Doddy | 06/08/2013 15:43:14 |
![]() 72 forum posts 103 photos |
So the bottom draw in the workshop has a few milling cutters which are a bit dull and have lost their edge. Always wanted a ToolCutter Grinder and one day I'm sure I'll make a Quorn, Stent, Worden or go and buy one. Up until now I've always though about the cost of a Tool Cutter Grinder Vs the price of a new cutter. Looking at the growing pile of blunt and chipped cutters there are a few that only require the edge "touching up" so heres my solution, yes it needs a guard and few other mods but I just made it to see if the results were OK. The only real problem is I can only sharpen the ends of Slot drills and End mills and not the sides and the diamond disk is turning down across the cutting edge rather than away from the cutting edge, but it hardly leaves a burr |
Thor 🇳🇴 | 06/08/2013 17:56:32 |
![]() 1766 forum posts 46 photos | Seems to be simple to make. I have made a cutter holder with a MT 2 spindle, and mounted it on a small X-Y table. The Unimat is used to grind the cutting edges, I use an ordinary aluminiumoxide wheel though. From your pictures it should be easy to mount a diamond wheel. Thor. |
jason udall | 06/08/2013 18:17:28 |
2032 forum posts 41 photos | It does highlight a "problem" with the SL...almost any tooling dwarfs the SL...but nice work. .neat job...guess diamond wheels also avoid shedding grit in the workshop. .. |
Ian P | 06/08/2013 20:09:05 |
![]() 2747 forum posts 123 photos | I like it! I have an SL doing nothing under the bench so now I know why I kept it. One questiion, where did you get the ER25 collet block? I can only find ER32 size. Ian P
Ian P | 06/08/2013 20:12:36 |
![]() 2747 forum posts 123 photos | Oops! I see Arc Euro do them. I looked at their website 'New Products' page and it has them listed as ER32, its only when you go to the page that the ER25 is shown Ian P |
Stub Mandrel | 06/08/2013 20:19:47 |
![]() 4318 forum posts 291 photos 1 articles | I discovered ER25 'stephenson collet blocks' on the Arc Website a few days ago. They also sell Mr S's trusty endmill sharpening block which works like the one above, but with a surface grinder (for the lucky few who have a surface grinder). Neil
jason udall | 06/08/2013 20:33:10 |
2032 forum posts 41 photos | Just a thought..the SL three jaw would suffice for grinding work holding...and the indexer would also serve...use the stub mounting for that assy. And away you go.... |
Ian P | 06/08/2013 20:41:43 |
![]() 2747 forum posts 123 photos | Jason If you use the chuck to hold and index the cutter you then need another spindle/motor for the diamond wheel, also I doubt the chuck accuracy would be good enough for cutters. The SL spindle is ideal for the grinding wheel, I'm sure with the right pulleys it would be good for 10,000 RPM so its a waste just to index with it. Ian P
jason udall | 06/08/2013 20:54:06 |
2032 forum posts 41 photos | No use the index unit with chuck for work holding..keep spindle as you say for wheel |
jason udall | 06/08/2013 20:55:58 |
2032 forum posts 41 photos | As to the chuck accuracy...well truw they do vary |
