What to do with a pile of bits?
Oompa Lumpa10/02/2014 19:26:19
888 forum posts
36 photos
So, I am now the proud owner of this pile of bits. Once upon a time it was a Seig C3 lathe, it's now a collection of parts.
I had originally thought to make a tool and cutter grinder - I have a nice quarter horse motor with a VFD - and mill the top side flush and the bottom carriage flush which would give me an X/Y table and attach a collet chuck to the top slide for the cutters.
Then I thought I might buy one of the X2 column and bases from Ketan and make a small Mill. Then I thought of taking the little DRO's off the topslide and trying to adapt them for my Chester Lathe.
THEN I thought it might be a good idea to do NONE of the above and save myself a load of time and aggravation. But that's no fun now is it?
Bazyle10/02/2014 20:21:42
6956 forum posts
229 photos
Gear hobber
or
Headstock + tailstock + stepper for computerised dividing head.
Cross-slide etc for rose engine.
Michael Gilligan10/02/2014 20:39:58
23121 forum posts
1360 photos
Bargain-Basement equivalent of the Quick-Step ?
Oompa Lumpa10/02/2014 21:00:19
888 forum posts
36 photos
Posted by Michael Gilligan on 10/02/2014 20:39:58:
I don't think so Michael. The headstock casting is no lightweight and add a motor..........
I'll give that one a miss I think.
Oompa Lumpa10/02/2014 21:02:17
888 forum posts
36 photos
Posted by Bazyle on 10/02/2014 20:21:42:
So what is a rose engine? Excuse my ignorance.
graham.
I.M. OUTAHERE11/02/2014 00:25:24
1468 forum posts
T&C grinder , camshaft grinder , dividing head or small cylindrical grinder are some of the things I would want to make if I had these items at hand .
Ian
Michael Gilligan11/02/2014 07:47:06
23121 forum posts
1360 photos
Posted by Oompa Lumpa on 10/02/2014 21:00:19:
... I don't think so Michael. The headstock casting is no lightweight ...
My error, Graham ... embarrassed
You did say the bits were from a C3 but, just looking at the photo, I mistook them for something much smaller.
I would still consider using the Headstock as a Milling Attachment of some sort ... but it's unlikely to be toolpost-mounted !!
For my education; could you please give the approximate outside dimensions of that Headstock casting, and also remind me which model of Chester Lathe you have.
Edit: I see, from another thread, that you have the DB7VS.
Edited By Michael Gilligan on 11/02/2014 07:54:31
old Al11/02/2014 09:29:01
187 forum posts
Bin it and move on to a project you want to do.
Don't put it in a corner so you think you will find a use for it later, you will run out of corners
Michael Gilligan11/02/2014 11:16:43
23121 forum posts
1360 photos
Posted by old Al on 11/02/2014 09:29:01:
Wise words, old Al ... as I know to my cost.
Currently wishing that I had a spherical workshop
[so there would be an infinity of corners]
Edited By Michael Gilligan on 11/02/2014 11:17:08
Gordon W11/02/2014 11:26:39
2011 forum posts
You could always give it to me, no use for it at the moment but have sheds and lots of corners.
IanT11/02/2014 12:10:29
2147 forum posts
222 photos
It has been some time since I've been able to get into any of my corners Al - but I've always known why.
'Head' says "just get rid of all this junk" but 'Heart' says "you might need it some day"
So whilst I would really like one of those lovely (tidy & well laid out) workshops that I so often envy online, the truth is that I don't think it's going to happen anytime soon. Stupid I know....
IanT
Oompa Lumpa11/02/2014 13:34:27
888 forum posts
36 photos
As always, the thread has been an education.
I now know what a Rose Engine is though I have long since seen the Holzapfel lathes, fascinating.
I am really ruthless when it comes to "corners", my workshop is one of those 'organised' ones. I can't be doing with disorganised catastrophe. My memory isn't good enough, I need everything to have a place so I can remember where I put it, whatever IT is
My first thoughts were a Tool and Cutter grinder, more specifically, something to sharpen drill bits with. I have all the components, including the material for the table and bracketry/adaptors so it would cost me nothing other than time so the consensus seems to be that route.
old Al is right though, I have a sort of rule of thumb: If I haven't used it in the last six months it is time to move it on. Tailstock and a few of the other bits are Bin Bound though, the Controller board I will sell and put the money to good use, IF it sells. The covers and boxing are also bin bound.
Michael, the headstock casting is 15.5 x 9 x 14 cm approx increasing to 22cm long if you take into account the shaft and gearing.
graham.
Michael Gilligan11/02/2014 13:44:29
23121 forum posts
1360 photos
Posted by Oompa Lumpa on 11/02/2014 13:34:27:
Thanks Graham,
Thinking-Cap is on ...
[Although in fact it's usually a matter of letting things simmer at the back of the mind.]
Next question: Does the profile on the bottom of that Headstock match your lathe bed ?
Another JohnS11/02/2014 13:45:20
842 forum posts
56 photos
Graham - I finally bit the bullet and got a Worden from Kirk @Hemingways and threw all the old "this is going to be a drill sharpener someday" bits in the bin.
Best move I've made in a decade.
My thoughts, anyway.
John.
Steve Withnell11/02/2014 22:17:16
858 forum posts
215 photos
Order a lathe bed of Ketan and put it back together
