michael burton 1 | 09/11/2013 12:23:31 |
126 forum posts 32 photos | hi will brass work as a slide valve material just i have a big block of brass that i can use the cylinder is cast iron so will brass work at the mo i cant afford to get any differant material so would rather use what i have?????? also were would engineering plastics come in to use could you use somthing like acytel or delrin............... this is just a courious question the model is only going have minimal use atb mike |
JasonB | 09/11/2013 13:09:14 |
![]() 25215 forum posts 3105 photos 1 articles | For light use Brass will be OK though a bronze would be better. You could always silver solder a thin piece of bronze onto a brass block, if you cut a hole in teh bronze first then that will form the cavity in the valve. J |
fizzy | 10/11/2013 23:29:05 |
![]() 1860 forum posts 121 photos | hi..if your not planning on powering the national grid with it brass will be just fine, in my experience avoid plastics, they do bad things when they get hot!!
Ian S C | 11/11/2013 11:30:32 |
![]() 7468 forum posts 230 photos | With a cast iron cylinder, steel could be used, but cast iron is better. Stuart Turner use bronze on engines like the S 9, and I presume their other engines too. Ian S C |
fizzy | 11/11/2013 19:14:57 |
![]() 1860 forum posts 121 photos | Ian...totally agree that brass isnt perfect but it will last plenty long enough as a d-valve |
Ian S C | 12/11/2013 11:01:24 |
![]() 7468 forum posts 230 photos | fizzy, true. I tend to over engineer thing, even when it not needed. Ian S C |
