clogs | 01/10/2013 04:11:55 |
630 forum posts 12 photos | Hi I have a 1920, 35HP car with a poorley gearbox....need to replace the case hardened layshaft...... first the repair must be able to be good for 5,000 miles per year for at least five years......this is no museum piece...... the gears run submerged in oil and the gear set has heavy bronze bushings.. can I use silver steel as is..??........have read the threads on hardening and seems to be a very complicated subjuct......if it needs to be hardened and tempered I woud do the machineing of oilways and location flats first the after the heat treatment have it centerless ground.....how much over size for the grinding....the original shaft is 19mm dia....and is there anyne able to do it or recomend anywhere..??..... many thanks Frank |
Russell Eberhardt | 01/10/2013 10:57:28 |
![]() 2785 forum posts 87 photos | Hi Frank, I wouldn't use silver steel for that. Hardened and tempered silver steel has the same hardness all the way through so if the surface is hard enough it will be brittle. Case hardening a lower carbon steel gives a hard surface and a soft, more resilient core but gives a poor finish and has to be finish ground. Perhaps a better alternative might be to use a special nitriding steel and get it nitrided after machining. The surface finish is better than case hardening and can be used as is or given a slight final polish with fine emery. Russell. |
ronan walsh | 01/10/2013 16:21:22 |
546 forum posts 32 photos | en16 maybe ? I know from working on the gearbox of my old bsa 650 that they made the gears out of en36 and case hardened them, maybe a steel to consider too. alternatively you could use a nitriding steel as distortion is low (or lower) with that process.
jonathan heppel | 02/10/2013 19:32:23 |
99 forum posts | Is it definitely case hardened? If a file touches it then EN24T would save heat treatment and any finish grinding |
colin hawes | 02/10/2013 21:54:48 |
570 forum posts 18 photos | I would use EN 36 and get it case hardened for this. Silver steel will be likely to let you down and cause enormous damage to everything else in the gearbox. Colin |
clogs | 18/01/2014 16:05:46 |
630 forum posts 12 photos | I have now decided to go down the en16 / 36 route...but can any body recomend a place to go for Nitride coating.... I've have tried a few but they will only batch work.....
many thanks Frank |
Lambton | 19/01/2014 08:18:03 |
![]() 694 forum posts 2 photos | Frank, How badly worn is the original shaft? Some years ago I had a very badly worn extractor fan shaft about 1" diameter metal sprayed and ground back to the original diameter by a company called Deritend in Luton. Their main plant is in Wolverhampton. They did a superb job, the bearings fitted perfectly and the fan is still in use. Detritend are used to doing one offs as they offer repair rather than production services. I am sure they may be other companies offering metal spray/grinding services. .Eric |
Windy | 19/01/2014 10:08:52 |
![]() 910 forum posts 197 photos | Linear shafting is a product I use on my flash steam engine it has a ground case hardened skin if your shaft is a common size it might be suitable. Not sure of the material specification the core is machinable but might have to use a carbide tools to get through the case. Paul |
RJW | 19/01/2014 10:29:55 |
343 forum posts 36 photos | Frank, I'm guessing the wear 'may' be limited to a step at the end of the shaft bearing the brunt of the 1st / reverse gear cluster, if so it may be worth considering localised repairs by turning down the worn area of the shaft and sleeving it, then have the sleeve surface ground to size, that way you keep much of the original shaft intact and able to use a harder material for the bearing surface without going down the route of hardening the whole thing, it can save a lot of time and expense if needing to faff around drilling and plugging for oilways and boring out the core if it's a hollow tube type shaft! When you rebuild the box, I'd highly recommend using a good anti-friction product to coat bearing surfaces during assembly and when refilling it! John |
