Emgee | 28/12/2013 12:21:59 |
2610 forum posts 312 photos | Hi All Just posted some videos on Youtube to help new owners of these now old hat machines to program and operate using the original control system, G and M codes. "Denford Orac Tutor 1" shows the control panel and keypads then goes on to enter a program with cyclic feature. The other 2 videos show a dry run and finally the program in use cutting an aluminium bar. Link below takes you to the videos. Rgds, Marcus Edited By Emgee on 28/12/2013 12:22:59 |
Michael Gilligan | 29/12/2013 16:38:32 |
![]() 23121 forum posts 1360 photos | Marcus, Very interesting, thanks !! I don't have the machine, and probably never will; but it's fascinating to see it being worked as originally intended. MichaelG. |
Emgee | 07/01/2014 09:50:19 |
2610 forum posts 312 photos | Hi Michael and All Another video with facing, turning, inside and outside radius, taper, threading and boring, all on 1 video. Must fit a greater nose rad tool for the taper cuts !!!!! Rgds, Marcus |
mike T | 11/02/2021 13:17:42 |
221 forum posts 1 photos | Hello Emgee (Triac?) I have just acquired a Denford Orac for upgrade. I would like to fit a four jaw and a collet chuck. Did you ever identify the spindle nose/ backplate type or a possible supplier? Regards Mike
Edited By mike T on 11/02/2021 13:32:31 |
Roderick Jenkins | 11/02/2021 13:44:32 |
![]() 2376 forum posts 800 photos | When I was employed I bought a couple of Novaturns for work. I never did manage to identify the nose fitting Rod |
David Jupp | 11/02/2021 14:24:13 |
978 forum posts 26 photos | Interesting discussion about it on Denford forum, with no absolute conclusion, but a link to drawing of possible matching backplate. |
Andrew Evans | 11/02/2021 14:39:46 |
366 forum posts 8 photos | I think it may be a case of making a new spindle with standard dimensions or adapt one from a scrap lathe - like a D1-3. Whether it is worth the effort or cost I am not sure - might be easier to just start with an Easiturn lathe in the first place. |
mike T | 11/02/2021 14:54:37 |
221 forum posts 1 photos | Thank you Andrew, Sounds like you are saying "If you want to get here, you should'nt start from here" Several leaned sources suggest the Orac spindle nose is to DIN 55021 (modified?) |
