Bearings
Bob Perkins28/01/2013 07:29:03
249 forum posts
60 photos
I'm working on a project at present which requires a couple of bearings. I've ordered the bearings, 19mm od, 10mm I'd. I,ve fitted and removed bearings in the past, but have not machined parts to fit. My drawing shows a 19mm recess for the bearing and a 10mm shaft. My question is do I need to allow - mm tolerance to the recess and shaft? If yes, what value should I consider? Or is a 19mm x 10mm designed to fit a 19mm recess and a 10mm shaft?
Thanks in advance
Bob P..
Springbok28/01/2013 08:06:48
879 forum posts
34 photos
Bob P
Is the shaft going to be a press fit onto the bearing. and into the recess.
If I am reading this correctly 10mm dia for shaft to fit into bearing. That is a big bearing what is it for.
Bob
Bob Perkins28/01/2013 08:12:05
249 forum posts
60 photos
Hi Bob
im building Jan Rissers sabine IC engine.
Bob P
Bob Perkins28/01/2013 08:13:05
249 forum posts
60 photos
Sorry Jan Ridders ( bloody IPAD)
David Jupp28/01/2013 08:48:43
978 forum posts
26 photos
Bearing manufacturers web sites typically give information on fitting bearings - including housing / shaft dimensions.
In some cases you may want slightly different dimensions for each bearing (axial movement allowed at one bearing to allow for shaft thermal expansion).
If you accidentally cut too much material away, there are 'bearing fit' adhesives available that can save the day (widely used in industry beacuse quicker/cheaper than close tolerance machining).
colin hawes28/01/2013 15:16:19
570 forum posts
18 photos
Note (for precision work such as a machine spindle): Ball and roller bearings are manufactured so that the outer race contracts to the correct diameter for running when pressed into its housing with a recommended interference fit Colin.
chris stephens29/01/2013 00:25:36
1049 forum posts
Hi Guys,
The other day, whilst frozen out of the engineerium, I was browsing You Tube and came across this site.
http://www.youtube.com/user/MaProNL/videos?view=0
An SKF bearing site showing how to do bearing fitting in an approved manner. Well, approved if you have a fortune to spend on their special kit! Even with this in mind, some are worth watching. It is always nice to know how things should be done, even if you have no chance of doing it that way.
chriStephens
Gordon W29/01/2013 09:49:27
2011 forum posts
Bearing fits are much to complicated to go into here, for a start depends on which is rotating, inner or outer ? For general model making I would make outer and inner a good push fit with a touch of bearing lock if needed.
