fizzy | 29/12/2012 21:40:40 |
![]() 1860 forum posts 121 photos | Hi - Ive got a part with some tapered holes in it, but ive got no pins. The big end of the hole is about 60 thou and its 1/2" long. Do I make them, buy them? What taper will they be? What material? Do they need loctiteing in? Hope you can help. Nigel |
JohnF | 29/12/2012 22:01:54 |
![]() 1243 forum posts 202 photos | Hi, sounds to me that they are standard taper pins 1/16" dia, generally taper pins are in inches per foot but i would have to look it up its to many years ago to remeber !!! Chronos sell them for £3.60 per 10off John |
Chris Trice | 30/12/2012 02:32:27 |
![]() 1376 forum posts 10 photos | Imperial sized taper pins have a 1 in 48 taper, metric 1 in 50. EKP Supplies also sell them in small quantities. |
Pete | 30/12/2012 02:38:06 |
128 forum posts | It really does depend on what the part is from and where and when it was built. Because there's also a metric series of taper pins too. Machinery's Handbook lists the dimensions. But a good industrial tool supplier would also list the dimensions for the taper pin reamers. You might need to make up a imperial and metric pin to see what fits the best. They do need to fit almost as well as a male Morse taper needs to fit the female bore. Pete |
roy entwistle | 30/12/2012 09:28:35 |
1716 forum posts | You can get clock pins from Meadows and Passmore Put m-p into google they come in steel or brass Roy |
Russell Eberhardt | 30/12/2012 11:18:48 |
![]() 2785 forum posts 87 photos |
Posted by fizzy on 29/12/2012 21:40:40:
Do they need loctiteing in? Hope you can help. Nigel No, don't use loctite. If they are a good fit they just need a light tap to hold them in place. Remember, you might want to dismantle it at some time in the future. Russell; |
Stub Mandrel | 30/12/2012 17:57:02 |
![]() 4318 forum posts 291 photos 1 articles | I got a good supply of taper pins from Proops and found a matching reamer at a boot sale. They work so well I'm surprised they aren't used more often. I have turned up my own pins when I have 'over reamed' the hole and they work fine. Neil |
