Cornish Jack | 12/03/2013 11:02:51 |
1228 forum posts 172 photos |
G'day all. Photos are of one of a number of motors which I have just re-discovered!! Unable to find any relevant info on the Web and would like to know what input would be correct and what connections should be used. Dimensions are approx. 1" diam and 2.5" long. Any help much appreciated. Rgds Bill |
Les Jones 1 | 12/03/2013 12:22:11 |
2292 forum posts 159 photos |
Hi Bill, Les. |
Stub Mandrel | 12/03/2013 12:54:42 |
![]() 4318 forum posts 291 photos 1 articles | Seimes throws up several results for V224411 all in the article here These suggest it is a brushed 220V/50Hz asynchronous motor with a number of variants and the brushes listed as parts. One or two sources suggest it may be three-phase, which would explain the 1,2,3 terminals. It may be a very small high-voltage servomotor, rather than a stepper. Don't just dive in and apply the mains though - check the resistance across the terminals is above, say, 80 ohms first. Some people find these in printers, someone else is selling one as 'possibly a stepper motor'. If its a stepper, you will probably be able to feel a sort of 'cogging' effect when you turn it. You could check the ebay hits for V22411 but don't rely on ebayers to know what they have scavenged! |
Keith Long | 12/03/2013 13:04:40 |
883 forum posts 11 photos | Bill Suggest you search on the other number as well 1BS1430-4TA plus the other nyumbers that are going round the side. Some suggestions from Polish site seem to be 15 volts but wther ac, dc or which pins - no idea. At least they are out there and known about! Keith |
Les Jones 1 | 12/03/2013 13:16:29 |
Well found Neil, Les. |
Cornish Jack | 12/03/2013 13:44:46 |
1228 forum posts 172 photos | Many thanks, gentlemen.
I get the feeling at times that my particular Google/Yahoo/ whatever search engine is/are different to everybody else's!! Rgds Bill |
Keith Long | 12/03/2013 14:14:29 |
883 forum posts 11 photos | Bill If you've got a tray of 50 of them you could well find that you've struck gold (well a small pot) in another sense! Depending on what they are I wouldn't be at all surprised if some folks here would offer beer tokens for some of them. Keith Edited By Keith Long on 12/03/2013 14:14:48 |
Stub Mandrel | 12/03/2013 14:58:55 |
![]() 4318 forum posts 291 photos 1 articles | It's a curious stepper motor if it only has three terminals, unless that's a fourth on the front. A complete guess think it's a small servo motor rather than a stepper, possibly brushless for three-phase control or perhsps it's for two phase AC. The terminal on the gearbox being a position encoder of some kind. If so it is probably quite an expensive bit of kit. It probably is lower than mains voltage. Neil |
Les Jones 1 | 12/03/2013 15:16:38 |
Hi Neil, Les. |
Kris Lehane | 12/03/2013 16:57:23 |
11 forum posts | Bill. I am curious, as I have just re-built an AC motor from Hoover, that has the same Three terminals, on opening it up, Marked A, B, and C, to drive my Myford ML7. I can't see a capacitor bolted to the outside, but there may be an internal One. It may be a Two-phase motor. I am familiar with most stepper motors. These usually have 4 wires, Each pair (Meter them) usually control 2 separate coils. Therefore, it's not a stepper motor. There maybe, probably, however, 2 coils, within said motor. One of the Three terminals is common for both coil A and coil B, The other Two terminals feed in to either coil A or coil B from the other end of the winding. To make it go in a certain direction, One will lag behind the other, via capacitor, or larger winding, to make it go in a certain direction. Take it apart and I am willing to bet you will find 4 terminals! Bit like riding a bike and which pedal do you push first...I t could be a delta winding Three-phase, but probably not at that size. Don't trust me, investigate further. K.
Stub Mandrel | 12/03/2013 18:27:33 |
![]() 4318 forum posts 291 photos 1 articles | > It could also be a brushless DC motor requiring a controller. Same difference - the controllers synthesise a 3-phase signal! Neil |
Michael Gilligan | 13/03/2013 10:48:01 |
![]() 23121 forum posts 1360 photos | You may get some more results by searching for the other number on the "plate" 1BS1430-4TA Someone on Allegro.pl is advertising some of these, and shows them as 15V MichaelG.
Edited By Michael Gilligan on 13/03/2013 10:50:55 Edited By Michael Gilligan on 13/03/2013 10:53:34 |
Cornish Jack | 13/03/2013 11:12:24 |
Again, many thanks for all the helpful suggestions - have to admit that some of the more esoteric advice joins reactive loads as 'knowledge gained'!! This, obviously, item in question opened up . There are 12 separating pieces and rotation of the shaft is 'lumpy' - seems to correspond to the number of separations (haven't counted them!) Resistance measurements (on an AVO digital meter) are : 1-2 - 6.76 ohms 1-3 - 6.80 ohms 2-3 - 6.79 ohms Will follow up some more of the above advice and report back Rgds Bill
Rgds B Edited By Cornish Jack on 13/03/2013 11:19:16 |
Michael Gilligan | 13/03/2013 11:27:49 |
![]() 23121 forum posts 1360 photos | Looks nicely made ... therefore must be worth investigating ! Incidentally, I think that V22411 is just an identifier for the Siemens company. MichaelG. |
Michael Gilligan | 13/03/2013 11:41:45 |
![]() 23121 forum posts 1360 photos | From your measurements, it seems most likely to be a Delta-wound DC Brushless Motor See this Wikipedia article If so, you might get suitable controllers from the RC aircraft suppliers. ... I reckon you could have a "High Speed Drill" project in there somewhere. MichaelG.
Cornish Jack | 14/03/2013 11:24:22 |
1228 forum posts 172 photos | Thank you Michael et al.
Still puzzling over these things but it would seem that brushless DC is correct. An even greater puzzle is how some of you have search facilities which produce results that don't come up for me!! Rgds and thanks Bill |
Michael Gilligan | 14/03/2013 12:41:50 |
![]() 23121 forum posts 1360 photos | Bill, To paraphrase from Star Wars: "... use the Force ..." Things just start to feel right, when you're heading in the right direction. One thing that often seems to work: Use the "images" search in Google [our visual pattern recognition is good] ... this can quickly filter-out the red herrings. As for your unit in particular: By searching on only V22411 you will find lots of references to other stuff made by Siemens ... therefore it's probably a code to identify the manufacturer. ... Log that fact for reference, then try some other number from the "plate" ... et seq. Happy hunting MichaelG.
Bazyle | 14/03/2013 17:02:39 |
![]() 6956 forum posts 229 photos | For future reference in worth knowing that aircraft often have 28v DC and 3 phase 400Hz (can't remember volts) and sometimes marine too. Ships may have a few more options available. These voltages might also bleed into equipent on tanks too. The 400 hz is used to make the transformers more efficient so small & light. 28v is from the battery of course. |
Stub Mandrel | 15/03/2013 09:23:38 |
![]() 4318 forum posts 291 photos 1 articles | I still have to grumble about how a brushless motor can be DC. Even wikipedia says:"Brushless DC electric motor (BLDC motors, BL motors) also known as electronically commutated motors (ECMs, EC motors) are synchronous motors which are powered by a DC electric source via an integrated inverter/switching power supply, which produces an AC electric signal to drive the motor (AC, alternating current, does not imply a sinusoidal waveform but rather a bi-directional current with no restriction on waveform);" I don't see how the Ac is generated from a DC source by an inverter makes them DC motors! But it is obviously accepted terminology so I'll just crawl ff into the Pedants' Corner and mumble quietly to myself! Neil PS: that link I found for a seimens list has references to various motors including 'sychronmotor, assynchronmotor and some that translate as 'brush turned off'. I suspect it refers to the case size. |
jason udall | 15/03/2013 09:43:44 |
2032 forum posts 41 photos | Neil... I agree... I think there is even a word for it...( don't remember at the mo. ) where "everyone knows" that frogs go RIBBET, horses hoves sound like coconuts , live centers that arn't...digital verniers...etc. but DC BRUSHLESS. is the term you would need to search for to find that class of device.. the divide between .. dc brushless and certain types of non- pm stepper motors is blurry... and with intregrated drives ( in box on side of motor) even more so...... regards Jason
Edited By jason udall on 15/03/2013 09:44:29 |
