photos | The best book by far on electronics is 'The Art of Electronics' by Horowitz and Hill. It is not cheap, but covers electronics in a practical sense, and discusses many real world component problems. The best thing you can do with a 555 is put it in the bin. Andrew |
jason udall | 27/02/2014 13:24:01 |
2032 forum posts 41 photos | I'll second "art of electronics". Readable. |
Swarf, Mostly! | 27/02/2014 13:24:51 |
753 forum posts 80 photos | Posted by Andrew Johnston on 27/02/2014 11:44:06:
SNIP The best thing you can do with a 555 is put it in the bin. Andrew
Hi there, Andrew, Please explain? What do you have against the ubiquitous 555? Best regards, Swarf, Mostly!
V8Eng | 27/02/2014 13:32:40 |
1826 forum posts 1 photos | A quick internet search for 555 timer will bring up lots of circuits for things like speed controls for small motors, etc. Those ICs have been around for decades now! Edited By V8Eng on 27/02/2014 13:33:43 |
Gordon W | 27/02/2014 14:18:53 |
2011 forum posts | Thanks for the replies so far. This illustrates my problem- The link to the Finnish site is very interesting, I think , But for me might as well be written in Finnish, just can't get it. Jokes about the 555 already, I don't know what one is! May be this time next year I will . I think it may be similar to my computer problems - to much jargon? The experts don't even realise they are using jargon, I'm just as guilty in other fields. Will check out The art of electronics. |
Ady1 | 27/02/2014 14:27:05 |
![]() 6137 forum posts 893 photos | A well known auction site has various learn-electronics books on dvd, as well as books |
WALLACE | 27/02/2014 14:27:39 |
304 forum posts 17 photos | I don't know how big your motors are, but you can get a pulse width controller kit from China on ebay that does a couple of amps at 12volts or so. Worked out cheaper than the components and came with a pcb so no flaffing with bits of veroboard. You'd probably need two and replace the single potentiometer with a dual ganged one. W. |
Gordon W | 27/02/2014 14:35:15 |
2011 forum posts | Just been checking out The Art of Electronics, seems about right for me with a bit of referencing, but at the price will have to wait, need a collett chuck first. My 2 motors are 24 V 400 W so will need a bit more oomph ( technical term ) Will try both existing controllers with one pot. and see what happens. |
V8Eng | 27/02/2014 14:40:09 |
1826 forum posts 1 photos | To find out what a 555 is try this, it might be a bit quicker than next year anyway . Good luck from an expert in absolutely nothing whatsoever!
Edited By V8Eng on 27/02/2014 14:44:13 |
jason udall | 27/02/2014 17:52:40 |
2032 forum posts 41 photos | Re motor control...just a thought..greenpower challenge. .used a speed controller made available for them..good solid design..again cheaper than the semiconductors. ... .. The speed control will need two channels not just two motors in parallel..because they never run the same speed (try getting a buggy to run straight with one motor in each wheel...eek!)... Good luck |
Andrew Johnston | 27/02/2014 19:02:20 |
![]() 7061 forum posts 719 photos | Gordon: The 555 is a timer integrated circuit. It can be triggered to produce a single pulse, or a continuous train of pulses, the timing of which is determined by an external resistor and capacitor. It was first introduced in the early 70s. Early versions had a number of problems including high supply currents, high current pulses when changing output levels, unexpected double output transitions and wouldn't run at low voltages. Some of these issues have been reduced by newer CMOS (complementary metal oxide semiconductor) versions. It is still widely available, and depending upon manufacturer, can be cheap, a few pence. It has uses in consumer grade electronics where cost is far more important than performance. However, for wider temperature ranges and reliability it has some problems, particularly as the timing parameters are dependent upon external passive components. Given that many devices these days contain a processor, even very cheap devices, that can be used to generate timing pulses that are orders of magnitude more accurate than a 555 timer. It is easier to change software than hardware too! Trawling through my memory there is, or was, a book based on 555 circuits, the publisher might have been Bambini? Regards, Andrew |
Mike Poole | 27/02/2014 19:11:20 |
![]() 3676 forum posts 82 photos | The publisher was Babani. Mike |
Andy Ash | 27/02/2014 19:42:38 |
159 forum posts 36 photos | The Art of Electronics is an excellent book. If you want to go bonkers I could recommend books which would be very expensive, and numb your soul. You would not need them. I have learned more from semiconductor application notes than ever I did in my studies. The 555 timer is simply a flip-flop (one bit memory cell) and a window comparator. You can use it in any way you could imagine, but it has a high current output ideal for driving a capacitor. This makes it a good timer. Normally a proper LSTTL non-retriggerable monostable is considered to be a better formal design candidate, but it depends on what you are doing. For the sake of your stock shelf a 555 timer can do more different things. I've not got one, but I'm pretty sure you could buy a book on just the 555 timer if you wanted. Speed control on motors is interesting. It depends very much on the particulars of the motor you are using. If you are using a synchronous motor, then dual speed control from a single control input is easy. If you are using an asynchronous motor then it is not. If you are using a typical brushless fan motor with an electronic commutator, then you have a means of synchronising the two motors. The commutator requires you to detect the position of the rotor for commutation. Since you have to change the polarity of the magnetic field yourself, when you do you know the rotor angle. By counting revolutions in time you know the speed of the motor. You can use potentiometer to specify a speed command signal. Your commutator design would take an input which controls the current in the winding. The commutator would automatically switch the current polarity every half revolution of the rotor. The commutator would integrate (count) reversals in time. This signal would represent the speed of the motor. You would then design an error circuit. The error circuit would compute the difference between the potentiometer speed demand, and the reported speed from the commutator. The result of the sum would be amplified greatly and fed into the current command of the commutator. Obviously if you had two motors, you would have two electronic commutators and two error circuits. The motors would maintain the same command speed irrespective of the load placed on them individually. It is important to realise that it would be a "speed match" and not an "angle match". For an angle match; control over, and feedback from the motor is required at a better precision. Another, older way of doing this is with a synchro/servo pair. Actually with this scheme a pair of three phase synchronous servo motors can be directly controlled for both speed and angle using a synchro transmitter. All you need is wiring and a three phase power source. The transmitter and the servos, are purely wound rotating components. These days servos are driven from inverter drives. A typical lathe motor is asynchronous (squirrel cage), but a permanent magnet three phase motor connected to an inverter can be controlled with with speed and angular precision.
Hope that all made sense!
Nicholas Farr | 27/02/2014 19:45:14 |
![]() 3988 forum posts 1799 photos | Hi, the book that Andrew metions is IC 555 Projects written by E.A. Parr and published by Bernard Babani (publishing) Ltd. (BP44) It was first published in Feb 1978, it was revised and reprinted on a few occasions, my copy being reprinted in 1788. My The Art of Electronics is the secound edition and was one of the 1990 reprints and cost me £32.50 Regards Nick. Edited By Nicholas Farr on 27/02/2014 20:02:49 |
Andy Ash | 27/02/2014 20:10:15 |
159 forum posts 36 photos | I think if you were researching a decision to buy Horrowitz and Hill you might want to do a Google for the free online PDF file!!!
Edited By Andy Ash on 27/02/2014 20:12:31 |
Billy Mills | 27/02/2014 21:35:35 |
377 forum posts | One aspect of electronics overlooked by many is the number of specialized fields within the subject. Depending on specialty people react in different ways to different perceptions. So a small DC brushed motor controller might be an analogue Pulse Width Modulated project to some, a digitally proportioned PWM to a software inclined person and a bridge feedback circuit( using back EMF as a tacho) to analogue types. They will all work but each approach has different strengths and weaknesses. AofE is a landmark good all round book but the second edition now needs some revision. Where it does work particuarly well is in conveying a "flavour" of good engineering to a very wide subject and in almost completly avoiding heavy maths, they also do what good engineers have always done- they revel in and love their profession. I would agree with Andrew about the 555 except that I would not be seen dead with a 555 in my bin. By the way the 555 has two comparitors for 1/3 and 2/3 rail thresholds, the three resistors were all 5K ohms in the original which some say is where "555" came from.
Billy,
Steven Vine | 28/02/2014 01:53:25 |
340 forum posts 30 photos | Hi Gordon The home tinkering books on Robot building mostly have good discussions and simple practical examples of small DC motor control. I have a few books packed away, else I would give you the titles. Steve |
Les Jones 1 | 28/02/2014 08:19:17 |
2292 forum posts 159 photos | Hi Gordon, Les. |
