Lloyd Bowers | 19/02/2013 07:15:49 |
49 forum posts 2 photos | Hi all, been looking and trying to set my tail stock to be dead centre on my exe 3.5 super, ive managed to get it within a thou to two side to side (towards/away from operator) but its still a little high, at least 0.5mm which i think is 20 thou i think. I have a dial gauge but over the 10" its a little "wobbly"? so ive ran the gauge side to side a number of times to check. my question is is this high within tolerance? if not how can i adjust it, i think its level/parallel to the bed. |
Les Jones 1 | 19/02/2013 09:30:20 |
2292 forum posts 159 photos |
Hi Lioyd, Les. |
Bubble | 19/02/2013 10:23:29 |
75 forum posts 6 photos | Hi Lloyd Put the lathe centres in the headstock spindle and tailstock, bring them together and insert a thin flat strip such as a Stanley knife blade between the points. Bring them in light contact. If the centres are in alignment the strip will remain vertical. If your tailstock really is .5mm out of alignment the strip will deflect. This test can be remarkably sensitive. The centre points must be in good condition, not bruised at all. Jim |
Nobby | 19/02/2013 10:45:08 |
![]() 587 forum posts 113 photos |
Hi Lloyd |
Lloyd Bowers | 19/02/2013 11:03:43 |
49 forum posts 2 photos | hi all, thanks for the surgestions i think ive basicly done what you've said nobby but dont own a sensitive dti, im just got a plunger type, so exspected a thou or two difference, i used a magnetic holder for my dial, which was fixed to the chuck then the dial on the revolving centre that i have, checked it first at the back face, then the front face (side to side) then turned it to the top and saw it was out compaired with the sides. I didnt do the outside of the quill incase the quill wasnt concentric. i done this close to the chuck first, then moved it back to about 10" where i need it for one bit im doing, i cant remember if both near and far were the same amound out? Edited By Lloyd Bowers on 19/02/2013 11:05:36 |
Les Jones 1 | 19/02/2013 11:12:30 |
Hi Lloyd, Les. |
Lloyd Bowers | 19/02/2013 11:23:36 |
49 forum posts 2 photos | yeah i did think of that, but i dont think it would be all that much, and there was a little near the chuck. im going to try a stiffer bigger bar to hold the gauge.. |
Lloyd Bowers | 19/02/2013 11:24:27 |
49 forum posts 2 photos | am i right in thinking high isnt as important as side/side? |
Ady1 | 19/02/2013 11:26:23 |
![]() 6137 forum posts 893 photos | Put two good pointy centres into the head and tailstock tapers and bring them together by eye The headstock is the critical bit for workholding I can't see you getting "true alignment" from a hobby lathe tailstock because it travels up and down the bed so some small errors will always arise edit Normally the pointy bits should show the same height and the only adjustment is from side to side If the height is obviously wrong take it to bits and clean it up and have a good look at it edit2 Don't forget that the tailstock barrel can be wonky/loose inside the tailstock housing, this is an old hobby lathe we're talking about and some errors you will have to accept and deal with as you do your metalwork Edited By Ady1 on 19/02/2013 11:31:41 |
Lloyd Bowers | 19/02/2013 11:54:33 |
49 forum posts 2 photos | ok, thanks, will do and recheck. |
Ady1 | 19/02/2013 12:18:14 |
![]() 6137 forum posts 893 photos | Don't view your tailstock as a high precision part, more as an aid to workholding which needs to be as close as possible to the centre point of the headstock
If you're tailstock isn't well adjusted then it can break small drills because it isn't drilling straight down the centreline If it drills a nice neat hole down the centreline when you have a workpiece in the chuck then that's all you can really expect of it gl |
speelwerk | 19/02/2013 12:21:17 |
464 forum posts 2 photos |
Make an arbor which you can place between the centers, as long as possible, solder on the ends a small length of larger diameter. When you turn, without changing the tool setting, the same diameter at headstock and tailstock end, your tailstock is in alignment. Niko |
Nobby | 19/02/2013 12:41:56 |
Hi Again |
Lloyd Bowers | 19/02/2013 13:47:11 |
49 forum posts 2 photos | ok i see. thanks. ill try it and see. do you also double check the tool is centred at both ends before or after? |
Lloyd Bowers | 19/02/2013 20:11:36 |
49 forum posts 2 photos | yep the bar worked, kind of? some how end to end was fine or ajustable to be fine. but the middle was slightly thicker? is that flex in the work piece due to the pressure of the tool acting on it? |
Stub Mandrel | 19/02/2013 20:34:04 |
![]() 4318 forum posts 291 photos 1 articles | > is that flex in the work piece due to the pressure of the tool acting on it? Most likely it is, unless the centre portion of the bed is worn. Neil |
Nobby | 19/02/2013 20:34:30 |
Hi |
Ady1 | 19/02/2013 22:05:34 |
![]() 6137 forum posts 893 photos | The centre/Chuck end of your bed is probbly worn to some extent The same probbly goes for your main leadscrew Your crosslide leadscrew is probbly the same, more wear in the middle You'll pick these things up as you get more experienced with your unit and fix or work your way around them, usually they are too minor to correct "for all time" What I ended up doing was only doing things accurately when it was essential Most of the time mega accuracy is unnecessary, your lathe will do a lot of hard work roughing stuff down, milling etc This knocks things about For any "final cuts" you get serious about accuracy, nipping up the slides etc The main thing is that your headstock bearings/spindle are decent, a wonky headstock is bad news Edited By Ady1 on 19/02/2013 22:11:15 |
Lloyd Bowers | 19/02/2013 22:12:46 |
Posted by Ady1 on 19/02/2013 22:05:34:
The centre/Chuck end of your bed is probbly worn to some extent The same probbly goes for your main leadscrew Your crosslide leadscrew is probbly the same, more wear in the middle You'll pick these things up as you get more experienced with your unit and fix or work your way around them The main thing is that your headstock bearings/spindle are decent, a wonky headstock is bad news
does the fixed steady fix to the cross slide? |
Ady1 | 19/02/2013 22:18:44 |
![]() 6137 forum posts 893 photos | The fixed steady goes on the lathe bed The travelling steady goes on the back of the cross slide saddle |
