StirlingSingle | 23/10/2013 18:45:33 |
![]() 40 forum posts | Hello,
I have set up my saddle on the vertical mill for fly cutting the 5" diameter. However I am having trouble. I think I may need a boring head. any recommendations?
All the best,
Stirling. |
Russell Eberhardt | 23/10/2013 18:57:48 |
![]() 2785 forum posts 87 photos | A boring head is the easiest way to do it. I used a 2" Soba boring head but any one should do. If you haven't seen the site have a look at the Simplex build pictures here although he doesn't show that operation there is lots of good info. there. Russell. |
Stub Mandrel | 23/10/2013 18:59:23 |
![]() 4318 forum posts 291 photos 1 articles | Hi Stirling, It is the devil's own job to set a flycutter accurately to a diameter, as you don't have two opposite points to measure across.. A boring head allows you to make incremental changes and 'creep up' on the right size, and also as it is graduated you can see how big a change you are making. That said, if you can set the flycutter somehow, the actual mechanics of the cutting are probably more rigid. If you start sightly off-centre with the fly cutter, you can move the work across once the diameter is right. Neil |
StirlingSingle | 24/10/2013 07:43:19 |
![]() 40 forum posts | Many thanks for all the info. All the best,
Stirling |
julian atkins | 26/10/2013 01:19:32 |
![]() 1285 forum posts 353 photos | it is quite an easy casting to file to size using the smokebox material as a gauge. to machine it you will need quite a complicated set up and clamping arrangement IMHO - in the time taken to set it all up and make the clamps you could file it to size. much easier to fabricate out of 6 pieces of brass. cheers, julian |
