Spotface
Wolfie02/12/2012 22:48:25
502 forum posts
Hi all, I'm still around, just working as a truck driver again so out of town an awful lot.
Next question, what does 'spotface' mean on a plan?
John Stevenson02/12/2012 23:08:55
5068 forum posts
Flat bottom for a washer of similar to sit on, usually on castings where the surface isn't flat.
John S.
Andrew Johnston02/12/2012 23:19:48
7061 forum posts
719 photos
Couldn't resist it, that's spot on John - Andrew
Windy02/12/2012 23:35:07
910 forum posts
197 photos
Good to see you back I wondered what had happened to you.
Windy
Stub Mandrel03/12/2012 20:27:29
4318 forum posts
291 photos
Spotfacer - acne-ridden engineering apprentice?
Edited By Stub Mandrel on 03/12/2012 20:36:44
chris stephens04/12/2012 00:06:25
1049 forum posts
Spot face, see someone in a crowd you recognise
NJH04/12/2012 10:14:09
2314 forum posts
139 photos
Hi Wolfie
Here is a pic of a Spotface cutter/ Counterbore. (Also known - by me- as a wallet emptier!) Makes a very neat job of creating a seating for cap headed screws.
Glad to hear that you are still about and involved
Norman
Edited By NJH on 04/12/2012 10:16:22
Bazyle04/12/2012 19:56:01
6956 forum posts
229 photos
I think the diagram above is a little deceptive in implying a recess is made. Much of the time the intention is just toi flatten off the top of a cast-in boss in a circle around the head of a bolt. Putting in a recess can create a problem of spanner access if not useing cap heads.
Rather than modify a drill it is common practice to make a simple spotfacer in silver steel the diameter of the desired spotface as follows. 1) drill end of silver steel bar the size of the hole, 2) make 2 saw cuts as an X across the end, 3) file relief on the end back from the cuts like the end of an endmill 4) harden and temper, 5) insert guide pin in the hole you drilled at the start. 6) use gently.
Andrew Johnston04/12/2012 20:33:58
7061 forum posts
719 photos
If you're just flattening the top of a boss why bother with a special tool, just use a normal milling cutter? In the picture the bosses on the small casting were cleaned up with a standard slot drill whereas the holes on the larger casting need a recess to provide a clean mating surface:
