GEAR CUTTING
Cutting the final drive gear for a 6" traction engine.
RICHARD GREEN 210/02/2013 12:57:42
329 forum posts
193 photos
This is a 21" diameter final drive gear for a 6" scale Burrell traction Engine, with 124 teeth , 6DP,
Using a Vertex 14" rotary table, and a homemade division plate,
The casting includes the winch drum, and weighs approx 100 KG
Richard.
Edited By RICHARD GREEN 2 on 10/02/2013 13:08:00
Another JohnS10/02/2013 14:14:54
842 forum posts
56 photos
Well done!
Another JohnS.
Phil P10/02/2013 14:35:19
851 forum posts
206 photos
You have my sympathies winding that knee up and down for every tooth, maybe more than one pass for each.
Phil
John Stevenson10/02/2013 14:44:49
5068 forum posts
Richard now requests to be known as Popeye Green.
RICHARD GREEN 210/02/2013 17:01:23
329 forum posts
193 photos
Phil and John,
The TOS mill has power feeds and rapids,
I raised the table under power to cut the teeth,......................Then used the "rapid" to lower the table to then set it for the next tooth, no arm ache at all !
The smaller gears for the 6" Burrell were cut on an Elliott U2 mill (no rapids), Power up and hand crank down, I calculated on a 95 tooth gear that I cranked the table down approx 2000 turns on the handle !!
Then I decided to use the TOS mill !
Richard, ( Popeye)
Stub Mandrel10/02/2013 17:07:56
4318 forum posts
291 photos
Interesting stuff Richard - shows how a horizontal mill is better than a vertical for some jobs.
Phil P10/02/2013 17:08:59
851 forum posts
206 photos
Power feed.............I take it all back, you are a wimp laugh
Just kidding, are you doing your own bevel gears for the diff by the way ?
Phil
RICHARD GREEN 210/02/2013 17:15:01
329 forum posts
193 photos
Neil,
I just couldn't do it any other way, As you can see the casting overhangs the rotary table by 31/2" all round, clearance would have been a big problem , it only just fitted on the mill as it was, maximum table load is 250KG so including the rotary table I was just under that figure,
Richard,
RICHARD GREEN 210/02/2013 17:18:57
329 forum posts
193 photos
Phil,
I'm not doing the bevel gears and pinions for the differential, I've had them professionally cut, They are a bit out of my league, all those calculations screw my head up!
Richard,
Springbok10/02/2013 17:25:36
879 forum posts
34 photos
Well all I can say is congratulation a wonderfull job.
Bob
RICHARD GREEN 210/02/2013 17:28:08
329 forum posts
193 photos
Thanks Bob,
Richard.
Andrew Johnston11/02/2013 12:28:54
7061 forum posts
719 photos
Hi Richard,
Thanks for posting the pictures, very impressive. When I get round to machining the final drive gears for my engines I will be using a similar set up; good to know that it works. My rotary table isn't as fancy, in that it has no division plates, but fortunately my final drive gears have 72 teeth, so easy division. It seems slightly odd that the final drive gears on my 4" engine are 5DP, whereas yours are 6DP.
I don't have power drive on the knee of my horizontal mill, so I'd better start eating that spinach.
RICHARD GREEN 211/02/2013 12:44:50
329 forum posts
193 photos
Andrew,
Then they will call you "Popeye" Johnstone !
Richard.
RICHARD GREEN 211/02/2013 12:58:07
329 forum posts
193 photos
Andrew,
Your final drive gear has 72 teeth, mine has 124 teeth, so even though my gear is larger , mine are going to be smaller teeth, just how it was designed I suppose.
Richard.
Bazyle11/02/2013 12:58:59
6956 forum posts
229 photos
A balance wieght and pulley would make it easier on both machine and operator.
RICHARD GREEN 211/02/2013 13:05:19
329 forum posts
193 photos
Bazyle,
You would need a big weight to counter balance the knee,table,rotary table and casting, would probably have to buy 3 or 4 large anvils ! smiley
Richard.
