Cast iron
where to buy
Ziggar02/11/2012 23:09:59
115 forum posts
Hi all
am looking to buy a chunk of cast iron that when i finish with it will have a size of 130 mm diam X 30mm thick
have tried several suppliers that i have bookmarked and none seem to have it in the size i need or even carry cast iron at all
so does anyone know of any suppliers that they know would have this and deliver nationwide - UK
TIA
Nicholas Farr03/11/2012 04:05:42
3988 forum posts
1799 photos
Hi Ziggar, have you tried The College Engineering Supply **LINK**
Regards Nick
JasonB03/11/2012 07:35:22
M-machine do 130mm CI cut to length at £9.32/25mm so cost you about £12 but that may be a bit tight on your finished Dia so they also do 140mm at £10.20/25mm.
Ian S C03/11/2012 08:19:40
7468 forum posts
230 photos
When buying cast materials, the actual size is usually a given amount oversize to allow for machining, so the 130 mm bar should machine to 130 mm. Ian S C
JasonB03/11/2012 08:34:35
I do find that CI is quite tight to size you may be thinking of cast bronze which usually has a bit more to play with, just measured some CI I have.
80mm = 80.91
70mm = 70.83
60mm = 60.12
45mm = 45.47
25mm = 25.44
So very little to play with.
colin hawes03/11/2012 12:09:26
570 forum posts
18 photos
I don't know the application for your cast iron project, but sometimes the obvious is easy to miss.When I design things I take standard stock sizes into account so as to involve minimum waste and machining.Dooes it really have to be exactly 130 mm finished? Colin
Ziggar04/11/2012 00:42:16
115 forum posts
Hi all
appreciate the links
Thanks
