Terryd | 03/11/2012 08:50:54 |
![]() 1946 forum posts 179 photos | Hi all, I am about to fit a new vertical scale to my milling machine and need to drill the scale to connect to the quill. Is there anything I should know before starting, will normal HSS drills do the job? Thanks in advance Regards Terry |
Douglas Johnston | 03/11/2012 09:12:21 |
![]() 814 forum posts 36 photos | I did this a while ago and found that a HSS drill was no good. I ended up using a solid carbide drill and this proved to be ideal. You could use a clamp type fixing which would eliminate the need to drill the scale. Doug |
Terryd | 03/11/2012 10:14:37 |
![]() 1946 forum posts 179 photos | Hi Doug, I may go down teh clamping route initially. Thanks for the information. Best regards Terry |
colin hawes | 03/11/2012 11:54:00 |
570 forum posts 18 photos | I think you ought to forget drilling scales when clamping is perfectly adequate. Colin |
Ian P | 03/11/2012 13:17:16 |
![]() 2747 forum posts 123 photos | I have had no problem drilling the common 'stainless' Chinese calipers with ordinary HSS twist drills, in fact I have tapped M4 threads into them as well. When drilling you need to apply lots of pressure so that you can take a good cut rather than letting the drill rub. Ian P |
Michael Cox 1 | 03/11/2012 13:27:04 |
555 forum posts 27 photos | I also had no problem drilling cheap Chinese digital caliper using HSS drills. It cuts easily with a hacksaw. As Ian said maintain a good pressure to prevent work hardening. Mike Mike |
