But what about the "Stars"?
Geoffrey HYDE FYNN19/06/2013 20:48:15
20 forum posts
Hi all again,
Last week I raised the old question about lube for my ML7. I got loads of useful advice but no-one actually answered the question that I was asking; i.e. the manuals and book all "star" certain lube points but then contradict their advice or so it seem to me being a novice...
I have the Publication 701 that came with the lathe in 1952 and also the Publication 720 and also Ian Bradley's excellent book. They all list various lube points amongst them: 5) Backgear and changegear over teeth; 7) Tumbler gears; 15) leadscrew; 16) Rack; and 17) Cross-slide and top-slide feedscrews The later manuals/book suggest SAE 30 but they both then say that anything with a star i.e. 5), 7), 15), 16), 17), should use Rotol MTS 1000 which is a grease. Am I missing something or...
Geoffrey.
magpie19/06/2013 22:17:31
508 forum posts
98 photos
Hi Geoffrey, I should just use some oil. crook You are most likley to get at least a dozen ideas from the members on here, so you will be no wiser. Cheers Derek.
Geoffrey HYDE FYNN19/06/2013 22:32:42
20 forum posts
I'm sure that was what my father did over all of the years and the machine seems in perfect condition.
I will get on and finish installing it and then USE IT (carefully...)
Thanks.
Geoffrey
Robbo19/06/2013 23:14:12
1504 forum posts
142 photos
Geoffrey,
I would use sae30 on all the points you mention, just apply it frequently. I would never use grease on the leadscrew as it attracts swarf and is a sod to clean off - you will see your manual recommends cleaning the leadscrew with paraffin and re-oiling.
The only place I would use grease is on the changewheels, and even there a good thick sticky oil is just as good - people have experimented with all sorts to quieten the changewheels for instance, but it all boils down to keep it lubricated with a product that will find it's way into the crevices, and that means oil.
Phil
I'll now duck down behind the parapet.
Lambton20/06/2013 08:21:58
694 forum posts
The handbook for my S7 states " Where SAE 30 is specified any good motor oil of this number will be satisfactory. For starred items nos. 21,22,23,24,25 use Rocol MTS1000 grease should be used in those territories where it is available"
I too have never understood this enigmatic instruction and I am sure the person who produced it is no longer available to explain the reasoning.
As Robbo says just use oil and never grease on these lub. points. I buy Castrol SAE 30 grade 4 stroke lawn mower oil which is more than adequate - don't waste your money on expensive modern motor oils.
Ian S C20/06/2013 10:40:22
7468 forum posts
230 photos
Lambton, your oil specs are just like the fuel specs in one of my old aero engine hand books
Fuel: Good grade automobile fuel. The engine is the D.H. Gypsy III Aero Engine. It's a bit more specific on lubricating oil. Ian S C
Robbo20/06/2013 21:57:19
1504 forum posts
142 photos
Ian,
but in those days you could just taxi up to a petrol pump (hand-operated) and fill up!!
Phil
Robbo20/06/2013 22:01:12
1504 forum posts
142 photos
Seriously though, for Geoffrey,
There was an article in MEW no 184 on the care and lubrication of Myford series 7 lathes. Although a Super 7 was used as an example (because the author has one) the principles are the same.
The author, David Haythornthwaite, wrote it after getting specific advice from Myford staff at one of the open days "because of the confusion surrouinding the subject".
Geoffrey, if you want to see this article send me a PM.
Phil
Bazyle20/06/2013 22:22:36
6956 forum posts
229 photos
I can imagine the scene
Chief Engineer “ Don’t need a manual for a lathe, every engineer has the common sense to know how to use one”
Marketing Director “ What’s a lathe? Google pictures look komplikated.”
CE knocks up manual “.......Lubricate as necessary....”
Marketing Director “Loo-ber- ic-kate. wow what a gi-nor-mouse word”
CE raises ECR001 “ .....oil here, here, and here....”
Marketing Director “ Oh, oil. Like wot Betty fries the chips in “
CE looks at barrel he is sitting on because chair budget was spent on printing manuals and raises ECR100 “....Oil to SAE 30.....”
Some clever Dick “ he he you missed that oiling point he he”
Exasperated CE raises ECR 500 “ ........and * and * and *.......”
Marketing Director “.....OOOH Betty. Spinning lathey thing has done an oily whoopsy on my shirt”
CE, losing will to live, raises ECR1000 “....use grease.......”
Welcome to my world. Well I write specifications not user manuals but the sentiment is the same.
magpie21/06/2013 10:34:35
508 forum posts
98 photos
Fick engineeeer here askin wots an ECR. ??? Cheers Derek.
Michael Gilligan21/06/2013 11:25:38
23121 forum posts
1360 photos
Derek,
My guess would be "Engineering Change Request" ... but there are probably dozens of alternatives.
Michael Gilligan21/06/2013 16:05:20
23121 forum posts
1360 photos
ECN at Acronym Finder
... any advance on 41 ?
Bazyle21/06/2013 16:37:10
6956 forum posts
229 photos
Well ECR yielded 76 but you were correct to start with. Pretty standard sort of terminology I thought around all the big old engineering companies, especially defence contractors, and now ISO9000 companies. Really anywhere that had a proper Drawing Office with those big old drawing boards and plan chests. I did wonder if anyone would ask, and also who might confuse CE with the more modern and American imported CEO.
Michael Gilligan21/06/2013 16:50:11
23121 forum posts
1360 photos
Posted by Bazyle on 21/06/2013 16:37:10:
Ooops !
... crossed my Change Notes with my Change Requests
blush
Gone Away21/06/2013 17:02:01
829 forum posts
Posted by Bazyle on 20/06/2013 22:22:36:
Bet that gives North American readers a chuckle smiley
KWIL21/06/2013 19:16:39
3681 forum posts
70 photos
Shouldn't you use an eraser on that one?
Geoffrey HYDE FYNN25/06/2013 21:36:13
20 forum posts
Thanks for all of your help and advice. The 1952 ML7 isback up and running and properly lubricated...
Thanks again.
Geoffrey
Hopper26/06/2013 06:22:59
7881 forum posts
397 photos
Posted by Robbo on 19/06/2013 23:14:12:ee your manual recommends cleaning the leadscrew with paraffin and re-oiling.
Motorcycle chain lube spray is a whole lot less messy on the change gears. Sticks like snot to a blanket and does not get flung everywhere. And it contains molybdenum and extreme pressure lubricant additives perfect for gear teeth.
Edited By Hopper on 26/06/2013 06:24:57
Robbo26/06/2013 11:55:21
1504 forum posts
142 photos
That sounds like good stuff, am using chainsaw oil at present because of it's anti-fling properties, and if it can stand the stress of chainsawing it can certainly stand the stress of a few changewheels.
Back in the olden days, motorcycle chain grease was like lard, we heated it up in a tin dish (old roasting tin if we could sneak it out of the kitchen), usually on top of an old Primus stove 'til it was warm and runny, then dunked the chain in it for a few minutes and hung it out to cool.
This was part of the Saturday ritual before riding out on Sunday.
Of course it is many years since I last had my leg over - a motorcycle - if I say Norton Dominator it will give you a clue how long!
Ian S C26/06/2013 12:52:09
7468 forum posts
230 photos
I'v got some Catapillar cam lobe lubricant that I'm going to try, it's used when assembling Cat engines after overhaul, can't hurt. Ian S C
