Clarkson auto lock
How does it work?
Robonthemoor06/09/2013 14:53:09
211 forum posts
45 photos
image.jpgGot one with a mill I bought but no idea how or what type of bits fit, I have an S type clarkson on mt2 but this is not the same, please see photo, and if you can post photos of how it work.
rob
ken king, King Design06/09/2013 15:26:30
144 forum posts
239 photos
Hello Rob, it seems that the two smaller items, if combined into one, would perform the function of the Clarkson nosepiece, apart from there being no obvious driving dogs. At any rate there would be a need for a collet to hold the tool, which would be tightened by the short taper in the central piece illustrated. I take it you have no collets ?
Regarding potential tool slippage, are there any driving lugs or similar buried up in the main body ?
Sorry I can't really help, I've not seen one like this, but I'll bet there are members who have. Hopefully they will come forward and shine the necessary light. Good Luck !
Ken.
Robonthemoor07/09/2013 05:00:15
211 forum posts
45 photos
Thank Ken, yes two driving dogs at the bottom, & no I have no collets. I think it is a C type! But would like it confirmed before I start buying collets that don't fit. 20mm or 3/4 OD collets would fit.
rob
Tony Pratt 107/09/2013 10:07:13
2319 forum posts
13 photos
Hi Rob, 20mm & 3/4" aren't the same size so they can't both fit?
Tony
Andrew Johnston07/09/2013 10:15:40
7061 forum posts
719 photos
A picture of the internals of the chuck body would help identify the type of collets required. It looks like a Clarkson C-type; does it have 'Clarkson' engraved anywhere?
Bazyle07/09/2013 11:41:13
6956 forum posts
229 photos
It looks too new to be a c-type!. Posilock perhaps. There are several 'own brand' versions of that eg axminster. The sleeve looks unusual as there is no taper either in it or on it and the groove is for what?
Could it be for something else - like part of a sliding tapping fixture, or tailstock die holder-holder.
Robonthemoor07/09/2013 12:08:31
211 forum posts
45 photos
I will take a photo of that sleeve you can see, and yes it has a taper, also it says clarkson Autolock On It and a part number, when I get home I will post photo & number.
rob
Keith Long07/09/2013 13:10:30
883 forum posts
11 photos
Hi Rob
I've just checked my Clarkson "C" type chuck and it looks the same as your's, apart from mine being a bit more battered on the outside. Mine is stamped quite clearly Clarkson Autolock on the face of the closing nut.
The collets that I have for it are all in the region of 20.64 - 20.65 mm od so well over either 3/4 in or 20 mm. They need to be a good sliding fit in the sleeve as this helps with the concentricity, and the sleeve is a VERY nice sliding fit in the body. I also have 3 collets that I've picked up separately that won't actually go into the sleeve, being slightly oversize on diameter. One of them is just 0.01mm too big so should be possible to get it to size fairly easily, the other 2 are more like 0.1mm oversize so more of a problem as they are HARD. It may be that those are for another make of chuck that uses the same principle, so be careful when you buy collets. If you can take the sleeve with you to try the collets for fit. Also good luck with finding metric ones, they seem to be VERY thin on the ground.
None of my collets are marked in any way with a trade mark but a number came with the chuck so I don't have any real reason to assume that they are NOT of Clarkson origin.
The sleeve for my chuck also has that groove, it's there as an undercut for where the nose taper meets the parallel outer diameter of the collet, so it avoids any "hang-ups" in that corner and also helps to minimise the effects of swarf or debris that gets in there so it doesn't affect the closing and centrering action.
"S" type metric collest have a groove in the od of the tail end flange to identify them, on the 2 metric "C" type collets that I have there is no such identification, I've sized them by trying the shanks of the milling cutters in when it was fairly easily able to tell the difference between 1/4in and 6mm and also the 1/2 in and 12mm collets. Without some definite marking though it would be pretty easy to pick up the wrong one and wonder why the cutter was running off centre.
Keith
RICHARD GREEN 207/09/2013 18:43:27
329 forum posts
193 photos
Hello Rob,
Here are some pictures of a Clarkson "C" type ? chuck that I've got, the collets are all 811 thou in diameter, the metric ones have an identifying groove around them, all collets have two locating "dogs" on the top end,
There are 1/4 , 3/8 , 1/2 , and 5/8" , also 6mm , 2 x 10mm,1 x 12mm and 1 x 16mm,
The lot can be yours for £ 40 if they are any use to you, I'm in Bucks. ( collection only )
All collets are in very good condition. ( nice original box as well )
Richard.
Robonthemoor07/09/2013 21:19:42
211 forum posts
45 photos
image.jpgThanks Keith all very good points' mine measure 20.64mm inside that sleeve too, & yes it looks like yours.
Richard, you have a nice set"and yes" I would buy them as at the moment I have none to fit. I do have a set of clarkson s type, and a reducer from mt4 to mt2 , so I can use it in my deckel fp1. Can I convince you to take them down to the post office! if I give you my address? I'm up in Lincolnshire, fair way down to you in Buckinghamshire, give it some thought with the post.
Rob.
Edited By Robonthemoor on 07/09/2013 21:25:06
Edited By Robonthemoor on 07/09/2013 21:26:32
RICHARD GREEN 208/09/2013 13:08:48
329 forum posts
193 photos
Rob,
Posting is no problem, I've sent you a PM.
Richard.
Robonthemoor08/09/2013 17:39:05
211 forum posts
45 photos
Sent you a pm Richard, thanks to you all for your expert advice, again" you all have anther of my problem solve.
regards
Rob
babiels27/02/2022 08:28:55
15 forum posts
Hi I have two questions for you experienced chaps:
1. I have a small C-type Clarkson Chuck that came with my ancient mill (in fact the Chuck is integral/ non-removable from the spindle shaft). I received it with a single 12mm collet and threaded endmill and have since bought a 1/4” collet and cutters. Both work great and very sturdy while making heavy cuts, however I realise now that I have been using them without the sleeve pictured in this thread. My Chuck came with the closing nut and collet only, so I didn’t know any better. It seems sturdy as hell AND concentric so is this a problem? The collet sticks out of the bottom of the closing nut by about 1/8” when done up and cutting.
2. I have been looking for a small 5/8” C-type collet for a long time, and I’m wondering whether it would be possible to modify a small 5/8” S-Type collet, by grinding the racetrack shaped dog down into the two dogs necessary for a C-Type collet? Does anyone know if they share outer dimensions including length?
thanks!
Edited By babiels on 27/02/2022 08:30:38
not done it yet27/02/2022 09:12:41
7517 forum posts
20 photos
I very much doubt a Clarkson is a non-removable part of a spindle.
You should be able to remove it from the spindle with a pair of suitable wedges.
babiels27/02/2022 09:46:46
15 forum posts
Oh maybe your right. But it doesn’t have a drawbar…? I’ll give it a try and report back. Thanks!
Michael Gilligan27/02/2022 10:00:38
23121 forum posts
1360 photos
Posted by babiels on 27/02/2022 09:46:46:
dont know
Don’t be over-enthusiastic in your efforts … your original understanding may be correct !
What is the ‘ancient mill’ that you have ?
[ someone, somewhere on the forum, might know about it ]
babiels27/02/2022 10:25:23
15 forum posts
It is called a Swisten (a rebranded Carsten’s mill **LINK**
photos of mine in a disassembled state:
peak427/02/2022 11:45:16
2207 forum posts
210 photos
Babiels, the link on Tony's site suggests that the mill originally came with an MT3 or an as yet unidentified taper.
It's quite possible that the latter is actually a Clarkson fitting, or a variation on it.
If you have a look in my album, of which this is one photo, there is a variety of different chucks on show there.
When I got my Centec, it came with a Clarkson C type and a set of imperial collets; I successfully made a full set of metric ones myself to suit, so it's quite possible to make your own from scratch.
I've since picked up a full set of genuine ones over the years.
I don't think it will be practical to convert S type to C type, though I will happily supply any measurements you need.
On the C type, there should certainly be a closing sleeve.
Whereabouts in the world are you roughly?
Bill
Edited By peak4 on 27/02/2022 11:46:22
babiels27/02/2022 12:30:31
15 forum posts
Thanks Bill. I guess I should start by making a sleeve then. If you have dimensions for the sleeve that would been much appreciated. Unfortunately I think making a collet from scratch is beyond me: I only have a micro lathe with no screw cutting or cross slide capability.
Looking at your photos, none of them look quite like mine. My experience of morse taper tooling is nil, so I am well have missed something.I would LOVE it if it turned out to be a removable Chuck, without a drawbar, if that’s a thing.
I’m in Hammersmith, London.
babiels27/02/2022 12:41:54
15 forum posts
Oh I should say I would LOVE it if it turned out to be a removable Chuck without a drawbar or a tang. And the spindle has no tang-access slot either.
