Samuel Brown 2 | 30/12/2012 19:46:18 |
9 forum posts | I notice that once again the 2" scale portable engine by Tony Webster has disappeared from Model Engineer. The last article mentioned that design faults etc had all been corrected. Have a complete set of working drawings for this engine been produced and are there intentions to make them available to purchase? |
Jeremy Moore 1 | 03/01/2013 18:01:18 |
2 forum posts | Having started this engine I also would like to have an up-date on the abvailability of correct drawings. I was given to understand tha these would made available. This was a long time ago, and since then, NOTHING !!! |
David Clark 1 | 03/01/2013 18:58:19 |
![]() 3357 forum posts 112 photos 10 articles | Hi There I expect we will start working on the articles around the first of February. There is a lot of work to do to make sure they are right. regards David
Jeff Dayman | 05/01/2013 15:01:42 |
2356 forum posts 47 photos | Jeremy you have a PM - JD |
Samuel Brown 2 | 10/01/2013 20:15:16 |
9 forum posts | Thank you for your replies. I look forward to the restart of the articles. |
fizzy | 05/09/2016 13:01:43 |
![]() 1860 forum posts 121 photos | Did anything ever come of this?
Thanks |
JasonB | 05/09/2016 13:07:08 |
![]() 25215 forum posts 3105 photos 1 articles | It was dropped. |
S.D.L. | 05/09/2016 19:02:11 |
236 forum posts 37 photos |
Posted by fizzy on 05/09/2016 13:01:43: Did anything ever come of this?
Thanks As Jason said it was dropped as there was lots of discussion re errors in the drawings. A book was subsequently published by Toby Webster but I don't know if the errors were worked on and removed or just published as was. Steve |
JasonB | 05/09/2016 19:16:25 |
![]() 25215 forum posts 3105 photos 1 articles | The portable in the book is a different one but it's no better than what appeared in the mag, infact some bad errors on the boiler for example that could have you building it from one of two thicknesses!! All drawings are no more than pencil sketches. |
clivel | 05/09/2016 20:05:05 |
344 forum posts 17 photos | When the series was first published in ME I was very much a beginner with limited experience. I was really keen on a portable, especially one supposedly described as suitable for a beginner, so when the book came out I immediately rushed out and bought it, mistakenly thinking that it was an updated and corrected version of the series of articles in ME. Unfortunately It turned out that not only was it for a different engine, but the quality of the book was no better, and if anything actually worse than of that described in ME. It contains a number of poor drawing, many bits are missing, and there are no assembly drawings, not of the complete engine nor of any of the sub-assemblies, only isolated bits and pieces with no apparent relationship to each other. I spent some time trying to visualise how some of the pieces go together, but with little success Except for a few nice photographs, the book is a complete waste of money. Clive Edited By clivel on 05/09/2016 20:06:48 |
Jeremy Moore 1 | 06/09/2016 11:09:27 |
2 forum posts |
Jeremy Hi, Like others I started this engine and made the wheels and started on the boiler before realising that there were numerous errors in the drawings. At one point I understood that although the series was being dropped sketch drawings would be made available for those that wanted to complete the portable. This idea was also dropped. I was then referred to the book which as has already been pointed out is for a different engine and is even more sparse with regard to drawings. One would have hoped that the editors of Model Engineer would have made sure that the series was of sufficient standard that an engine could be completed, from the drawings, before publication and before subscribers had spent hard earned money and time on a model which could not be completed. I have Model Engineers going back to 1979 and as far as i can seen this is the only time that this has ever happened. In the past when a series has not been complete other Model Engineers have stepped in and have been invited to complete, as happened with an earlier portable.
