Searching for a "Bench Grinder with Sanding Belt"
dcosta27/07/2013 23:40:41
496 forum posts
207 photos
Hello,
Would any of you gentlemen have opinions about "DRAPER 150mm 370W 230V Bench Grinder with Sanding Belt and Worklight" sold by Chronos. I ask because I have no idea of ​​the quality attributes of the item and specifications, as we know, do not tell us everything about the subject. The fact of being away (in Portugal) and relatively isolated
(in terms of engineering) not knowing anyone who knows anything about the item makes it even more risky to order such an item.
Thanks in anticipation
Dias Costa
Trevor Wright29/07/2013 13:05:49
139 forum posts
36 photos
Have had one of these for 6 years now and love the thing.
Trevor
Stub Mandrel29/07/2013 19:45:39
4318 forum posts
291 photos
As I've got a bench grinder and smaller one powering my T&C grinder I bopught one of THESE: It works really well. I could kick myself as about two weeks after getting it I found one of the regulars (Chester?) shifting them for nearer £50.
Sold for wood but the standard belt works a treat on steel, great for finishing unmachined flat surfaces and rounding corners.
NJH29/07/2013 21:23:20
2314 forum posts
139 photos
Agreed Neil
.....or even touching up a HSS lathe tool !
I also have a heavier duty belt and disc sander which I picked up, second hand, about 20 years ago from an ad in the local paper. I think thats had more use than any of my machines - I use it for wood , steel etc - you name it.
Norman
John Coates29/07/2013 21:28:29
558 forum posts
28 photos
I've bought one of these
the table up against the disc is useful
Robbo29/07/2013 21:29:36
1504 forum posts
142 photos
Dias,
Can't tell you about the specific machine from personal experience, but it is one of several "clones" made in China to this design. Others are sold by Sealey and Scheppach, among others. (Made by Scheppach was once a guarantee of a quality item made in Europe, but like everyone else they have moved production to China.)
So it is one of several on sale for under £100, for a much better quality machine you would be looking at £200 plus as a minimum.
The Draper brand contains many small machines for home use, and quality is similar to those mentioned by Trevor and Stub. I have a linisher/sander in the same quality range,similar to the one in John's link, and it is OK.
If you are happy with Asian quality, and it may need a little personal touch to improve it, then I should go ahead. I assume Chronos are able to ship to Portugal without problem, that being why you have chosen them.
Phil
Edited By Robbo on 29/07/2013 21:31:49
Billy Mills29/07/2013 23:47:46
377 forum posts
Dias-
Hope you have an Aldi store near by;**LINK**. Under £30.00 and 3 year g/tee!
So might come up in Portugal some time.
Billy.
Edited By Billy Mills on 29/07/2013 23:49:16
Robbo01/08/2013 22:09:14
1504 forum posts
142 photos
Billy,
Have had a look at one of these, and to me they have an intrinsic design/build fault on the idler drum attachment method.
Not recommended unless you're despaerate.
Phil
_Paul_02/08/2013 03:05:26
543 forum posts
31 photos
I bought an Aldi Combination Grinder/Sander some time ago the idler drum was badly out of round I remachined it to try and stop it jumping around it's still rough but useable, amongst others I have an RJH Bison grinder that has 12" wheels that you can balance a cup of tea on the Aldi combination machine will stir your tea for you
Billy Mills02/08/2013 18:04:42
377 forum posts
I saw the offer in a local store but did not buy as I already have some linishing gear. For someone starting out it might be useful but we have now two reviews against.
In the past I have found Lidl and Aldi stuff to be very good value, not the world's best but good value for everyday use. They don't quibble about refunds and do give a 3 year warrenty.
Couple of years back I got a small belt and disc sander from Warco. Not expensive but have had to fiddle around lining up bits and replacing the table lock which falls apart. It does ok for the light use it gets but then it did not cost what a RJH Bison cost new.
Billy.
Robbo03/08/2013 19:07:42
1504 forum posts
142 photos
Billy,
Have to agree that some of Aldi kit is OK, and I have bought some of less frequently used stuff there. But in this case, no. The fault could be rectified at home, but you may as well make your own belt attachment for a grinder given the amount of work involved.
Phil
John Stevenson03/08/2013 19:34:40
5068 forum posts
I bought one a while ago off Ebay, decent but you can't press hard.
I modified mine by drilling three extra holes in the sanding backplate so the belt is vertical.
Just seemed more useful at this angle ?
_Paul_03/08/2013 20:44:46
543 forum posts
31 photos
Posted by John Stevenson on 03/08/2013 19:34:40:
+1
As standard they are a peculiar angle probably set like that to suit them what mess around with brown stuff crook
Robbo03/08/2013 22:42:54
1504 forum posts
142 photos
The angle of the belt is good for grinding woodturning tools from a flat (more or less) grinding rest.
Robert Sorby produce a well engineered version, without grinding wheel, just for this purpose.
Phil
dcosta10/08/2013 18:09:16
496 forum posts
207 photos
Hello everyone, good afternoon.
Context: Preparing an order to Chronos.
To Trevor: The Chronos only sells the bench grinder you mentioned in uk main land, and not having asked, I think that this excludes Portugal. Thank you.
To Neil: I would buy one of these grinders from Clark but this model does not figure on the website of Chronos. Thank you.
To Norman: I would buy one of these grinders from Clark but this model does not figure on the website of Chronos. Thank you.
To John Coates: The grinder Scheppach (beautiful) is not sold by Chronos. Thank you.
To Phil (Robbo): Yes, I think you're right on all the statements you make in both your posts. Thank you.
To Billy: A few days ago I found in my mailbox a flyer of an Aldi supermarket that recently opened near me and there I found the grinders. Its price was about 60 € and how I could not open the box to observe the quality of the grinder gave up the purchase.
To _Paul_: A few days ago I found in my mailbox a flyer of an Aldi supermarket that recently opened near me and there I found the grinders. As I could not open the box to observe the quality of the grinder gave up the purchase.
To John Stevenson: Thank you for your suggestion of a few more holes and opinion.
In conclusion, I will probably buy the Draper grinders with the sanding belt assuming that perhaps I'll need some improvements of its operation.
Also have to consider the exiguous space versus usefulness that I have for such a device.
Best regards
Dias Costa
Edited By dcosta on 10/08/2013 18:09:45
Stub Mandrel10/08/2013 18:12:23
4318 forum posts
291 photos
HI Dias
If you haven't ordered yet, there is an identical machine to mine for £52.08 + deleivery on offer from Chester on the back of the latest Model Engineer. That's £20 less than I paid.
The machine from Chester  comes up as £49.00 + VAT  about £69 if you 'add to cart' but this is with UK delivery. I suggest you email them say you want the ME offer (52.08 inc vat) and ask about delivery to Portugal?
Chronos do (or used to, their website is plkaying up!) sell it, but UK mainland delivry only as Clarke CS4-6D Belt And Disc Sander  (Ref: 6500412) at about £80
Edited By Stub Mandrel on 10/08/2013 18:23:27
Edited By Stub Mandrel on 10/08/2013 18:27:56
Edited By Stub Mandrel on 10/08/2013 18:29:26
martin perman10/08/2013 18:48:48
2095 forum posts
75 photos
Gentlemen,
I have an ALDI linisher as described and find it very useful, I've not had to modify or repair it, for the money it does well for me.
Martin P
dcosta10/08/2013 19:57:50
496 forum posts
207 photos
Hello Neil,
Thank you for your help I see you understood the various aspects of my problem which are not only about the quality of the grinding and sanding belt but also about the scarcely available space in my workshop, availabilty in the seller and save some Euros in carrying costs by carrying a set of items together in only one parcel.
The Chester Machine Tools in its WWW shop, when chosing country in check out, only shows UK.
It looks like the crisis is felt by only some...
Best regards
Dias Costa
NJH10/08/2013 20:14:08
2314 forum posts
139 photos
Hi again Dias
Well I hope you do manage to get your grinder - if you do perhaps you will let us know the result!
May I make a personal plea? I find your use of a slightly smaller than usual font and, especially, the blue type colour in your postings very hard on my aging eyes. A little larger, black, typeface in your postings would help me a lot.
Norman
Stub Mandrel10/08/2013 20:59:36
4318 forum posts
291 photos
Comic Sans - the marmite of typefaces!
You need to visit HERE Norman.
I understand that Chester may export, Dias, try emailing them with an enquiry.
Edited By Stub Mandrel on 10/08/2013 21:01:28
