Here is a list of all the postings Frank Small has made in our forums. Click on a thread name to jump to the thread.
Thread: Setting 16 TPI on Colchester Bantam Lathe |
09/08/2017 07:36:11 |
Hi Simon, Thanks again for your interest. Firstly its good that I have confirmation that I am not overlooking something I think I now have a plan to do as little damage as possible. I will make an aluminium clamp along the lines suggested by Jason that can be held in the vice against the T120 gear. One minor problem I anticipate is that the width of the clamp may not be wide enough to accommodate adequate clamping bolts, but I as sure I will think of something. What a lot of problems over what should not even be a problem. Mind you I have now decided that I will now borrow a decent socket rather that the wrench supplied by Colchester which could reduce my difficulties down the line!!!!!!! It is great to have such an exchange of ideas Regards Frank
08/08/2017 20:51:15 |
Jason, Thank you I agree about the bronze I will focus on trying to hold the small gear and the rack idea. I also may reconsider if I can pin the gears together although it is rather small Will let you know how I get on Regards frank
08/08/2017 20:15:21 |
Hi Jason, Thanks for the prompt reply. You are right Gear T120 is not splined. For that reason also I think jamming the gear train will not work, so it seems that holding the brass sleeve in the vice is the only option unless I can hold the small gear in a pipe wrench and accept any damage to that gear What do you think? Regards Frank
08/08/2017 16:52:50 |
Hi Guys, Thank you all for your kind help. I am now ready to ask the next question!!!!! The instruction requires the mounting the 127 tooth gear outside the 120 gear , to do this the retaining nut must first be removed.. I purchased the lathe secondhand and the change gear 100T was replaced by a much smaller one about the size of the retaining nut (see photo and drawing below). The problem is that the gear is about the same size as the nut and I find it impossible to hold the gear (without damaging it) whilst I try to open the nut which is very tight. If the gear were larger say 100T it would be very easy to deal with it. Any idea how I can hold the gear under the nut without damaging it. I have tried a (chain) strap wrench but it is too wide to retain the gear as the nut is very tight. I look forward to you ideas. Thank you Frank
Thank you everyone for your kind help. Now I am ready to ask the next question!!!! The instructions require the mounting the 127 tooth gear outside the 120 gear
08/08/2017 14:39:38 |
Hi Guys, I now have a different problem relating to the same subject. I simply want to attach a couple of views of the problem, is there an easy way. I can send it in any format jpeg etc. Otherwise is there a tutorial on how to do so using this post system? Thank you. Frank
08/08/2017 10:08:53 |
Thanks Guys, I am sure that will solve my problem. I did not notice the 127 gear on the plate and also not realise that it is possible to place more than one gear on the same shaft. Regards Frank
07/08/2017 20:03:59 |
Hi Guys, I am trying to cut a 16 TPI thread using a Colchester Bantam 1600 Lathe for the first time. It is fitted with a metric pitch lead screw (6mm) The settings I have used are as follows as per information plate. Gears 120 V-42 W-36 The Gear levers are T5 but I find that the measured TPI is aprox 18 I notice that there is also 127 adjacent to the 120 on panel. Could this be the problem. I am using a mandrel as I have no thread dial but I think that should not be causing the problem. Any ideas would be very welcome Thank you
Thread: Allen key screw heads |
14/08/2016 17:43:50 |
Hi Guys, Many thanks for your help. It will take me time to follow up on your very useful suggestions but I would just like to respond to one comment/question. This is my first attempt at a model engineering project and I thought it might be better to adhere to the BA system as per my instructions in case I created any unanticipated difficulties even though I was aware that metric has probably superseded the BA. Now I have a good selection of small BA taps and dies so I feel I am tied to that system for the present Regards |
11/08/2016 07:56:42 |
Hi Guy, I am presently building a Stuart V10 steam engine and am a relative beginner. I chose to use BA fasteners rather than metric. U Tube's Tinker John suggested using screws with Allen key heads to ease trial assembly, an excellent suggestion, in my view. Does anyone have any Idea where I could obtain miniature screws, either BA or Metric with Allen key heads suitable for the above task? Thank you for your interest Regards
Thread: Stuart V10 Cylinder Casting |
14/07/2015 18:04:11 |
Hi Guys, Thanks for the info Ian. I sadly have another question. I am proceeding well with the Stuart engine and am taking my information from "Building a Vertical Steam Engine" by Andrew Smith Revised by Pengwren. However when I assemble the crank shaft, con rod, piston, column etc I find that on the top of travel the piston protrudes by nearly 6mm. The valve assembly seems fine and will be adjustable to carry out its function which indicates that the column is ok. Piston travel is 20mm which indicates that the throw is ok. I have measured all relevant components and even if I say so myself the dims are not bad. I am beginning to think that there may be an error in book and I have even checked the conversion from imperial to metric and can't find an error. My question: is there an error in my work or in my information? I look forward to your replies Thank you
26/06/2015 11:35:58 |
Hi Guys, Just a quick update. After a lot of consideration I decided to drill a further hole in the Steam chest housing and use the counter sunk screw solution as suggestion in one of the posts. Excellent result. I adopted this solution as it was a technique I could identify most with. Oh, by the way, what is alum and where could I get it. Thanks again |
17/06/2015 19:31:57 |
Hi Guys Many thanks for all that good advice and encouragement. I like the idea of the hollow silver steel bit but will experiment first. Possibly end up with using 3 holes, nice to know there are alternatives!! Regards |
30/05/2015 17:24:03 |
Hi Everyone, Just had a disaster. Drilled the cylinder for the steam chest screws. I was tapping the 7BA holes and snapped it. Is there any way I can recover the cylinder, the tap is broken off flush with the casting. I guess, probably not, which gets me on to the second question which is, has anyone a casting surplus to requirements? Thank you for your interest and hopefully a reply
Thread: Printing page on digital Model Engineer |
28/11/2012 15:46:33 |
Hi Dave, Yes, you are correct "Print this page" button that appears when you click on the page to zoom in ..
Do you have a solution? Thank you for your interest Regards Frank
28/11/2012 09:48:43 |
Hi, My printer works fine on Word etc but not on Digital Model Engineer. My PC OS is Windows 7 Premium Home When I select print on the top of the page the menu shows my printer but fails to print. When I check in to printer properties the file is not in the queue Your advice would be greatly appreciated Thank you for your interest Regards
Thread: Contact admin staff |
01/10/2012 16:03:15 |
Hi Everyone, Some time ago I subscribed to the digital version of either the Model Engineer of the Model Engineers Workshop . Now I wish to subscribe to the other one. Unfortunatly I cant remember which so I need to contact the admin staff. I have searched for a link to admin but am unable to find one. Would someone be kind enough to point me in the right direction Thank you
Thread: adjusting gib on machine vice |
19/11/2010 09:58:03 |
Hi Guys,
Many thanks for you interest.
The history of the vice is unknown and hence the clean, stripdown inspection and repair is important. Without your input I would probably have spent a lot of time just trying to carry out the adjustments.
FS
18/11/2010 20:07:34 |
Hi Guys,
I have a Deckel lookalike milling machine with its own excellent vice
The gibs on the vice need adjusting as the workpiece tilts badly when vice is tightened. There is multiple set screws for the gib and wonder if there is a good way to carry out the adjustment
FS |
Thread: Angled HSS toolholder and tool sharpening angles |
19/09/2010 11:08:26 |
Hi Guys,
Many thanks for your assistance which is very reassuring when information is otherwise limited. The results I am now achieving are certainly as good as the carbide tips I suspect I could improve that by creating that radius on the tip. I tried using the grinder but it seems too course.Maybe I will try a stone I will summerise my approach to tool and tool height to date. It is only my approach but may be helpful to others. I used to set and measure tool height with a digital vernier but of course it was a hit and miss affair. I was also using carbidre tips. In the search for a better finish I decided to use HSS cutters. I then decided to get serious, measuring tool height accuratly guided by article in MEW
1. Turn a shaft to any diameter 2. Measure and divide by 2 3. Using block and feeler gauge measure height to lower edge of shaft 4. Add two results to give tool height. Obtain a block of steel that will stand vertically on saddle and exceeding the tool height by perhaps 10mm Machine a slot to mark the tool height from saddle. This is the tool for setting cutter height. The tools in the angeled HSS holders can now be adjusted in out to set correct tool height as suggested in the forum Carbide holders can be machined to correct tool height. Something I was reluctant to do until I was sure of the exact height. Now to gringing the HSS base on my understanding of the help I received on the forum No need to grind a "back rake angle" as this is provided by the tilt of the tool holder. However there is a need to have a side rake angle The profile of the tool as presented to the workpiece should be the same as that in the many well publisied article. Regards
Frank |
18/09/2010 09:20:48 |
Hi John,
Many thanks for clearing up my understanding of sharpening HSS tools
From what you say I assume the normal published data is for horizontal tool holders and needs adjustment to accomodate the tilt on the tool.
Frank
