Frank Small | 28/11/2012 09:48:43 |
25 forum posts 3 photos | Hi, My printer works fine on Word etc but not on Digital Model Engineer. My PC OS is Windows 7 Premium Home When I select print on the top of the page the menu shows my printer but fails to print. When I check in to printer properties the file is not in the queue Your advice would be greatly appreciated Thank you for your interest Regards
Steambuff | 28/11/2012 11:28:05 |
![]() 544 forum posts 8 photos | I assume that you mean the "Print this page" button that appears when you click on the page to zoom in .. and not the Windows IE/Firefox print icon. Dave |
Frank Small | 28/11/2012 15:46:33 |
25 forum posts 3 photos | Hi Dave, Yes, you are correct "Print this page" button that appears when you click on the page to zoom in ..
Do you have a solution? Thank you for your interest Regards Frank
Keith Long | 28/11/2012 16:13:20 |
883 forum posts 11 photos | Hi Frank Just tried and printed no problem. I was a bit surprsed at seeing the pages numbers diplayed in the printer dialogue box as "0" but hitting the "OK" button in the dialogue box resulted in a printed page without any problem. I'm using Widows 7 starter, running on a Toshiba net book, and Firefox as the browser. You might need to check your local settings. Keith |
Roger Vane | 28/11/2012 16:33:48 |
108 forum posts 18 photos | Hi Frank
Just tried printing a page from latest MEW - no problems. The dialog box enables me to select a printer (defaults to my inkjet printer (setup under 'printers and devices' Using Windows Home Premium 64 bit and IE9. Regards, Roger
Brian in OZ | 02/12/2012 21:51:30 |
63 forum posts | Hi Frank, What on earth did you do with your last msg ?? ((Posting deleted by Diane)) I print from the page viewer though I will say that sometimes a page will take a while to upload and no printing will happen till this is complete. I think it was the previous issue of MEW the "programing person" did not position the "downloading" box very well and it was almost impossible to find (top left corner of the page). Yes, as "Steambuff" says, you print from the page viewer NOT from your browser or operating system. Regards Brian in OZ
Edited By Diane Carney on 03/12/2012 17:13:35 |
Henri Vanherle | 30/01/2013 14:39:34 |
1 forum posts | I have problems with printing pages from back issues of Model Engineer's Workshop. Although the "Print Preview" shows the correct pages I want to print, my printer turns out a completely black page. Utterly frustrating and expensive on ink. I guess I'm not using the correct procedure. Which one is? I'm using Windows 7 and my printer works fine for other jobs. Henri
David Clark 1 | 30/01/2013 15:05:50 |
![]() 3357 forum posts 112 photos 10 articles | Hi There In recent versions of Windows you can electronically turn the screen 90 degrees. I have my monitor mounted on an extending arm so I can rotate it. This is ideal for checking full page proofs. This is sufficient on most modern monitors to display a full magazine page. Then press print screen. Paste this into a paint program as a new image and then you can print it out. regards David
Dithering | 02/02/2013 15:55:13 |
20 forum posts | The "Print" item on the left-click menu doesn't work for me either - I just get a completely black page. However, if you magnify the page you will get a "Print this page" tab appearing at the top. That works OK. Brian.
Dithering | 02/02/2013 15:58:20 |
20 forum posts | Well, almost OK. Although the colour images come out in colour and the black text comes out black, the black diagrams come out in a rather faint green - thus rendering them useless! Brian. |
Russell Eberhardt | 02/02/2013 16:03:08 |
![]() 2785 forum posts 87 photos |
Posted by Frank Small on 28/11/2012 09:48:43:
Check your antivirus. It could be blocking scripts on that site. Russell. |
Gone Away | 02/02/2013 19:01:07 |
829 forum posts 1 photos |
Posted by David Clark 1 on 30/01/2013 15:05:50:
Then press print screen. Paste this into a paint program as a new image and then you can print it out. But the resolution would be terrible - on a modern monitor - maybe 96 dpi. Even a picture image is rubbish below ~150 dpi for printing (and pushing it at that). For text, I wouldn't bother. |
