Alan .204 | 01/06/2013 20:22:08 |
304 forum posts 14 photos | Hello chaps after making H Halls grinding rest I thought I would make the jig for sharpening my drill bits but it doesn't seam to matter what or how I do it they do not cut any suggestions, they look right and I have done what it says in the book but I must be doing something wrong and can't see it, any advice would be welcome.
Alan. |
Chris Heapy | 01/06/2013 22:14:45 |
209 forum posts 144 photos | Sounds like you don't have enough clearance behind the cutting edge and it is just rubbing.. |
Ady1 | 02/06/2013 01:40:46 |
![]() 6137 forum posts 893 photos | The hardest bit to get right is the centre point area, and this is the most important bit. Do a small hole followed by a bigger hole wherver possible to make life easier for the bigger drill. I always found that the flutes cut quite easily and the pointy bit held things back A drill has to be REALLY bad for the flutes not to cut Edited By Ady1 on 02/06/2013 01:41:55 |
Ady1 | 02/06/2013 02:49:54 |
![]() 6137 forum posts 893 photos | The best advice I can think of is get one you've never touched up and have a really good look at it Then practice practice practice I found that a drill press can cover a host of sharpening errors because it applies such high pressure compared to hand drilling steel with a bosch Once you get it right you can zap through steel with a hand held drill, but it does take a while to "get it" The main thing to learn is never ever try to force it if it won't cut Basically... the tip is at right angles to the flutes... which have a bit of relief behind them If you angle the tip too much it can actually drag the drill into the cut, almost like a self tapping screw gl
Edited By Ady1 on 02/06/2013 03:17:24 Edited By Ady1 on 02/06/2013 03:17:49 |
Ady1 | 02/06/2013 03:24:58 |
![]() 6137 forum posts 893 photos | If you angle the tip too much it can actually drag the drill into the cut, almost like a self tapping screw You can get away with this with bigger stronger drills and produce cool whirls of swarf, but the teeny ones will grab too much metal and snap, so it's worth knowing any details which control the amount of metal being munched |
dcosta | 02/06/2013 12:02:04 |
496 forum posts 207 photos |
Hello Allan, good morning. |
Clive Hartland | 02/06/2013 13:49:29 |
![]() 2929 forum posts 41 photos | It looks as if you need to make or invest in a 4 Facet drill grinding jig! This should solve all your problems. To grind a drill by hand, particularly small sizes is difficult without lots of practice, mostly hit and miss. Clive |
Russell Eberhardt | 02/06/2013 15:51:51 |
![]() 2785 forum posts 87 photos | You don't say which drill jig you've made. HH describes one for small drills and one for 4 facet grinding in that book. I have made the 4 facet one and it works fine. Perhaps you should post a close-up picture of the tip of your reground drill? Russell. |
Harold Hall 1 | 02/06/2013 17:25:37 |
418 forum posts 4 photos | I assume Alan that you are attempting the four facet method, in that case, can I suggest that you look at the explanation of the method on my web site as it describes and illustrates it in more detail than in the book. This is at - **LINK** See also the earlier pages in that item that deal with more normal drill sharpening techniques. These start at - **LINK** Harold |
Alan .204 | 03/06/2013 19:26:43 |
304 forum posts 14 photos | I will go back and have another go at it tomorrow if I get chance, have read the reply's and its given me a new lease if you know what I mean, it is the four facet jig I made, for years I have been sharpening free hand and never had much of a problem just gets a bit difficult with the small drills, so thought I would have some ultra sharp drills using the jig ?
Regards Alan. |
Stub Mandrel | 03/06/2013 21:04:58 |
![]() 4318 forum posts 291 photos 1 articles | Alan, Try and get a close up of the drill point. It should be easier to make an assessment of a 4-facet point than a conical one from a picture. Neil |
