Units of measure in Gear cutting
David Paterson 415/12/2013 22:20:03
83 forum posts
8 photos
G'day,
I have been re-reading the workshop practice gear cutting book with a view to actually doing this.
One of the tables describes the dimensions for the button tools for creating cutter profiles. The dimensions used in this table are 'Ins'. Can anyone help me identify what these are please?
clearly they are not inches. Elsewhere in the book there is some advice the 1/4" material is sutable for maiking most small cutters - this would appear to be specified as '4' in the table, but any scling from that seems silly.
happpy christmas to the lot of you
Graham Wharton15/12/2013 22:33:51
149 forum posts
48 photos
The numbers in the tables are for a 1DP cutter
For other DP cutters, you must divide the number by the DP of the cutter you are making.
e.g if you are making a 20DP cutter, and the value in the table is 4, then the measurement you need is 0.2"
This is explained in more detail on the last page of the book. (Might have been nice to include a footnote on the relevant pages though) smiley
David Paterson 415/12/2013 23:55:48
83 forum posts
8 photos
Excellent, thank you.
I now have enough information to have a go at this.
Are you aware of any similar references that would let you generate cutters for clock making? I understand that these are cycloidal and they seem to have a much greater depth of cut than would appear feasible through use of button formers.
dave
Edited By David Paterson 4 on 15/12/2013 23:56:29
Thor 🇳🇴16/12/2013 05:06:27
1766 forum posts
46 photos
Hi Dave,
if you should want to make metric gears - using the module system - you have to multiply the numbers with the module and the result will be in mm. I have made module cutters using John Stevenson's table and description. Here's another description.
Thor
David Paterson 416/12/2013 23:42:39
83 forum posts
8 photos
Thor,
Interesting read - makes you wonder about maths.
I needed a thin woodruff key cutter so have stepped through the process of a fly cutter and using the index plate last night for 10 teeth. looks pretty much like the ratchet wheel i need to do that has much more materials and time invested than a 3" length of silver steel
next for the tooth profiles. first project might be an orrery based on Furgussons paradox. There is enough info around to see how a few of the problems have been solved, andit is only 5 gears.
Stub Mandrel17/12/2013 08:52:53
4318 forum posts
291 photos
Hi Norman,
The link should now take you to the host - it obviously took a day or so for DNS servers (the things that find a website for you when you type in teh name or click a link) to update.
I have to set up my business website first, but when I get a bit of spare time I will put up a holding page with a nice pic on it.
John Stevenson17/12/2013 09:35:50
5068 forum posts
You got the right thread Neil ?
Michael Cox 117/12/2013 17:39:01
555 forum posts
27 photos
Posted by David Paterson 4 on 16/12/2013 23:42:39:
Thor,
If you want to see the maths behind the tables see:
David Paterson 417/12/2013 21:12:00
83 forum posts
8 photos
Thanks Mike
