Digital Issue Access
Dunc14/12/2012 21:10:09
139 forum posts
I received an email stating that the latest issue (MEW #198) was available. Sure enough, it shows in the index for all issues. However, when I click on it to open it does not appear & posts an error message: File Not found: Try Again.
I am able to access all the other issues (tried several and no problems).
Is this just an issue with a premature message or is it something else?
Thanks.
JasonB14/12/2012 21:22:05
Works fine for me
There was a thread a day or so about teh same thing but the problem seemed cured, have a look at that.
Edit sorry you were refering to MEW not ME but could still be a similar problem
J
Edited By JasonB on 14/12/2012 21:23:06
Michael Gilligan14/12/2012 21:23:38
23121 forum posts
1360 photos
Works O.K. for me too
David Clark 114/12/2012 21:23:45
3357 forum posts
112 photos
10 articles
Hi There
Works fine for me but takes a few seconds to load.
regards David
Dunc15/12/2012 00:40:39
139 forum posts
Retried (few hours later) with no success. Not a case of slow loading since the error message pops up immediately. I have rebooted my system but continue to get the same error message and "Try Again" does nothing. Again, the other issues open with no problem.
Johnande15/12/2012 02:21:26
5 forum posts
I too was having problems (see previous posts) but have found the problem in my case.
Even though I have been receiving each digital Issue monthly for almost a year. All of a sudden access was not available. My 10 digit member number was required. And thereby was the problem.
Initially I had entered the NUMBERS which in my case is 8 digits, it worked at first. When I was asked to re-entered the NUMBERS it didn't. So I entered the NUMBERS + the trailing letter. Tilt!! it didn't work.
Eventually I had to put in ALL NUMBERS including the 2 leading zero's and leave the trailing letter off. Hope it helps somebody.
BINGO! it works.
Johnande
JES15/12/2012 09:10:03
84 forum posts
71 photos
MEW 198 gives file not found on Firefox but works on Explorer,
I have had this problem before but it went away, it looks as though the coding for the page is iffy or Firefox is not interpreting somthing correctly.
JES
KWIL15/12/2012 11:48:52
3681 forum posts
70 photos
Sorry to see you appear to have a problem JES, MEW 198 works on Firefox for me, no problems at all straight in.
Terryd15/12/2012 11:55:45
1946 forum posts
179 photos
Posted by KWIL on 15/12/2012 11:48:52:
yes  Ditto,
Terry
Edited By Terryd on 15/12/2012 11:56:05
Dunc15/12/2012 14:06:08
139 forum posts
Tried IE...works!
Never had the problem b4 with Firefox but nothing beats success.
Thanks for all the help.
JES15/12/2012 14:42:44
84 forum posts
71 photos
Cleard todays History on Firefox and now all works, The world is a very confusing place,
JES
