Doddy | 16/07/2013 16:45:12 |
![]() 72 forum posts 103 photos |
#After 4 years use my Warco WM14 mill motor finally gave the ghost and died on me. It has at times worked quite hard, sometimes taking cuts bigger than I should have, usually rushing to finish a job. The motor has run quite hot, so I used to run it with the cover removed. Edited By Dodweld on 16/07/2013 16:48:10 |
Andyf | 16/07/2013 17:17:18 |
392 forum posts | The computer fan is a good idea. As a result of someone else's tale of releasing the magic smoke, I shoehorned one on the end of the motor on my little Warco lathe, which has vents in both ends. It runs continuously from a 12V wall wart when the lathe is switched on at the wall socket, and gives a good breeze through the motor. When running at low speed and highish torque, the motor's own internal fan is needed most, but isn't doing much to help. Andy |
Mark P. | 16/07/2013 19:22:48 |
![]() 634 forum posts 9 photos | Had my WM16 for about 6 years,replaced 2 sets of brushes in that time. It has done a lot of work some of which has seriously tested it no sign of gear stripping.I also fitted an extra cooling fan.Still going strong. Mark P. |
mick H | 17/07/2013 18:01:17 |
795 forum posts 34 photos | Dodweld...from where have you sourced the power for the fan....a lead seems to be going in to the yellow control box. Is there a power takeoff in there ? Or is the power takeoff from the transformer in the 13 amp socket ? Mick |
Ziggar | 18/07/2013 22:02:12 |
![]() 115 forum posts 1 photos | lm also interested in where the takeoff for power for the fan is. i have the WM14 too, and like you, am concerned about the high temps the motor runs at. ive bought a fan for it but would rather have the power coming from off the board if possible rather than having a serperate power unit for it
Z
John Stevenson | 18/07/2013 23:08:12 |
![]() 5068 forum posts 3 photos | There is no low voltage on the WM circuit boards. However if you get one of these [ or a few given the price ]
You can pinch 240v AC from the input side to power the fan.
Bought loads of these for various projects and they work well for something that does not require more than 1 amp @ 12v. In fact it's far cheaper to but one of these power supplies and a 12v fan than source a 240v mains fan. |
Ziggar | 18/07/2013 23:17:38 |
![]() 115 forum posts 1 photos | Nice. Cheers John for the link just bought 4. got some other places too i can use these things.
Z
Doddy | 19/07/2013 09:16:19 |
The fan is 240v origanally from Maplins , 13watt 85mA so supply is taken from the fused side mains supply chocolate block before the PCB. Runs all the time the power is on, so it cools the motor once I've finished the cut. Just add a temperature guage too |
