Myford which one
ron grimshaw02/12/2012 12:25:53
40 forum posts
I have a ML7, I would like a gearbox for screw cutting, what should I do, keep my ML7 and fit a gearbox that would cost around £600 or buy a S7 which as got a gearbox fitted and sell my ML7. Or should I be looking at other options.
Nobby02/12/2012 12:31:15
587 forum posts
113 photos
Hi Ron
Get the Super 7 . The bearings are better than the ML7
Nobby
chris j02/12/2012 12:33:17
338 forum posts
17 photos
Posted by Nobby on 02/12/2012 12:31:15:
Hi Ron
Nobby
I agree.
Clean your ML to within an inch of it's like, maybe a lick of paint and get it on ebay.
David Littlewood02/12/2012 12:48:11
533 forum posts
I agree. It's not just the bearings (impportant though they are). The S7 has:
Better tailstock
Leadscrew handwheel
Longer cross-slide
Vastly improved topslide mounting
Countershaft clutch
....and probably other things I've forgotten. The ML7R has some, but not all, of these improvements. As for gearboxes, I have the impression (though I've not done a careful check) that the difference in price between S7 and S7B is less than the cost of an add-on gearbox. I certainly wouldn't want to go back to achangewheel machine again, even though you do occasionally have to use changewheels for unusual jobs.
David
NJH02/12/2012 14:06:55
2314 forum posts
139 photos
No contest Ron
If you can afford it go for the S7. It's not just for screwcutting but also for a good range of fine feeds and, depending on the model, power cross feeds too. Despite the ritual " bad mouthing" of Myford by some on this site I'm very pleased with mine, it fulfills all my requirements and is always a pleasure to use. Yes it has its limitations re spindle bore etc. but I like to make small things so I don't find myself limited here and the build quality and accuracy is good. I've been through ML4, ML 10 to Super 7B and the accessories from each have moved with me.
Norman
Nobby02/12/2012 15:40:22
587 forum posts
113 photos
HI guys
Here is mine . Can anybody spot the difference's to the original Mk one
Nobbyusing fixed steady
Stub Mandrel02/12/2012 16:02:44
4318 forum posts
291 photos
Tailstock and crossslide have rules and pointers attached for a start, and a saddle stop.
Nobby02/12/2012 16:19:18
587 forum posts
113 photos
Well done Neil
On the x slide is a 1/2 scale rule I set turning say .2 dia and zero the micromter dial and zero And set pointer on the scale to .2 . Like setting o on a cnc lathe etc
Nobby
Kevin F02/12/2012 19:22:45
96 forum posts
24 photos
I wish I went for the s7 or even the 7crying 2 But that was my own fault for not doing my homework as I though everything was interchangeable between the range ,but that's not so with the ml4 and not a lot of people seem to know or do a lot with the old ml4 .
ron grimshaw03/12/2012 13:06:33
40 forum posts
well desided to get S7 traveling to the far corners of Great Briton to get it, any one want a ML7.
