Raymond Anderson | 25/10/2012 18:23:30 |
![]() 785 forum posts 152 photos | Hi All, Have got about half way through making my new tilting table.It has 190 degrees of tilt *95 /-95 It is mostly from Meehanite, apart from the 2 shafts and their flanged nuts [1 right hand thread and 1 left hand thread] they are from EN24T . But I seem to have boobed with the weight I reckoned about 40 kg's when finished but it is now at a shade under 51kg's and still has the base to go so will probably be nearer 60kg's but it is very very rigid and stable so that is 1 plus from the boob. As it is just now when horizontal on the granite surface plate there is 0.004mm from end to end so I am happy with the accuracy it's just the weight is a pest [being a bricklayer I am used to lifting Granite a lot heavier than the table] but putting the thing on the milling machine in a controlled manner is not easy. I have put a photo in my album for anyone interested. Regards, Raymond. Edited By Raymond Anderson on 25/10/2012 18:26:33 |
Ady1 | 25/10/2012 18:27:33 |
![]() 6137 forum posts 893 photos |
Raymond Anderson | 25/10/2012 18:35:40 |
![]() 785 forum posts 152 photos | Thanks Ady I was not to sure about how to stick a photo into a post ,Cheers. Raymond. |
KWIL | 25/10/2012 18:53:16 |
3681 forum posts 70 photos | It obviously stays attached to a mill by its own weight? |
Raymond Anderson | 25/10/2012 19:05:42 |
![]() 785 forum posts 152 photos | KWIL, Unfortunately it won,t stay with it's own weight, the base still has to be completed. as has the Tslots, or a threaded tooling plate [ argh, even more weight] Raymond. |
James B | 25/10/2012 20:52:16 |
![]() 101 forum posts 14 photos | Hi Raymond, I like the flycutter - homemade? Is that a Glanze tipped tool you have in there? How do you find it works with the tipped insert? Table looks good too! Thanks James
KWIL | 25/10/2012 22:00:58 |
3681 forum posts 70 photos | Raymond How nice to see another user of a Newall C80, I have several. K
Thor 🇳🇴 | 26/10/2012 05:41:26 |
![]() 1766 forum posts 46 photos | Hi Raymond, The table looks nice, I like the clamps you made, Regards Thor |
Raymond Anderson | 26/10/2012 07:11:43 |
![]() 785 forum posts 152 photos | Hello All, James the cutter that you mention is not really a flycutter ,I made several in Ø's up to 150mm they take indexable tools, the largest takes 5 tools and the smallest takes 2 they are from EN16T In the larger ones I often remove a few tools and leave only 2 depends on what I am milling Yes I think 1 has a couple of Glanze tools the others are either Sandvik Coromant or Walter NOVEX they work great with the correct insert I will stick a few photo's of the others in my album. KWIL, Yes the Newall C80 is a great piece of gear .I also have a Newall topaz 2 axis on the Warco GH750 lathe and a Heidenhain on the DSG. Thor, The plate clamps you mention are machined from EN16T the front faces are from EN24T. the guides bars [to prevent any rotation of the front face] are from silver steel they are designed to apply a downward force as well as a linear force and they can apply a lot of pressure if needed. There is not really much to them but they must be made very accurate to work correctly I will take 1 apart and stick it in my album. Regards, Raymond. |
Ian S C | 27/10/2012 02:28:53 |
![]() 7468 forum posts 230 photos | Raymond, is the table hollowed out underneath? That would lose a bit of weight, you could also put resesses in each leg, and at the bottom of the legs have a slot for a mounting stud, just an idea to lose a bit of surplus. Ian S C |
Raymond Anderson | 27/10/2012 18:04:32 |
![]() 785 forum posts 152 photos | Ian, No, the table is not hollowed out . I see where you are coming from, re saving some weight. But it will be managable at approx 60kgs, and I like everything solid and rigid and it's certainly both. The construction side of the table should be finished tomorrow [ the base], and then only the T slots [or tapped tooling plate] will remain to be done, then it's done and dusted. Regards, Raymond. |
Ian S C | 28/10/2012 11:47:09 |
![]() 7468 forum posts 230 photos | Raymond, I was just thinking what I would do, I look at it this way, I can lift it now, but will I be able to do it in years to come, Thats why I built a hoist to move the chucks on the lathe,m they are 8", so a reasonable weight, but this year I'v had trouble with my legs, and the hoist has come into its own. The only time I have to man handle a chuck, is when I want to put it on the rotary table on the milling machine. The hoist uses the motor from a garage door opener, I think its a 36V motor, but it's ok on my 17V workshop low voltage supply. Ian S C |
Raymond Anderson | 29/10/2012 17:34:25 |
![]() 785 forum posts 152 photos | Michael, good call about the t-slots, I have the table scraped flat and true so I would not want the slightest distortion . I have decided to install a threaded tooling plate, they are also made to very fine limits of flatness. Yes I will certainly need a fail safe as it would certainly do the fingers a bit of damage. [in fact if I were to loosen it from the horizontal and it decided to tilt on to the fingers then I would most probably be looking at broken fingers at the very least ] again. Regards, Raymond. Ps, The worm wheel sounds a nice idea, I will try to design one to suit the almost finished table. or else it's the easy way out [blocks of wood]. |
